paralell-netcdf-1.1.1 installation problem
Rob Latham
robl at mcs.anl.gov
Wed Feb 3 10:59:36 CST 2010
On Wed, Feb 03, 2010 at 11:40:37AM -0500, Shawn Kim wrote:
> Hi,
> I did autoreconf before "configure". I attached the output from configure
> and macros.make.
> Thank you.
> - Shawn
> $ ./configure
> --prefix=/home/mdl/yuazhang/IOTracing/benchmark/parallel-netcdf-1.1.1/install
> --with-mpi=/home/mdl/yuazhang/IOTracing/mpich2-1.0.8 --enable-fortran | &
Is mpich2-1.0.8 the directory where you built mpich2, or is it the
directory where you installed it?
> checking mpi C compiler ... configure: WARNING: mpicc either does not exist
> or is not executable: falling back to mpicc
> using mpicc
> checking mpi C++ compiler ... using
> /home/mdl/yuazhang/IOTracing/mpich2-1.0.8/bin/mpicxx
> checking mpi Fortran 77 compiler ... configure: WARNING: mpif77 either does
> not exist or is not executable: falling back to mpif77
> using mpif77
> checking mpi Fortran 90 compiler ... configure: WARNING: mpif90 either does
> using mpif77
These lines all point to the former.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
More information about the parallel-netcdf
