Compilation problem when using openmpi-1.3.3
Christoper Daley
cdaley at flash.uchicago.edu
Thu Nov 26 13:56:09 CST 2009
Hi all,
Thanks Rich and Kui for the patches. Both patches allow me to
compile parallel-netcdf-1.1.0 with openmpi-1.3.3, and allow me to run
our C test problems successfully. I am using Rich's patch for now as
the additional C++ fix is needed to compile our C++ application.
Chris
Kui Gao wrote:
> Hi Chris,
> The attached patch is for openmpi-1.3.3. The patch should apply to
> the original parallel-netcdf1.1.0. A new MPI_Datatype variable is added in
> the struct in order to avoid the convert between nc_type and MPI_Datatype.
> Thanks a lot for Rich's patch.
> Kui.
> From: parallel-netcdf-bounces at lists.mcs.anl.gov
> [mailto:parallel-netcdf-bounces at lists.mcs.anl.gov] On Behalf Of Rich Lee
> Sent: Wednesday, November 25, 2009 5:38 PM
> To: Christoper Daley
> Cc: parallel-netcdf at lists.mcs.anl.gov
> Subject: Re: Compilation problem when using openmpi-1.3.3
> I found that the attached patch I created helped me in compiling
> parallel-netcdf 1.1.0 with openmpi (version 1.2.7). Note that the patch
> should apply to the original parallel-netcdf 1.1.0 distribution. It
> contained addition fix (for C++ compiler) I reported early.
> Best regards,
> Rich Lee
> SLAC National Accelerator Lab
> On Tue, Nov 24, 2009 at 9:45 AM, Christoper Daley
> <cdaley at flash.uchicago.edu> wrote:
> Hi Kui,
> I applied the patch, and now get a different compilation error:
> mpinetcdf.c: In function ‘ncmpii_postprocess’:
> mpinetcdf.c:8249: error: incompatible type for argument 1 of
> ‘ncmpii_postread’
> mpinetcdf.c:8143: note: expected ‘nc_type’ but argument is of type
> ‘MPI_Datatype’
> mpinetcdf.c: In function ‘ncmpi_iget_var1’:
> mpinetcdf.c:8794: error: incompatible types when assigning to type
> ‘MPI_Datatype’ from type ‘nc_type’
> mpinetcdf.c: In function ‘ncmpi_iget_var’:
> mpinetcdf.c:9078: error: incompatible types when assigning to type
> mpinetcdf.c: In function ‘ncmpi_iget_vara’:
> mpinetcdf.c:9372: error: incompatible types when assigning to type
> mpinetcdf.c: In function ‘ncmpi_iget_vars’:
> mpinetcdf.c:9661: error: incompatible types when assigning to type
> Chris
> Kui Gao wrote:
> Hi Chris,
> Thank you very much for your report. It is a bug. "nc_type
> vartype" should be replaced by "MPI_Datatype vartype" at
> L66 in src/lib/pnetcdf.h . The patch file is attached.
> Thanks,
> Kui.
> -----Original Message-----
> [mailto:parallel-netcdf-bounces at lists.mcs.anl.gov] On Behalf Of Rob Ross
> Sent: Tuesday, November 24, 2009 8:37 AM
> Yeah you're right that does look like a bug. Thanks! -- Rob
> On Nov 24, 2009, at 12:16 AM, Christoper Daley wrote:
> Hi all,
> I'm unable to compile parallel-netcdf-1.1.0 with openmpi-1.3.3 compiler
> wrapper script (using gcc 4.4.2). I get the following compilation error:
> mpinetcdf.c:13216: error: incompatible types when assigning to type
> 'nc_type' from type 'MPI_Datatype'
> (*request)->vartype = datatype;
> This looks like a bug to me as vartype is an enum field in the
> NCMPI_Req data structure.
> I am able to compile parallel-netcdf-1.1.0 with mpich2-1.1.1p1
> compiler wrapper script. I think this is because MPI_Datatype is
> a typedef for an integer in mpich, and so can be freely
> mixed with enum types. This is not the case in openmpi where
> MPI_Datatype is a typedef for a pointer to struct.
> Thanks for any help,
> Chris
More information about the parallel-netcdf
