seg fault caused by nonblocking reads of scalar variables
Kui Gao
kgao at eecs.northwestern.edu
Tue Dec 14 22:37:26 CST 2010
Hi Jeff,
Thank you for your report.
Could you please send me your test code? I'd like test it.
Thanks and regards,
Kui.
On Dec 14, 2010, at 4:15 PM, Daily, Jeff A wrote:
> Using pnetcdf 1.2.0, I get a seg fault during ncmpi_wait_all if I try to read both scalar and dimensioned variables at the same time. I'm using ncmpi_iget_vara_XXX calls followed by ncmpi_wait_all. I can read 1 or more dimensioned variables. I can read 1 or more scalar variables. But once I try to mix scalar and dimensioned, I get the seg fault during ncmpi_wait_all. If I use the blocking calls, everything works okay, but then I'm only reading one variable at a time.
> Any ideas? Thanks.
> Jeff
More information about the parallel-netcdf
