filename prefixes
Johnny Chang Johnny.Chang at nasa.gov
Wed Aug 11 17:44:45 CDT 2010
Hello,
I am helping a user trouble-shoot a runtime error using
parallel-netcdf version 1.1.1 and mvapich2/1.2p1/intel-PIC.
The error message is:
  0: MPI_File_open : File does not exist, error stack:
ADIO_RESOLVEFILETYPE_PREFIX(546): Invalid file name wrfout_d01_2006-07-25_00:00:00
  open_hist_w : error opening wrfout_d01_2006-07-25_00:00:00 for writing. ***
While googling the ADIO_RESOLVEFILETYPE_PREFIX error, we found the
ad_fstype.c code containing:
477     /*
478	  ADIO_FileSysType_prefix - determines file system type for a file using
479	  a prefix on the file name.  upper layer should have already determined
480	  that a prefix is present.
481
482	Input Parameters:
483	. filename - path to file, including prefix (xxx:)
484
485	Output Parameters:
486	. fstype - pointer to integer in which to store file system type (ADIO_XXX)
487	. error_code - pointer to integer in which to store error code
488
489	  Returns MPI_SUCCESS in error_code on success.  Filename not having a prefix
490	  is considered an error. Except for on Windows systems where the default is
NTFS.
491
492	 */
493	static void ADIO_FileSysType_prefix(char *filename, int *fstype, int
*error_code)
494	{
495	    static char myname[] = "ADIO_RESOLVEFILETYPE_PREFIX";
496	    *error_code = MPI_SUCCESS;
497
498	    if (!strncmp(filename, "pfs:", 4) || !strncmp(filename, "PFS:", 4)) {
499	        *fstype = ADIO_PFS;
500	    }
557	#else
558	        *fstype = 0;
559	        /* --BEGIN ERROR HANDLING-- */
560	        *error_code = MPIO_Err_create_code(MPI_SUCCESS, MPIR_ERR_RECOVERABLE,
561	                                           myname, __LINE__,
MPI_ERR_NO_SUCH_FILE,
562	                                           "**filename", "**filename %s",
filename);
563	        /* --END ERROR HANDLING-- */
564	#endif
565	    }
566	}
which seems to indicate that the MVAPICH2 library is expecting parallel-netcdf
to pre-pend a prefix on the filename passed to the MVAPICH2 library.
We are running on a Lustre filesystem.  So, we think that the parallel-netcdf
library should have passed the "lustre:" or "LUSTRE:" prefix along with the
actual filename.  Are we right in this interpretation of the error?
If so, then perhaps the parallel-netcdf library was not built correctly?
Here is the beginning part of config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.61.  Invocation command line was
   $ ./configure --prefix=/nasa/parallel-netcdf/1.1.1/mvapich2
--with-mpi=/nasa/mvapich2/1.2p1/intel-PIC
## Platform. ##
hostname = pbspl1
uname -m = x86_64
uname -r = 2.6.16.60-0.42.5.03schamp-nasa
uname -s = Linux
uname -v = #1 SMP Tue Nov 10 20:46:20 UTC 2009
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /nasa/intel/Compiler/11.1/046/bin/intel64
PATH: /nasa/intel/Compiler/11.1/046/mkl/tools/environment
PATH: /nasa/mvapich2/1.2p1/intel-PIC/bin
PATH: /u/jrappley/bin
If the problem is in the parallel-netcdf build, let us know
what is the fix.
Thanks in advance!
Johnny
Johnny Chang
650-604-4356
