Problem on Blue Gene/P
Wei-keng Liao wkliao at ece.northwestern.edu
Mon Jun 15 10:37:37 CDT 2009
This error message indicates a different value used in defining
variable metadata
among processes. Please make sure the variable define values are the
same across
all processes.
Wei-keng
On Jun 14, 2009, at 1:50 PM, Julien Bodart wrote:
> Hi Wei-keng,
> Actually, if I was writing a single file, the array size in this
> case would be around 2^31. But as I am writing on several files
> (64), the size decreases to 2^25, which I guess, should not be a
> problem.
> Do you have any informations on the kind of check which is performed
> before giving this error message:
> "NC definations on multiprocesses conflict."
> Thanks for your help!
> 2009/6/13 Wei-keng Liao <wkliao at ece.northwestern.edu>
> Hi, Julien,
> The current release of parallel netcdf 1.0.3 does not support
> an array size that has more than 2^32 elements. It is because
> of the netCDF header format uses only 32-bit integers. I think
> this is most likely your case.
> The next release of pnetCDF will support large-size arrays,
> i.e. > 2^32 elements. The file format will also have slight
> changes (in order to use 64-bit integers for metadata.)
> Wei-keng
> On Jun 12, 2009, at 7:19 AM, Julien Bodart wrote:
> Hi everybody,
> I am doing some CFD on a Blue Gene/P computer (40 thousand cores). I
> am trying to use parallel Netcdf, as I originally used Netcdf-3
> format. Everything works fine on small cases(10 millions grid
> points), but when going to bigger cases (1000 millions grid-points)
> problems arise. I tried to use the 64 bits flag, which does not
> improve the matter.
> Actually I am trying to write 64 files whose size is lower than 1GB,
> using some subcommunicators.
> While it does not create any problems on small cases, bigger cases
> stop at the ncmpi_enddef call on some files (randomly, even with
> synchronisation in between), saying that there is a mismatch between
> dimensions. After many check it does not seems that there is
> something wrong with the dimensions. I have no idea of how to solve
> the problem. Did anyone had similar problem? Thanks for your help.
> Julien
