filename prefixes
michael michael.bane at manchester.ac.uk
Wed Aug 11 18:54:02 CDT 2010
Isn't there a WRF configure option to use HDF5 (par) with netcdf4 to
give you much the same thing? In which case there may be something in
the relevant external/ (or externio?) (from mem!) subdir to peek at?
Michael
http://www.twitter.com/mkbane_mcr
On Wed, 2010-08-11 at 18:47 -0500, Gerald Creager wrote:
> On the system I'm working with, I can't use the MPICH envVars such as:
> MPICH_MPIIO_HINTS_DISPLAY 1
> MPICH_MPIIO_HINTS “wrfout*:striping_factor=64”
> Therefore, to set striping on the wrfout files, with a Lustre file
> system and SGE for the batch queuing environment, I've gotta find where
> the wrfout file creation instance occurs and add a couple lines of code
> to make it create the wrfouts with stripe-counts appropriately set
> (somewhere between 16-64, I think). What I intend to do eventually, is
> to get that folded back into WRF as a namelist parameter, so that those
> of us using pnetcdf (needed if proc count gets past ~512 or so on this
> system) can have a simplified granular method of using striping on
> parallel file systems (specifically with pnetcdf).
> I've looked at Johnsen's work to use Lustre on the Cray XT5. It dowsn't
> apply to my environment, more's the pity.
> Thanks, Gerry
> Don Morton wrote:
> > I've used pnetcdf with WRF, using the nocolons option.  I'm not sure
> > specifically what you're asking now, but I can send you my notes if it
> > helps...
> > On Wed, Aug 11, 2010 at 3:13 PM, Gerald Creager <gerry.creager at tamu.edu
> > <mailto:gerry.creager at tamu.edu>> wrote:
> >     It's a namelist.input spec: NOCOLONS
> >     I'm sorting thru some other issues with pnetcdf and WRF right now...
> >     I'm having to change it so it'll create wrfout_dxx files with the
> >     striping info correct at file creation. If anyone's had to do this,
> >     I'd appreciate a clue...
> >     gerry
> >     Jim Edwards wrote:
> >         Hi Johnny,
> >         I think that the real problem may be that WRF uses the colon
> >         character in filenames and the filesystem reserves this same
> >         character for special use.   I think that there is a compile
> >         option for wrf not to use colons.
> >         Jim
> >         On Wed, Aug 11, 2010 at 4:44 PM, Johnny Chang
> >         <Johnny.Chang at nasa.gov <mailto:Johnny.Chang at nasa.gov>
> >         <mailto:Johnny.Chang at nasa.gov <mailto:Johnny.Chang at nasa.gov>>>
> >         wrote:
> >            Hello,
> >            I am helping a user trouble-shoot a runtime error using
> >            parallel-netcdf version 1.1.1 and mvapich2/1.2p1/intel-PIC.
> >            The error message is:
> >             0: MPI_File_open : File does not exist, error stack:
> >            ADIO_RESOLVEFILETYPE_PREFIX(546): Invalid file name
> >            wrfout_d01_2006-07-25_00:00:00
> >             open_hist_w : error opening wrfout_d01_2006-07-25_00:00:00 for
> >            writing. ***
> >            While googling the ADIO_RESOLVEFILETYPE_PREFIX error, we
> >         found the
> >            ad_fstype.c code containing:
> >            477     /*
> >            478       ADIO_FileSysType_prefix - determines file system
> >         type for
> >            a file using
> >            479       a prefix on the file name.  upper layer should have
> >            already determined
> >            480       that a prefix is present.
> >            481        482     Input Parameters:
> >            483     . filename - path to file, including prefix (xxx:)
> >            484        485     Output Parameters:
> >            486     . fstype - pointer to integer in which to store file
> >         system
> >            type (ADIO_XXX)
> >            487     . error_code - pointer to integer in which to store
> >         error code
> >            488        489       Returns MPI_SUCCESS in error_code on
> >         success.  Filename
> >            not having a prefix
> >            490       is considered an error. Except for on Windows systems
> >            where the default is NTFS.
> >            491        492      */
> >            493     static void ADIO_FileSysType_prefix(char *filename, int
> >            *fstype, int *error_code)
> >            494     {
> >            495         static char myname[] = "ADIO_RESOLVEFILETYPE_PREFIX";
> >            496         *error_code = MPI_SUCCESS;
> >            497        498         if (!strncmp(filename, "pfs:", 4) ||
> >         !strncmp(filename,
> >            "PFS:", 4)) {
> >            499             *fstype = ADIO_PFS;
> >            500         }
> >            557     #else
> >            558             *fstype = 0;
> >            559             /* --BEGIN ERROR HANDLING-- */
> >            560             *error_code = MPIO_Err_create_code(MPI_SUCCESS,
> >            MPIR_ERR_RECOVERABLE,
> >            561                                                myname,
> >         __LINE__,
> >            MPI_ERR_NO_SUCH_FILE,
> >            562                                                "**filename",
> >            "**filename %s", filename);
> >            563             /* --END ERROR HANDLING-- */
> >            564     #endif
> >            565         }
> >            566     }
> >            which seems to indicate that the MVAPICH2 library is expecting
> >            parallel-netcdf
> >            to pre-pend a prefix on the filename passed to the MVAPICH2
> >         library.
> >            We are running on a Lustre filesystem.  So, we think that the
> >            parallel-netcdf
> >            library should have passed the "lustre:" or "LUSTRE:" prefix
> >         along
> >            with the
> >            actual filename.  Are we right in this interpretation of the
> >         error?
> >            If so, then perhaps the parallel-netcdf library was not built
> >         correctly?
> >            Here is the beginning part of config.log:
> >            This file contains any messages produced by compilers while
> >            running configure, to aid debugging if configure makes a mistake.
> >            It was created by configure, which was
> >            generated by GNU Autoconf 2.61.  Invocation command line was
> >             $ ./configure --prefix=/nasa/parallel-netcdf/1.1.1/mvapich2
> >            --with-mpi=/nasa/mvapich2/1.2p1/intel-PIC
> >            ## Platform. ##
> >            hostname = pbspl1
> >            uname -m = x86_64
> >            uname -r = 2.6.16.60-0.42.5.03schamp-nasa
> >            uname -s = Linux
> >            uname -v = #1 SMP Tue Nov 10 20:46:20 UTC 2009
> >            /usr/bin/uname -p = unknown
> >            /bin/uname -X     = unknown
> >            /bin/arch              = x86_64
> >            /usr/bin/arch -k       = unknown
> >            /usr/convex/getsysinfo = unknown
> >            /usr/bin/hostinfo      = unknown
> >            /bin/machine           = unknown
> >            /usr/bin/oslevel       = unknown
> >            /bin/universe          = unknown
> >            PATH: /nasa/intel/Compiler/11.1/046/bin/intel64
> >            PATH: /nasa/intel/Compiler/11.1/046/mkl/tools/environment
> >            PATH: /nasa/mvapich2/1.2p1/intel-PIC/bin
> >            PATH: /u/jrappley/bin
> >            If the problem is in the parallel-netcdf build, let us know
> >            what is the fix.
> >            Thanks in advance!
> >            Johnny
> >            --     Johnny Chang
> >            650-604-4356
> >     Gerry Creager -- gerry.creager at tamu.edu <mailto:gerry.creager at tamu.edu>
> >     Texas Mesonet -- AATLT, Texas A&M University
> >     Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.862.3983
> >     Office: 1700 Research Parkway Ste 160, TAMU, College Station, TX 77843
> > Arctic Region Supercomputing Center
> > http://weather.arsc.edu/
