problem with put_att (maximum number of attributes)
Alex Hoffmann ah519 at cam.ac.uk
Tue Feb 24 11:15:36 CST 2009
Yes, this works, also if I replace in the old version the vectors for
start and count by corresponding vector variables.  Thank you.
Is this a function interface issue?
Lex
Wei-keng Liao wrote:
> Hi, Lex,
> Can you try the attached program? I removed the serial netCDF part.
> Since I don't have any problem of running it, I would suggest you to
> run mpiexec in the debug mode and find the exact error location in pnetCDF.
> Please let us know.
> Wei-keng
> On Feb 24, 2009, at 3:33 AM, Alex Hoffmann wrote:
>> Dear Wei-keng,
>> The following are the MPI errors I get, also if I subdivide the line
>> (surely it can't be necessary to divide lines, though?).  I never had
>> any compilation problems...
>> The job aborts at the nfmpi_put_vara_real_all() call, so my serial
>> netCDF subfiles are still assigned and the parallel netCDF file still
>> created.
>> Cheers,
>> Lex
>> aborting job:
>> Fatal error in MPI_Waitall: Other MPI error, error stack:
>> MPI_Waitall(273): MPI_Waitall(count=5, req_array=0xa11220,
>> status_array=0xa1dc70) failed
>> MPIDI_CH3_Progress_wait(207): an error occurred while handling an event
>> returned by MPIDU_Sock_Wait()
>> MPIDI_CH3I_Progress_handle_sock_event(540): ch3|sock|immedread 0xa07e50
>> 0xa116e0 0xa0cd70
>> MPIDU_Sock_readv(331): the supplied buffer contains invalid memory
>> (set=0,sock=3,errno=14:Bad address)
>> aborting job:
>> Fatal error in MPI_Alltoall: Other MPI error, error stack:
>> MPI_Alltoall(814): MPI_Alltoall(sbuf=0xa1b180, scount=1, MPI_INT,
>> rbuf=0xa1b160, rcount=1, MPI_INT, comm=0x84000001) failed
>> MPI_Waitall(273): MPI_Waitall(count=8, req_array=0xa1b240,
>> status_array=0xa1b270) failed
>> MPIDI_CH3I_Progress_handle_sock_event(492):
>> connection_recv_fail(1728):
>> MPIDU_Socki_handle_read(590): connection closed by peer (set=0,sock=1)
>> aborting job:
>> Fatal error in MPI_Allreduce: Other MPI error, error stack:
>> MPI_Allreduce(1058): MPI_Allreduce(sbuf=0x7fff2f18140c,
>> rbuf=0x7fff2f181408, count=1, MPI_INT, MPI_MAX, comm=0x84000000) failed
>> MPIR_Allreduce(317):
>> MPIC_Sendrecv(161):
>> MPIC_Wait(308):
>> MPIDU_Socki_handle_read(614): connection failure
>> (set=0,sock=2,errno=104:Connection reset by peer)
>> rank 0 in job 37  Herzog131_50855   caused collective abort of all ranks
>> exit status of rank 0: return code 13
>>> Hi, Lex,
>>> I got a compile error of "Syntax error in array constructor" from the
>>> line calling
>>> nfmpi_put_vara_real_all(). But after divide this line into two lines:
>>>  call
>>> handle_err_nc_p(nfmpi_put_vara_real_all(NCIDP,array_varIDP,(/istart,jstart/),
>>> (/nx_mpi,ny_mpi/),reshape(array,(/nx_mpi,ny_mpi/))),10)
>>> Everything compiles, runs OK.
>>> Please tell us what MPI errors you have got.
>>> The followings is from the command-line output and ncmpidump:
>>> % mpiexec -n 4 mpi_setup_netCDFout
>>> Myrank 0:            0
>>> MPI initialized!
>>> Number of processes [nprocs]:            4
>>> Coords of process            0  :           0           0
>>> whole 4*4 array on each process:
>>> 11.00000       12.00000       13.00000       14.00000
>>> 21.00000       22.00000       23.00000       24.00000
>>> 31.00000       32.00000       33.00000       34.00000
>>> 41.00000       42.00000       43.00000       44.00000
>>> subgrid array on process with coords            0           0 :
>>> shape:            2           2
>>> 11.00000       12.00000
>>> 21.00000       22.00000
>>> array in nc_out_p subroutine
>>> 11.00000       21.00000       12.00000       22.00000
>>> (/nx,ny/)                    2           2
>>> (/istart,jstart/)                     1                    1
>>> pnetCDF var dimensions in xy                     4                    4
>>> ntx_mpi                     4
>>> ntx                4
>>> nx_mpi                      2
>>> nx                 2
>>> % ncmpidump out_glb.nc
>>> netcdf out_glb {
>>> dimensions:
>>>  x = 4 ;
>>>  y = 4 ;
>>> variables:
>>>  float x(x) ;
>>>  float y(y) ;
>>>  float array(y, x) ;
>>> data:
>>> x = 0, 0, 0, 0 ;
>>> y = 0, 0, 0, 0 ;
>>> array =
>>> 11, 21, 31, 41,
>>> 12, 22, 32, 42,
>>> 13, 23, 33, 43,
>>> 14, 24, 34, 44 ;
>>> On Feb 23, 2009, at 5:57 AM, Alex Hoffmann wrote:
>>>> Dear Wei-keng,
>>>> below is the script section in collective data mode:
>>>> ! this should have been possible in collective data mode, but did
>>>> not seem to work !!!
>>>> !    call handle_err_nc_p(nfmpi_begin_indep_data(NCIDP),9)
>>>> !    call
>>>> handle_err_nc_p(nfmpi_put_vara_real(NCIDP,array_varIDP,(/istart,jstart/),(/nx_mpi,ny_mpi/),reshape(array,(/nx_mpi,ny_mpi/))),10)
>>>> call
>>>> handle_err_nc_p(nfmpi_put_vara_real_all(NCIDP,array_varIDP,(/istart,jstart/),(/nx_mpi,ny_mpi/),reshape(array,(/nx_mpi,ny_mpi/))),10)
>>>> !    call handle_err_nc_p(nfmpi_end_indep_data(NCIDP),11)
>>>> call handle_err_nc_p(nfmpi_close(NCIDP),12)
>>>> Basically, I replaced the independent call by the collective call for
>>>> all processes, and commented out the call into/out of independent data
>>>> mode.  This produces MPI error messages...
>>>> Cheers,
>>>> Lex
>>>>> Hi, Lex,
>>>>> Have you tried nfmpi_put_vara_real_all() in collective mode?
>>>>> Collective mode is the default mode.
>>>>> If yes, can you show me how you call it?
>>>>> Wei-keng
>>>>> On Feb 20, 2009, at 1:24 PM, Alex Hoffmann wrote:
>>>>>> Thank you for the clarifications.
>>>>>> I included the mpi setup and netCDF output test code and the
>>>>>> corresponding Makefile as attachments.  Maybe it can be of use as a
>>>>>> simple example.
>>>>>> I am currently running my code with the bugs in the output file
>>>>>> fixed,
>>>>>> and it seems to be working just fine.
>>>>>> Thanks again,
>>>>>> Lex
>>>>>>> Hi, Lex, Please read below.
>>>>>>> On Feb 20, 2009, at 5:13 AM, Alex Hoffmann wrote:
>>>>>>>> Many thanks, Wei-keng, the issue seems to have been tracked down...
>>>>>>>> For reasons that are still not completely clear to me, using
>>>>>>>> trim() for
>>>>>>>> trimming the coordinate variable names and units (lines 480/81,
>>>>>>>> 485/86)
>>>>>>>> seemed to leave a strange character (such as y diacritic or Y
>>>>>>>> accent)
>>>>>>>> trailing on e.g. the units (such as degrees_east).  Though this
>>>>>>>> did not
>>>>>>>> affect the run on its own, any subsequent attribute definition
>>>>>>>> made the
>>>>>>>> code crash.  I fixed this by removing the trim().
>>>>>>> If you called trim() on a string argument in a function, the tailing
>>>>>>> character '\0' will not be passed to the function. So if the string
>>>>>>> length
>>>>>>> argument has a larger value, the function will include undefined
>>>>>>> tailing
>>>>>>> characters as part of the string. Glad to know you solve the
>>>>>>> problem.
>>>>>>>> If I may, I'd like to clarify one further issue with PnetCDF.
>>>>>>>> I initially implemented the code (also a small test program) in
>>>>>>>> collective data mode.  This did not work (the different
>>>>>>>> processes/Cartesian sub domains) did not write their data into the
>>>>>>>> netCDF file.  I then changed the data write statements into
>>>>>>>> independent
>>>>>>>> data mode, with which it worked immediately.  Am I right to use
>>>>>>>> independent data mode for this purpose?
>>>>>>> I am not sure what you meant here.
>>>>>>> Can you post your small test program to the list?
>>>>>>> Wei-keng
>>>>>>>> Thank you very much for your support.
>>>>>>>> Cheers
>>>>>>>> Lex
>>>>>>>>> Hi, Lex,
>>>>>>>>> If this error message "NC definations on multiprocesses conflict"
>>>>>>>>> is the only one you got before every crash, it is most likely the
>>>>>>>>> attribute values are not the same across all processes.
>>>>>>>>> Please check that first, so you can rule out that possibility.
>>>>>>>>> Also, can you check the attributes in the output file for the case
>>>>>>>>> that ran successfully? (using ncmpidump -c filename) This is just
>>>>>>>>> to see if the attributes are the ones you expected. Also, please
>>>>>>>>> make sure the number of attributes created is less than 4K global
>>>>>>>>> or per variable, as Rob indicated.
>>>>>>>>> Wei-keng
>>>>>>>>> On Feb 19, 2009, at 5:53 PM, Alex Hoffmann wrote:
>>>>>>>>>> Dear Wei-keng,
>>>>>>>>>> I understand that the attribute define arguments must be the same
>>>>>>>>>> across
>>>>>>>>>> all processes.   I am also almost certain that the arguments you
>>>>>>>>>> cited
>>>>>>>>>> are identical across processes but I will perform a check.
>>>>>>>>>> Be this as it may, I get the same arrow message if I uncomment
>>>>>>>>>> one of
>>>>>>>>>> the text attributes specifying the unit or one of the real
>>>>>>>>>> attributes
>>>>>>>>>> specifying the fill value, for instance.  There is no possibility
>>>>>>>>>> that
>>>>>>>>>> these are different across processes as they are introduced
>>>>>>>>>> straight
>>>>>>>>>> into the function call.  Any check I performed seemed to indicate
>>>>>>>>>> that
>>>>>>>>>> the problem arises from the number of arguments I defined, and
>>>>>>>>>> not
>>>>>>>>>> from
>>>>>>>>>> the arguments themselves, since they work all fine individually.
>>>>>>>>>> I was actually thinking to write the attributes ad-hoc once the
>>>>>>>>>> dataset
>>>>>>>>>> is defined using regular netCDF functions.  This however
>>>>>>>>>> seemed to
>>>>>>>>>> be a
>>>>>>>>>> little elegant solution defeating the purpose of using PnetCDF.
>>>>>>>>>> Thanks,
>>>>>>>>>> Lex
>>>>>>>>>> Wei-keng Liao a écrit :
>>>>>>>>>>> Hi, Lex,
>>>>>>>>>>> PnetCDF requires the attribute define arguments be the same
>>>>>>>>>>> across
>>>>>>>>>>> all processes. This is why you got the error message for
>>>>>>>>>>> defining
>>>>>>>>>>> attribute "history" in line 400, if its value "conflicts" among
>>>>>>>>>>> processes.
>>>>>>>>>>> I think you have got this.
>>>>>>>>>>> I checked your codes. Starting from line 562, you have a few
>>>>>>>>>>> text
>>>>>>>>>>> attributes
>>>>>>>>>>> from des_tgas_picture(i), des_trac_picture(i),
>>>>>>>>>>> des_tpas_picture(i),
>>>>>>>>>>> and des.
>>>>>>>>>>> Similar for out_type == 2. Are you sure their values are all the
>>>>>>>>>>> same
>>>>>>>>>>> across
>>>>>>>>>>> all the processes? May be you can use MPI_Bcast to check if
>>>>>>>>>>> anyone has
>>>>>>>>>>> different value.
>>>>>>>>>>> Wei-keng
>>>>>>>>>>> On Feb 19, 2009, at 11:14 AM, Alex Hoffmann wrote:
>>>>>>>>>>>> Dear Rob
>>>>>>>>>>>> Thanks a lot for your answer.
>>>>>>>>>>>> Isolating the PnetCDF output module from the code as a
>>>>>>>>>>>> stand-alone
>>>>>>>>>>>> would
>>>>>>>>>>>> require a substantial effort, and I do not encounter this error
>>>>>>>>>>>> in  my
>>>>>>>>>>>> small test programs.  I attached the output module for
>>>>>>>>>>>> reference.
>>>>>>>>>>>> The attribute section that causes trouble is between lines
>>>>>>>>>>>> 369-405
>>>>>>>>>>>> (global) and 468-613 (variables).  I am aware that the
>>>>>>>>>>>> attribute
>>>>>>>>>>>> history
>>>>>>>>>>>> (line 400) may be problematic as every process may have a
>>>>>>>>>>>> slightly
>>>>>>>>>>>> different value (for the time element taken from the fortran
>>>>>>>>>>>> function
>>>>>>>>>>>> date_and_time).  Yet this is not the only issue.
>>>>>>>>>>>> If I prematurely exit at line 492, uncommenting any further
>>>>>>>>>>>> attribute
>>>>>>>>>>>> definition between 468 and 489 causes a crash with the
>>>>>>>>>>>> multiprocesses
>>>>>>>>>>>> conflict.
>>>>>>>>>>>> Note also that the attribute definitions between 558 and 613
>>>>>>>>>>>> only
>>>>>>>>>>>> produce no crash currently because of the print statements on
>>>>>>>>>>>> lines 560
>>>>>>>>>>>> and 591, which made me think that maybe there is an
>>>>>>>>>>>> optimization
>>>>>>>>>>>> problem.  What is strange is that if these are not included,
>>>>>>>>>>>> the
>>>>>>>>>>>> crash
>>>>>>>>>>>> occurs only when I start writing the first file (movie file,
>>>>>>>>>>>> out_type=2), AND if I leave the first block (if out_type==1)
>>>>>>>>>>>> uncommented, although this block is not even entered in that
>>>>>>>>>>>> particular
>>>>>>>>>>>> case, and vice versa.  Hope this is more or less clear...
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Lex
>>>>>>>>>>>> Robert Latham wrote:
>>>>>>>>>>>>> On Thu, Feb 19, 2009 at 10:09:37AM +0000, Alex Hoffmann wrote:
>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>> I am getting the same error message as had already been
>>>>>>>>>>>>>> inquired
>>>>>>>>>>>>>> on in
>>>>>>>>>>>>>> this list, i.e.:
>>>>>>>>>>>>>> NC definations on multiprocesses conflict.
>>>>>>>>>>>>>> NOTE: Definitions across all process
>>>>>>>>>>>>>> and this seems to be related somehow randomly to the total
>>>>>>>>>>>>>> number of
>>>>>>>>>>>>>> attributes (global or for each variable) that I intend to
>>>>>>>>>>>>>> write
>>>>>>>>>>>>>> during
>>>>>>>>>>>>>> the the definition phase (and, though I am not sure about
>>>>>>>>>>>>>> this, to
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> number of processes used to run my F90 parallel code).
>>>>>>>>>>>>>> More precisely, if I uncomment one put_att to replace
>>>>>>>>>>>>>> another,
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> program still runs, if I do not comment out another one, the
>>>>>>>>>>>>>> program
>>>>>>>>>>>>>> crashes with the above error message.
>>>>>>>>>>>>>> Is there any way of identifying where this problem comes from
>>>>>>>>>>>>>> or is
>>>>>>>>>>>>>> there a maximum amount of attributes (though I don't write an
>>>>>>>>>>>>>> excessive
>>>>>>>>>>>>>> amount of them)?  There is no problem running it on one
>>>>>>>>>>>>>> process(or).
>>>>>>>>>>>>> Maybe you can show us with a small test program how you are
>>>>>>>>>>>>> encountering this error?  The maximum number of attributes
>>>>>>>>>>>>> is 4k
>>>>>>>>>>>>> (the
>>>>>>>>>>>>> constant NC_MAX_ATTRS).
>>>>>>>>>>>>> ==rob
>>>>>>>>>>>> ______________________________________________________________________
>>>>>>>>>>>> Alex HOFFMANN                     PhD Candidate
>>>>>>>>>>>> Centre for Atmospheric Science
>>>>>>>>>>>> Department of Geography           University of Cambridge
>>>>>>>>>>>> Downing Place, Cambridge CB2 3EN, UK
>>>>>>>>>>>> e-mail: ah519 at cam.ac.uk  tel: +44 (0)1223 766581
>>>>>>>>>>>> www.geog.cam.ac.uk/people/hoffmann/
>>>>>>>>>>>> !-*- F90 -*-
>>>>>>>>>>>> module atham_pnetcdf
>>>>>>>>>>>> ! author:  Alex
>>>>>>>>>>>> HOFFMANN                                             !
>>>>>>>>>>>> ! email:
>>>>>>>>>>>> ah519 at cam.ac.uk                                           !
>>>>>>>>>>>> ! date:    February
>>>>>>>>>>>> 2009                                             !
>>>>>>>>>>>> ! version:
>>>>>>>>>>>> v0.1                                                      !
>>>>>>>>>>>> ! collection of routines for ATHAM PnetCDF
>>>>>>>>>>>> output                    !
>>>>>>>>>>>> ! module is to replace existing atham_netcdf.mod (GL) to write
>>>>>>>>>>>> ATHAM
>>>>>>>>>>>> output as netCDF files
>>>>>>>>>>>> ! same as atham_netcdf.mod (AH) but adapted to run with the
>>>>>>>>>>>> Parallel
>>>>>>>>>>>> NetCDF API,
>>>>>>>>>>>> !  developed by Northwestern University and Argonne National
>>>>>>>>>>>> Laboratory,
>>>>>>>>>>>> !  which is built on top of MPI-IO (tested with MPICH 2.1)
>>>>>>>>>>>> use precision,    only : kint, kreal, real4, my_real
>>>>>>>>>>>> use atham_module, only : nx, ny, nz, ntx, nty, npx, npy
>>>>>>>>>>>> use atham_module, only : ntgas_picture, ntrac_picture,
>>>>>>>>>>>> ntpas_picture, &
>>>>>>>>>>>>                  ntgas_movie, ntrac_movie, ntpas_movie
>>>>>>>>>>>> implicit none
>>>>>>>>>>>> private
>>>>>>>>>>>> public :: netcdf_data
>>>>>>>>>>>> ! 'pnetcdf.inc' file includes cpp directives that were not
>>>>>>>>>>>> understood
>>>>>>>>>>>> at compile-time
>>>>>>>>>>>> ! this is to be changed and hard-wired link to be replaced
>>>>>>>>>>>> by the
>>>>>>>>>>>> include 'pnetcdf.inc' command
>>>>>>>>>>>> !include 'pnetcdf.inc'
>>>>>>>>>>>> #include "/usr/local/parallel-netcdf-1.0.1/include/pnetcdf.inc"
>>>>>>>>>>>> include 'mpif.h'
>>>>>>>>>>>> ! ######### tried saving netCDF variable IDs here so that they
>>>>>>>>>>>> must
>>>>>>>>>>>> not be retrieved by inquiry
>>>>>>>>>>>> ! ######### if this creates conflict, especially between
>>>>>>>>>>>> picture
>>>>>>>>>>>> and
>>>>>>>>>>>> movie file, this must be changed
>>>>>>>>>>>> integer(kint), save                   :: x_dimID, y_dimID,
>>>>>>>>>>>> z_dimID, t_dimID
>>>>>>>>>>>> integer(kint), save                   :: x_varID, y_varID,
>>>>>>>>>>>> z_varID, t_varID
>>>>>>>>>>>> integer(kint), save                   :: u_varID, v_varID,
>>>>>>>>>>>> w_varID
>>>>>>>>>>>> integer(kint), save                   :: pnew_varID,
>>>>>>>>>>>> tetnew_varID,
>>>>>>>>>>>> tempnew_varID, density_varID
>>>>>>>>>>>> integer(kint), save                   :: turbhor_varID,
>>>>>>>>>>>> turbver_varID, turblen_varID
>>>>>>>>>>>> integer(kint), dimension(99), save    :: tgas_varID,
>>>>>>>>>>>> trac_varID,
>>>>>>>>>>>> tpas_varID, d_trac_varID
>>>>>>>>>>>> integer(MPI_OFFSET_KIND), save        :: tcounter
>>>>>>>>>>>> real(real4), parameter                :: undef =
>>>>>>>>>>>> -0.99e33_real4 !
>>>>>>>>>>>> make sure precision of _FillValue and output (NF90_FLOAT) is
>>>>>>>>>>>> the
>>>>>>>>>>>> same
>>>>>>>>>>>> contains
>>>>>>>>>>>> subroutine netcdf_data(outfile,out_type,timetot)
>>>>>>>>>>>> ! IF: outfile = picture_file or movie_file (path/filename for
>>>>>>>>>>>> output created in atham_module)
>>>>>>>>>>>> !     out_type = 1 (picture_file) or 2 (movie_file)
>>>>>>>>>>>> !     timetot = total simulation time since simulation start
>>>>>>>>>>>> use atham_module, only : unew, vnew, wnew, pnew, tetnew,
>>>>>>>>>>>> tempnew, &
>>>>>>>>>>>>                      density, turbhor, turbver, turblen
>>>>>>>>>>>> use atham_module, only : tgasnew, tracnew, tpasnew, tracdep
>>>>>>>>>>>> use atham_module, only : itgas_picture, itrac_picture,
>>>>>>>>>>>> itpas_picture, &
>>>>>>>>>>>>                      itgas_movie, itrac_movie, itpas_movie
>>>>>>>>>>>> use atham_module, only : mycoor, my_cart, myrank
>>>>>>>>>>>> character(*),           intent(in   ) :: outfile
>>>>>>>>>>>> integer(kint),          intent(in   ) :: out_type
>>>>>>>>>>>> real(kreal),            intent(in   ) :: timetot
>>>>>>>>>>>> ! local
>>>>>>>>>>>> variables                                                  !
>>>>>>>>>>>> integer(MPI_OFFSET_KIND)              :: nx_mpi,ny_mpi, nz_mpi,
>>>>>>>>>>>> y_cl_mpi
>>>>>>>>>>>> integer(MPI_OFFSET_KIND)              :: istart,jstart
>>>>>>>>>>>> integer(kint)                         :: STATUS
>>>>>>>>>>>> character(len=50)                     :: OP  ! debugging
>>>>>>>>>>>> variable
>>>>>>>>>>>> corresponding to the called netCDF OPeration
>>>>>>>>>>>> integer(kint)                         :: NCID
>>>>>>>>>>>> integer(kint)                         :: i
>>>>>>>>>>>> logical                               :: DynMovie_flag,
>>>>>>>>>>>> bounds_control
>>>>>>>>>>>> integer(kint)                         :: y_st, y_sp, y_cl
>>>>>>>>>>>> ! replace DynMovie precompiler flag by program flag for more
>>>>>>>>>>>> convenient code structure
>>>>>>>>>>>> DynMovie_flag = .false.
>>>>>>>>>>>> #ifdef DynMovie
>>>>>>>>>>>> DynMovie_flag = .true.
>>>>>>>>>>>> #endif
>>>>>>>>>>>> ! re-assign dimension lengths as an MPI_Offset type (necessary
>>>>>>>>>>>> for
>>>>>>>>>>>> the PnetCDF interface)
>>>>>>>>>>>> ! cut-off subdomain borders
>>>>>>>>>>>> nx_mpi  = nx-2
>>>>>>>>>>>> ny_mpi  = ny-2
>>>>>>>>>>>> nz_mpi  = nz
>>>>>>>>>>>> ! assign coordinates of first element of each process in the
>>>>>>>>>>>> netCDF file
>>>>>>>>>>>> istart = mycoor(1)*nx_mpi + 1_MPI_OFFSET_KIND
>>>>>>>>>>>> jstart = mycoor(2)*ny_mpi + 1_MPI_OFFSET_KIND
>>>>>>>>>>>> bounds_control = .true. ! debugging flag
>>>>>>>>>>>> tcounter = tcounter+1_MPI_OFFSET_KIND
>>>>>>>>>>>> ! === open netCDF dataset: enter data mode
>>>>>>>>>>>> ! if     dataset does not yet exist (STATUS =  ), create
>>>>>>>>>>>> file and
>>>>>>>>>>>> enter data mode
>>>>>>>>>>>> ! else   continue
>>>>>>>>>>>> OP = 'open existing netCDF file'
>>>>>>>>>>>> STATUS = nfmpi_open(my_cart, trim(outfile), NF_WRITE,
>>>>>>>>>>>> MPI_INFO_NULL, NCID)
>>>>>>>>>>>> if ( STATUS /= nf_noerr ) then
>>>>>>>>>>>> if (myrank==0) then
>>>>>>>>>>>>   print *, ""
>>>>>>>>>>>>   print *, "P-NetCDF operation: ",trim(OP)
>>>>>>>>>>>>   print *, trim(nfmpi_strerror(STATUS))
>>>>>>>>>>>>   print *, "atham_pnetcdf netcdf_data(): new netCDF file
>>>>>>>>>>>> created: ", outfile
>>>>>>>>>>>>   print *, ""
>>>>>>>>>>>> end if
>>>>>>>>>>>> call netcdf_define(outfile,out_type,timetot,NCID)
>>>>>>>>>>>> tcounter = 1_MPI_OFFSET_KIND ! reset time counter for output if
>>>>>>>>>>>> new file is created
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! ---                        write data values
>>>>>>>>>>>> ! unlimited record dimension time (only one process writes the
>>>>>>>>>>>> whole dimension, i.e. accross all processes)
>>>>>>>>>>>> OP = 'write data values - unlimited dimension t'
>>>>>>>>>>>> call handle_err(nfmpi_begin_indep_data(NCID))
>>>>>>>>>>>> if (myrank==0) then
>>>>>>>>>>>> call handle_err(nfmpi_put_vara_real(NCID, t_varID,
>>>>>>>>>>>> (/tcounter/), (/1_MPI_OFFSET_KIND/), real(timetot,real4)),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> call handle_err(nfmpi_end_indep_data(NCID))
>>>>>>>>>>>> ! discriminate between 2D and 3D case for output generation
>>>>>>>>>>>> if (nty>4) then
>>>>>>>>>>>> y_st = 2    ! y index start
>>>>>>>>>>>> y_sp = ny-1 ! y index stop
>>>>>>>>>>>> y_cl = ny-2 ! y number of columns
>>>>>>>>>>>> else
>>>>>>>>>>>> y_st = ny-1 ! 3 in 2D case
>>>>>>>>>>>> y_sp = ny-1 ! 3 in 2D case
>>>>>>>>>>>> y_cl = 1
>>>>>>>>>>>> end if
>>>>>>>>>>>> y_cl_mpi = y_cl
>>>>>>>>>>>> ! dynamics data
>>>>>>>>>>>> OP = 'write data values - data'
>>>>>>>>>>>> if (out_type == 1 .OR. DynMovie_flag == .true.) then
>>>>>>>>>>>> call write_data(real(unew,real4),u_varID)
>>>>>>>>>>>> bounds_control = .false.
>>>>>>>>>>>> call write_data(real(vnew,   real4),v_varID)
>>>>>>>>>>>> call write_data(real(wnew,   real4),w_varID)
>>>>>>>>>>>> call write_data(real(pnew,   real4),pnew_varID)
>>>>>>>>>>>> call write_data(real(tetnew, real4),tetnew_varID)
>>>>>>>>>>>> call write_data(real(tempnew,real4),tempnew_varID)
>>>>>>>>>>>> call write_data(real(density,real4),density_varID)
>>>>>>>>>>>> call write_data(real(turbhor,real4),turbhor_varID)
>>>>>>>>>>>> call write_data(real(turbver,real4),turbver_varID)
>>>>>>>>>>>> call write_data(real(turblen,real4),turblen_varID)
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! tracer data
>>>>>>>>>>>> if (out_type == 1) then
>>>>>>>>>>>> do i=1,ntgas_picture
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tgasnew(:,:,:,itgas_picture(i)),real4),tgas_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntrac_picture
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tracnew(:,:,:,itrac_picture(i)),real4),trac_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntpas_picture
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tpasnew(:,:,:,itpas_picture(i)),real4),tpas_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> d_trac_varID(i),(/istart,jstart,tcounter/), &
>>>>>>>>>>>>        (/nx_mpi,y_cl_mpi,1_MPI_OFFSET_KIND/),
>>>>>>>>>>>> real(reshape(tracdep(2:nx-1,y_st:y_sp,itrac_picture(i)),shape=(/nx-2,y_cl,1/)),real4)
>>>>>>>>>>>> ),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> else if (out_type == 2) then
>>>>>>>>>>>> do i=1,ntgas_movie
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tgasnew(:,:,:,itgas_movie(i)),real4),tgas_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntrac_movie
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tracnew(:,:,:,itrac_movie(i)),real4),trac_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntpas_movie
>>>>>>>>>>>>   call
>>>>>>>>>>>> write_data(real(tpasnew(:,:,:,itpas_movie(i)),real4),tpas_varID(i))
>>>>>>>>>>>> enddo
>>>>>>>>>>>> endif
>>>>>>>>>>>> ! === close netCDF dataset: exit data mode & save
>>>>>>>>>>>> OP = 'close netCDF file'
>>>>>>>>>>>> call handle_err(nfmpi_close(NCID))
>>>>>>>>>>>> if (myrank==0) then
>>>>>>>>>>>> print *, ''
>>>>>>>>>>>> print *, 'wrote netCDF output to file ', outfile
>>>>>>>>>>>> print *, ''
>>>>>>>>>>>> end if
>>>>>>>>>>>> contains
>>>>>>>>>>>> subroutine write_data(array_in,varID)
>>>>>>>>>>>> ! IF: array_in = data array (3D) to be written to netCDF
>>>>>>>>>>>> !     varID    = data variable netCDF ID
>>>>>>>>>>>> use atham_module, only : iflgs ! topography mask: topography
>>>>>>>>>>>> (iflgs=0) remains undef
>>>>>>>>>>>> use atham_module, only  : myrank
>>>>>>>>>>>> real(real4),dimension(nx,ny,nz), intent (in   )   :: array_in
>>>>>>>>>>>> integer(kint),                intent(in   )       :: varID
>>>>>>>>>>>> ! local
>>>>>>>>>>>> variables                                              !
>>>>>>>>>>>> real(real4), dimension(nx,ny,nz)            :: array_masked
>>>>>>>>>>>> ! dimensions & bounds control
>>>>>>>>>>>> integer(MPI_OFFSET_KIND)                    :: dimlenx,
>>>>>>>>>>>> dimleny, dimlenz, dimlent
>>>>>>>>>>>> integer(kint), dimension(NF_max_var_dims)   :: dimIDs
>>>>>>>>>>>> if (myrank == 0) then
>>>>>>>>>>>>    if (bounds_control) then
>>>>>>>>>>>>       print *, ''
>>>>>>>>>>>>       print *, 'atham var in xyz
>>>>>>>>>>>> ',shape(array_in)
>>>>>>>>>>>>       print *, 'atham var reshaped to xyzt
>>>>>>>>>>>> ',shape(reshape(array_in(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/)))
>>>>>>>>>>>>       call handle_err(nfmpi_inq_vardimid(NCID, u_varID,
>>>>>>>>>>>> dimIDs)) ! taken unew as ref
>>>>>>>>>>>>       call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(1),
>>>>>>>>>>>> dimlenx))
>>>>>>>>>>>>       call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(2),
>>>>>>>>>>>> dimleny))
>>>>>>>>>>>>       call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(3),
>>>>>>>>>>>> dimlenz))
>>>>>>>>>>>>       call handle_err(nfmpi_inq_dimlen(NCID, dimIDs(4),
>>>>>>>>>>>> dimlent))
>>>>>>>>>>>>       print *, 'netCDF var dimensions in xyzt
>>>>>>>>>>>> ',dimlenx,dimleny,dimlenz,dimlent
>>>>>>>>>>>>    end if
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! mask topography
>>>>>>>>>>>> where (iflgs == 1)
>>>>>>>>>>>>    array_masked = array_in
>>>>>>>>>>>> elsewhere
>>>>>>>>>>>>    array_masked = undef
>>>>>>>>>>>> endwhere
>>>>>>>>>>>> ! mask control
>>>>>>>>>>>> !print *, ''
>>>>>>>>>>>> !print *, 'topography mask'
>>>>>>>>>>>> !print *, iflgs(1:5,3,3)
>>>>>>>>>>>> !print *, iflgs(1:5,3,2)
>>>>>>>>>>>> !print *, iflgs(1:5,3,1)
>>>>>>>>>>>> !print *, ''
>>>>>>>>>>>> !print *, 'masked variable array'
>>>>>>>>>>>> !print *, array_masked(:,3,3)
>>>>>>>>>>>> !print *, array_masked(:,3,2)
>>>>>>>>>>>> !print *, array_masked(:,3,1)
>>>>>>>>>>>> !print *, ''
>>>>>>>>>>>> varID,(/istart,jstart,1_MPI_OFFSET_KIND,tcounter/), &
>>>>>>>>>>>>      (/nx_mpi,y_cl_mpi,nz_mpi,1_MPI_OFFSET_KIND/),
>>>>>>>>>>>> reshape(array_masked(2:nx-1,y_st:y_sp,1:nz),shape=(/nx-2,y_cl,nz,1/))
>>>>>>>>>>>> ),OP)
>>>>>>>>>>>> end subroutine write_data
>>>>>>>>>>>> end subroutine netcdf_data
>>>>>>>>>>>> subroutine netcdf_define(outfile,out_type,timetot,ncid_def)
>>>>>>>>>>>> !     timetot = simulation time since simulation start (from
>>>>>>>>>>>> atham/atham_out)
>>>>>>>>>>>> !     ncid_def = netCDF ID assigned to file during creation
>>>>>>>>>>>> use atham_module, only   : var_tgas_picture,
>>>>>>>>>>>> var_tgas_movie,           &
>>>>>>>>>>>>                        des_tgas_picture,
>>>>>>>>>>>> des_tgas_movie,           &
>>>>>>>>>>>>                        var_trac_picture,
>>>>>>>>>>>> var_trac_movie,           &
>>>>>>>>>>>>                        des_trac_picture,
>>>>>>>>>>>> des_trac_movie,           &
>>>>>>>>>>>>                        var_tpas_picture,
>>>>>>>>>>>> var_tpas_movie,           &
>>>>>>>>>>>>                        des_tpas_picture, des_tpas_movie
>>>>>>>>>>>> use atham_module, only   : iindex, spinup, nrep, periodt
>>>>>>>>>>>> use atham_module, only   : volcano_setup,
>>>>>>>>>>>> coignimbrite_setup,          &
>>>>>>>>>>>>                        nuclear_setup, convection_setup,
>>>>>>>>>>>> procsconfig_setup
>>>>>>>>>>>> use atham_module, only   : x, y, z, xg, yg
>>>>>>>>>>>> use atham_module, only   : grid2geo, sim_d_YYYY, sim_d_MM,
>>>>>>>>>>>> sim_d_DD,   &
>>>>>>>>>>>>                        sim_t_hh, sim_t_mm, sim_t_ss
>>>>>>>>>>>> use atham_module, only   : my_cart, myrank
>>>>>>>>>>>> integer(kint),          intent(  out) :: ncid_def
>>>>>>>>>>>> ! local
>>>>>>>>>>>> variables                                                  !
>>>>>>>>>>>> integer(MPI_OFFSET_KIND)              :: ntx_mpi,nty_mpi,nz_mpi
>>>>>>>>>>>> variable
>>>>>>>>>>>> integer(kint)                         :: i
>>>>>>>>>>>> character(len=50)                     :: var, des
>>>>>>>>>>>> real(kreal)                           :: toffset
>>>>>>>>>>>> real(real4)                           :: coord_scale,
>>>>>>>>>>>> coord_x_offset, coord_y_offset, coord_t_offset
>>>>>>>>>>>> character(len=3)                      :: coord_x_name,
>>>>>>>>>>>> coord_y_name, coord_z_name
>>>>>>>>>>>> character(len=4)                      :: coord_t_name
>>>>>>>>>>>> character(len=9)                      :: coord_x_lname,
>>>>>>>>>>>> coord_y_lname
>>>>>>>>>>>> character(len=13)                     :: coord_x_units,
>>>>>>>>>>>> coord_y_units
>>>>>>>>>>>> character(len=33)                     :: coord_t_units
>>>>>>>>>>>> character(len=8)                      :: date
>>>>>>>>>>>> character(len=10)                     :: time
>>>>>>>>>>>> character(len=19)                     :: simdatetime
>>>>>>>>>>>> character(len=10)                     :: simdate
>>>>>>>>>>>> character(len=20)                     :: login
>>>>>>>>>>>> character(len=63)                     :: hist_string
>>>>>>>>>>>> integer(kint)                         :: isetup
>>>>>>>>>>>> character(len=12)                     :: model_setup(6)
>>>>>>>>>>>> data model_setup /'volcano     ', 'coignimbrite',
>>>>>>>>>>>> 'nuclear     ',
>>>>>>>>>>>> 'convection  ', 'procsconfig ','unknown     '/
>>>>>>>>>>>> #ifdef DynMovie
>>>>>>>>>>>> #endif
>>>>>>>>>>>> for
>>>>>>>>>>>> ! cut-off domain borders
>>>>>>>>>>>> ntx_mpi = ntx-2
>>>>>>>>>>>> nty_mpi = nty-2
>>>>>>>>>>>> nz_mpi  = nz
>>>>>>>>>>>> ! convert date and time integers into string 'YYYYMMDD
>>>>>>>>>>>> hh:mm:ss'
>>>>>>>>>>>> write (simdatetime,10)
>>>>>>>>>>>> sim_d_YYYY,sim_d_MM,sim_d_DD,sim_t_hh,sim_t_mm,sim_t_ss
>>>>>>>>>>>> 10 format (I4,'-',I2,'-',I2,1X,I2,':',I2,':',I2)
>>>>>>>>>>>> simdate = simdatetime(1:10)
>>>>>>>>>>>> ! switch between cartesian axes/time (default) and geographic
>>>>>>>>>>>> axes/date (linear approx)
>>>>>>>>>>>> coord_scale    = 1._real4
>>>>>>>>>>>> coord_x_offset = 0._real4
>>>>>>>>>>>> coord_x_name   = 'x  '
>>>>>>>>>>>> coord_x_lname  = 'x_coor   '
>>>>>>>>>>>> coord_x_units  = 'm            '
>>>>>>>>>>>> coord_y_offset = 0._real4
>>>>>>>>>>>> coord_y_name   = 'y  '
>>>>>>>>>>>> coord_y_lname  = 'y_coor   '
>>>>>>>>>>>> coord_y_units  = 'm            '
>>>>>>>>>>>> coord_z_name   = 'z  '
>>>>>>>>>>>> coord_t_offset = 0._real4
>>>>>>>>>>>> coord_t_name   = 'time'
>>>>>>>>>>>> coord_t_units  = 'sec                              '
>>>>>>>>>>>> if (grid2geo) then
>>>>>>>>>>>> call
>>>>>>>>>>>> gridconvert(coord_scale,coord_x_offset,coord_x_name,coord_x_lname,coord_x_units,
>>>>>>>>>>>> coord_y_offset,coord_y_name,coord_y_lname,coord_y_units, &
>>>>>>>>>>>> coord_z_name,coord_t_offset,coord_t_name,coord_t_units)
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! === create netCDF dataset: enter define mode
>>>>>>>>>>>> OP = 'enter define mode'
>>>>>>>>>>>> call handle_err(nfmpi_create(my_cart, trim(outfile), 0,
>>>>>>>>>>>> MPI_INFO_NULL,NCID),OP)
>>>>>>>>>>>> ncid_def = NCID
>>>>>>>>>>>> ! === create netCDF dataset: assign metadata
>>>>>>>>>>>> ! ---                        set global attributes
>>>>>>>>>>>> OP = 'set global attributes'
>>>>>>>>>>>> toffset = timetot - spinup
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'title',
>>>>>>>>>>>> 13_MPI_OFFSET_KIND, 'atham_picture'),OP)
>>>>>>>>>>>> else
>>>>>>>>>>>> toffset = timetot - spinup - nrep*periodt
>>>>>>>>>>>> 11_MPI_OFFSET_KIND, 'atham_movie'),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'content',
>>>>>>>>>>>> 223_MPI_OFFSET_KIND, &
>>>>>>>>>>>>  'This data corresponds to a simulation run of the
>>>>>>>>>>>> mesoscale-beta/gamma type non-hydrostatic Active Tracer
>>>>>>>>>>>> High-resolution Atmospheric Model ATHAM ' &
>>>>>>>>>>>>  // '(Oberhuber et al., 1998, Herzog, 1998), for a setup as
>>>>>>>>>>>> specified under history'),OP) ! ######### add further
>>>>>>>>>>>> description as
>>>>>>>>>>>> necessary
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL, 'version',
>>>>>>>>>>>> 21_MPI_OFFSET_KIND, 'no current versioning'),OP) ! #########
>>>>>>>>>>>> change
>>>>>>>>>>>> once available
>>>>>>>>>>>> call date_and_time(date, time)
>>>>>>>>>>>> call getlog(login)
>>>>>>>>>>>> if (volcano_setup) then
>>>>>>>>>>>> isetup=1
>>>>>>>>>>>> else if (coignimbrite_setup) then
>>>>>>>>>>>> isetup=2
>>>>>>>>>>>> else if (nuclear_setup) then
>>>>>>>>>>>> isetup=3
>>>>>>>>>>>> else if (convection_setup) then
>>>>>>>>>>>> isetup=4
>>>>>>>>>>>> else if (procsconfig_setup) then
>>>>>>>>>>>> isetup=5
>>>>>>>>>>>> else
>>>>>>>>>>>> isetup=6
>>>>>>>>>>>> end if
>>>>>>>>>>>> hist_string = trim(date//' '//time//'  '//trim(login)//'  atham
>>>>>>>>>>>> '//model_setup(isetup))
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_text(NCID, NF_GLOBAL,
>>>>>>>>>>>> 'history',
>>>>>>>>>>>> 63_MPI_OFFSET_KIND, hist_string),OP) ! 1 line/modification:  -
>>>>>>>>>>>> cmd
>>>>>>>>>>>> arg
>>>>>>>>>>>> 'Conventions', 28_MPI_OFFSET_KIND, 'COARDS,
>>>>>>>>>>>> //cf-pcmdi.llnl.gov/'),OP)
>>>>>>>>>>>> 'sim_onset_date_time', 19_MPI_OFFSET_KIND, simdatetime),OP)
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, NF_GLOBAL,
>>>>>>>>>>>> 'sim_time_offset', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>>>>>>>>> real(toffset,real4)),OP)
>>>>>>>>>>>> 'x_zoom_location', NF_FLOAT, 1_MPI_OFFSET_KIND,
>>>>>>>>>>>> real(x(max(1,iindex)),real4)),OP)
>>>>>>>>>>>> ! ---                        define dimensions
>>>>>>>>>>>> OP = 'define dimensions'
>>>>>>>>>>>> call handle_err(nfmpi_def_dim(NCID, trim(coord_x_name),
>>>>>>>>>>>> ntx_mpi,             x_dimID),OP)
>>>>>>>>>>>> if (nty>4) then
>>>>>>>>>>>> call handle_err(nfmpi_def_dim(NCID, trim(coord_y_name),
>>>>>>>>>>>> nty_mpi,             y_dimID),OP)
>>>>>>>>>>>> else
>>>>>>>>>>>> 1_MPI_OFFSET_KIND,   y_dimID),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> call handle_err(nfmpi_def_dim(NCID, trim(coord_z_name),
>>>>>>>>>>>> nz_mpi,              z_dimID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_dim(NCID, coord_t_name,
>>>>>>>>>>>> nfmpi_unlimited,     t_dimID),OP)
>>>>>>>>>>>> ! ---                        define variables
>>>>>>>>>>>> ! dimensions
>>>>>>>>>>>> OP = 'define variables - dimensions'
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, trim(coord_x_name),
>>>>>>>>>>>> NF_FLOAT, 1, x_dimID, x_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, trim(coord_y_name),
>>>>>>>>>>>> NF_FLOAT, 1, y_dimID, y_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, trim(coord_z_name),
>>>>>>>>>>>> NF_FLOAT, 1, z_dimID, z_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, coord_t_name,
>>>>>>>>>>>> NF_FLOAT, 1, t_dimID, t_varID),OP)
>>>>>>>>>>>> ! dynamics data
>>>>>>>>>>>> OP = 'define variables - data'
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'u',       NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), u_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'v',       NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), v_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'w',       NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), w_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'pnew',    NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), pnew_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'tetnew',  NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tetnew_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'tempnew', NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), tempnew_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'density', NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), density_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'turbhor', NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbhor_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'turbver', NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turbver_varID),OP)
>>>>>>>>>>>> call handle_err(nfmpi_def_var(NCID, 'turblen', NF_FLOAT, 4,
>>>>>>>>>>>> (/x_dimID,y_dimID,z_dimID,t_dimID/), turblen_varID),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! tracer data
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_tgas_picture(i),
>>>>>>>>>>>> NF_FLOAT, 4, (/x_dimID,y_dimID,z_dimID,t_dimID/),
>>>>>>>>>>>> tgas_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_trac_picture(i),
>>>>>>>>>>>> trac_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_tpas_picture(i),
>>>>>>>>>>>> tpas_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   var='d_'//trim(var_trac_picture(i))
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var,
>>>>>>>>>>>> NF_FLOAT, 3, (/x_dimID,y_dimID,t_dimID/), d_trac_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntgas_movie
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_tgas_movie(i),
>>>>>>>>>>>> tgas_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntrac_movie
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_trac_movie(i),
>>>>>>>>>>>> trac_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntpas_movie
>>>>>>>>>>>>   call handle_err(nfmpi_def_var(NCID, var_tpas_movie(i),
>>>>>>>>>>>> tpas_varID(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> endif
>>>>>>>>>>>> ! ---                        assign attributes
>>>>>>>>>>>> ! common attributes: long_name, units, valid_range,
>>>>>>>>>>>> scale_factor,
>>>>>>>>>>>> add_offset, _FillValue, history, conventions
>>>>>>>>>>>> ! dimensions
>>>>>>>>>>>> OP = 'assign attributes - dimensions'
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, x_varID,
>>>>>>>>>>>> 'long_name',               9_MPI_OFFSET_KIND,
>>>>>>>>>>>> trim(coord_x_lname)),OP)
>>>>>>>>>>>> 'units',                  13_MPI_OFFSET_KIND,
>>>>>>>>>>>> trim(coord_x_units)),OP)
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, x_varID,
>>>>>>>>>>>> 'scale_factor', NF_FLOAT,  1_MPI_OFFSET_KIND, coord_scale),OP)
>>>>>>>>>>>> 'add_offset',   NF_FLOAT,  1_MPI_OFFSET_KIND,
>>>>>>>>>>>> coord_x_offset),OP)
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, y_varID,
>>>>>>>>>>>> trim(coord_y_lname)),OP)
>>>>>>>>>>>> trim(coord_y_units)),OP)
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, y_varID,
>>>>>>>>>>>> coord_y_offset),OP)
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>>>>>>>>> 'long_name',               6_MPI_OFFSET_KIND, 'height'),OP)
>>>>>>>>>>>> 'units',                   1_MPI_OFFSET_KIND, 'm'),OP)
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_text(NCID, z_varID,
>>>>>>>>>>>> 'positive',                2_MPI_OFFSET_KIND, 'up'),OP)
>>>>>>>>>>>> call handle_err(nfmpi_put_att_text(NCID, t_varID,
>>>>>>>>>>>> 'long_name',               4_MPI_OFFSET_KIND, coord_t_name),OP)
>>>>>>>>>>>> 'units',                  33_MPI_OFFSET_KIND,
>>>>>>>>>>>> trim(coord_t_units)),OP)
>>>>>>>>>>>> !    call handle_err(nfmpi_put_att_real(NCID, t_varID,
>>>>>>>>>>>> coord_t_offset),OP)
>>>>>>>>>>>> !    OP = 'exit define mode NOW for testing
>>>>>>>>>>>> ah_testing
>>>>>>>>>>>> !    call
>>>>>>>>>>>> handle_err(nfmpi_enddef(NCID),OP)
>>>>>>>>>>>> ! ah_testing ********************************
>>>>>>>>>>>> ! dynamics data
>>>>>>>>>>>> OP = 'assign attributes - data'
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, u_varID,
>>>>>>>>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'x_wind'),OP)
>>>>>>>>>>>> 'units',                  7_MPI_OFFSET_KIND, 'm sec-1'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, u_varID,
>>>>>>>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1.),OP)
>>>>>>>>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, 0.0),OP)
>>>>>>>>>>>> '_FillValue',  NF_FLOAT,  1_MPI_OFFSET_KIND, undef),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, v_varID,
>>>>>>>>>>>> 'long_name',              6_MPI_OFFSET_KIND, 'y_wind'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, v_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, w_varID,
>>>>>>>>>>>> 'long_name',             19_MPI_OFFSET_KIND,
>>>>>>>>>>>> 'upward_air_velocity'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, w_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, pnew_varID,
>>>>>>>>>>>> 'long_name',             20_MPI_OFFSET_KIND,
>>>>>>>>>>>> 'air_pressure_anomaly'),OP)
>>>>>>>>>>>> 'units',                  2_MPI_OFFSET_KIND, 'Pa'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, pnew_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tetnew_varID,
>>>>>>>>>>>> 'long_name',             25_MPI_OFFSET_KIND,
>>>>>>>>>>>> 'air_potential_temperature'),OP)
>>>>>>>>>>>> 'units',                  1_MPI_OFFSET_KIND, 'K'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tetnew_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, tempnew_varID,
>>>>>>>>>>>> 'long_name',             15_MPI_OFFSET_KIND,
>>>>>>>>>>>> 'air_temperature'),OP)
>>>>>>>>>>>> 'units',                  7_MPI_OFFSET_KIND, 'Celsius'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, tempnew_varID,
>>>>>>>>>>>> 'add_offset',  NF_FLOAT,  1_MPI_OFFSET_KIND, -273.15),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, density_varID,
>>>>>>>>>>>> 'long_name',             11_MPI_OFFSET_KIND, 'air_density'),OP)
>>>>>>>>>>>> 'units',                  6_MPI_OFFSET_KIND, 'kg m-3'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, density_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbhor_varID,
>>>>>>>>>>>> 'hor_turb_energy'),OP)
>>>>>>>>>>>> 'units',                  8_MPI_OFFSET_KIND, 'm2 sec-2'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbhor_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turbver_varID,
>>>>>>>>>>>> 'ver_turb_energy'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turbver_varID,
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_text(NCID, turblen_varID,
>>>>>>>>>>>> 'long_name',             17_MPI_OFFSET_KIND,
>>>>>>>>>>>> 'turb_length_scale'),OP)
>>>>>>>>>>>> !       call handle_err(nfmpi_put_att_real(NCID, turblen_varID,
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! tracer data
>>>>>>>>>>>> print *, 'NetCDF output type (1-picture,2-movie) ',out_type !
>>>>>>>>>>>> #####  DO NOT REMOVE!!! optimization problem, trace source
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_text(NCID, tgas_varID(i),
>>>>>>>>>>>> des_tgas_picture(i)),OP)
>>>>>>>>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram kg-1'),OP)
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_real(NCID, tgas_varID(i),
>>>>>>>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 1000.),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_text(NCID, trac_varID(i),
>>>>>>>>>>>> des_trac_picture(i)),OP)
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_real(NCID, trac_varID(i),
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_text(NCID, tpas_varID(i),
>>>>>>>>>>>> des_tpas_picture(i)),OP)
>>>>>>>>>>>> 'units',                  1_MPI_OFFSET_KIND, '%'),OP)
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_real(NCID, tpas_varID(i),
>>>>>>>>>>>> 'scale_factor',NF_FLOAT,  1_MPI_OFFSET_KIND, 100.),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>>   des='deposited_'//trim(des_trac_picture(i))
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_text(NCID, d_trac_varID(i),
>>>>>>>>>>>> 'long_name',             35_MPI_OFFSET_KIND, des),OP)
>>>>>>>>>>>> 'units',                  9_MPI_OFFSET_KIND, 'gram m-2'),OP)
>>>>>>>>>>>>   call handle_err(nfmpi_put_att_real(NCID, d_trac_varID(i),
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntgas_movie
>>>>>>>>>>>> des_tgas_movie(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntrac_movie
>>>>>>>>>>>> des_trac_movie(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> do i=1,ntpas_movie
>>>>>>>>>>>> des_tpas_movie(i)),OP)
>>>>>>>>>>>> enddo
>>>>>>>>>>>> end if
>>>>>>>>>>>> ! === create netCDF dataset: exit define mode, enter data mode
>>>>>>>>>>>> OP = 'exit define mode'
>>>>>>>>>>>> call handle_err(nfmpi_enddef(NCID),OP)
>>>>>>>>>>>> ! dimensions (only one process writes the whole dimension, i.e.
>>>>>>>>>>>> OP = 'write data values - dimensions'
>>>>>>>>>>>> if (myrank==0) then
>>>>>>>>>>>> call handle_err(nfmpi_put_vara_real(NCID, x_varID,
>>>>>>>>>>>> (/1_MPI_OFFSET_KIND/), (/ntx_mpi/),real(xg(2:ntx-1),real4)),OP)
>>>>>>>>>>>> if (nty>4) then
>>>>>>>>>>>>   call handle_err(nfmpi_put_vara_real(NCID, y_varID,
>>>>>>>>>>>> (/1_MPI_OFFSET_KIND/), (/nty_mpi/),
>>>>>>>>>>>> real(yg(2:nty-1),real4)),OP)
>>>>>>>>>>>> else
>>>>>>>>>>>> (/1_MPI_OFFSET_KIND/), (/1_MPI_OFFSET_KIND/),
>>>>>>>>>>>> real(yg(nty-1),real4)),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> call handle_err(nfmpi_put_vara_real(NCID, z_varID,
>>>>>>>>>>>> (/1_MPI_OFFSET_KIND/), (/nz_mpi/), real(z,real4)),OP)
>>>>>>>>>>>> end if
>>>>>>>>>>>> contains
>>>>>>>>>>>> subroutine
>>>>>>>>>>>> gridconvert(cd_scale,cd_x_offset,cd_x_name,cd_x_lname,cd_x_units,
>>>>>>>>>>>> cd_y_offset,cd_y_name,cd_y_lname,cd_y_units, &
>>>>>>>>>>>> cd_z_name,cd_t_offset,cd_t_name,cd_t_units)
>>>>>>>>>>>> ! IF: cd_* = coordinate parameters
>>>>>>>>>>>> ! linear conversion from cartesian grid into lon/lat
>>>>>>>>>>>> system    !
>>>>>>>>>>>> ! only valid as first approxiamtion over small
>>>>>>>>>>>> domains         !
>>>>>>>>>>>> ! to be replaced once a dyn core in a lat/lon system
>>>>>>>>>>>> available !
>>>>>>>>>>>> use atham_module, only             : deglat_start,
>>>>>>>>>>>> deglon_start
>>>>>>>>>>>> use phys_constants, only           : pi
>>>>>>>>>>>> real(real4),        intent(inout) :: cd_scale, cd_x_offset,
>>>>>>>>>>>> cd_y_offset, cd_t_offset
>>>>>>>>>>>> character(len=3),   intent(inout) :: cd_x_name, cd_y_name,
>>>>>>>>>>>> cd_z_name
>>>>>>>>>>>> character(len=4),   intent(inout) :: cd_t_name
>>>>>>>>>>>> character(len=9),   intent(inout) :: cd_x_lname, cd_y_lname
>>>>>>>>>>>> character(len=13),  intent(inout) :: cd_x_units, cd_y_units
>>>>>>>>>>>> character(len=33),  intent(inout) :: cd_t_units
>>>>>>>>>>>> ! local
>>>>>>>>>>>> variables                                              !
>>>>>>>>>>>> real(kreal)                       :: r
>>>>>>>>>>>> real(kreal), parameter            :: a = 6378137._kreal     !
>>>>>>>>>>>> (WGS 84)
>>>>>>>>>>>> real(kreal), parameter            :: b = 6356752.3142_kreal !
>>>>>>>>>>>> (WGS 84)
>>>>>>>>>>>> ! ellipsoid radius at ATHAM domain start
>>>>>>>>>>>> r = a*b / sqrt((b*b*(cos(deglat_start*pi/180._kreal))**2
>>>>>>>>>>>> )+(a*a*(sin(deglat_start*pi/180._kreal))**2 ))
>>>>>>>>>>>> cd_scale    = real((1/r) * (180._kreal/pi),real4)
>>>>>>>>>>>> cd_x_offset = deglon_start
>>>>>>>>>>>> cd_x_name   = 'lon'
>>>>>>>>>>>> cd_x_lname  = 'longitude'
>>>>>>>>>>>> cd_x_units  = 'degrees_east '
>>>>>>>>>>>> cd_y_offset = deglat_start
>>>>>>>>>>>> cd_y_name   = 'lat'
>>>>>>>>>>>> cd_y_lname  = 'latitude '
>>>>>>>>>>>> cd_y_units  = 'degrees_north'
>>>>>>>>>>>> cd_z_name   = 'lev'
>>>>>>>>>>>> coord_t_offset = real((sim_t_hh*3600 + sim_t_mm*60
>>>>>>>>>>>> +sim_t_ss),real4)
>>>>>>>>>>>> coord_t_name   = 'date'
>>>>>>>>>>>> coord_t_units  = 'seconds since '//simdate//' 00:00:00
>>>>>>>>>>>> [local]'
>>>>>>>>>>>> ! COARDS conventions require time zone from UTC to be
>>>>>>>>>>>> specified
>>>>>>>>>>>> ! not necessary for local area version of ATHAM
>>>>>>>>>>>> end subroutine gridconvert
>>>>>>>>>>>> end subroutine netcdf_define
>>>>>>>>>>>> subroutine handle_err(status,op)
>>>>>>>>>>>> integer,                    intent (in   ) :: status
>>>>>>>>>>>> character(len=*), optional, intent (in   ) :: op
>>>>>>>>>>>> if ( status /= nf_noerr ) then
>>>>>>>>>>>> if (myrank==0) then
>>>>>>>>>>>> print *, ""
>>>>>>>>>>>> print *, "P-NetCDF operation: ",trim(op)
>>>>>>>>>>>> print *, trim(nfmpi_strerror(status))
>>>>>>>>>>>> print *, "atham_pnetcdf error: program execution stopped"
>>>>>>>>>>>> print *, ""
>>>>>>>>>>>> stop
>>>>>>>>>>>> end if
>>>>>>>>>>>> end if
>>>>>>>>>>>> return
>>>>>>>>>>>> end subroutine handle_err
>>>>>>>>>>>> end module atham_pnetcdf
>>>>>> !-*- F90 -*-
>>>>>> program mpi_setup_netCDFout
>>>>>> ! author:  Alex
>>>>>> HOFFMANN                                             !
>>>>>> ! email:
>>>>>> ! date:    February
>>>>>> 2009                                             !
>>>>>> ! version:
>>>>>> development                                               !
>>>>>> ! simple program to test mpi runs & netCDF output (serial &
>>>>>> parallel)!
>>>>>> !  test code designed to be used with the variables from the
>>>>>> mesoscale
>>>>>> !     atmospheric model ATHAM
>>>>>> !  re-structured as stand-alone
>>>>>> !  reads and writes as netCDF an index matrix for a 4x4 matrix in
>>>>>> real4
>>>>>> !  use precision
>>>>>> !  use atham_module, only : nx,ny,ntx,nty,npx,npy
>>>>>> implicit none
>>>>>> !private
>>>>>> !public
>>>>>> ! --- mpi interface for Fortran 77 only, use header files-----------
>>>>>> include 'mpif.h'
>>>>>> ! --- precision ----------------------------------------------------
>>>>>> integer, parameter         :: real4 =
>>>>>> selected_real_kind(6),            &
>>>>>>                            real8 =
>>>>>> selected_real_kind(12),           &
>>>>>>                            kreal = real8
>>>>>> integer, parameter         :: int4 =
>>>>>> selected_int_kind(7),              &
>>>>>>                            int8 =
>>>>>> selected_int_kind(13),             &
>>>>>>                            kint = int4
>>>>>> ! --- atham_module -------------------------------------------------
>>>>>> integer(kint)                            :: nx,ny,ntx,nty,npx,npy
>>>>>> integer(kint)                            :: my_ranks,
>>>>>> nprocs,           &
>>>>>>                                          my_cart, myrank, mycoor(2)
>>>>>> logical                                  :: mpi_initialized, mpi
>>>>>> ! --- other --------------------------------------------------------
>>>>>> integer(kint)                            :: ierror
>>>>>> real(real4), allocatable, dimension(:,:) :: array_g, array
>>>>>> mpi_initialized=.false.
>>>>>> ! ---for initial testing--------------------------------------------
>>>>>> nx  = 4_kint ! user-specified number of grid points along x
>>>>>> ny  = 4_kint
>>>>>> npx = 2_kint ! number of processes along x
>>>>>> npy = 2_kint
>>>>>> ntx = nx     ! re-adjusted total number of grid points along x
>>>>>> nty = ny
>>>>>> nx  = nx/npx ! number of grid points along x per process
>>>>>> ny  = ny/npy
>>>>>> ! --- MAIN
>>>>>> ! --- mpi setup calls ----------------------------------------------
>>>>>> call initialize_mpi
>>>>>> call setup_mpi
>>>>>> ! --- netCDF out calls ---------------------------------------------
>>>>>> call nc_out_s
>>>>>> call nc_out_p
>>>>>> ! --- mpi finalize call --------------------------------------------
>>>>>> call mpi_Finalize(ierror)
>>>>>> ! --- END MAIN
>>>>>> contains
>>>>>> subroutine initialize_mpi()
>>>>>> !    use atham_module, only : mpi, mpi_initialized
>>>>>> !    use atham_module, only : myrank, nprocs
>>>>>> integer(kint)              :: ierror, errorclass
>>>>>> character(len=100)         :: message
>>>>>> ! assign variables for serial version
>>>>>> ierror=0
>>>>>> myrank=0
>>>>>> nprocs=1
>>>>>> mpi=.false.
>>>>>> ! initialize MPI
>>>>>> mpi=.true.
>>>>>> if (.not. mpi_initialized) call mpi_init(ierror)
>>>>>> call MPI_Comm_rank(mpi_comm_world,myrank,ierror)
>>>>>> call MPI_Comm_size(mpi_comm_world,nprocs,ierror)
>>>>>> mpi=.true.
>>>>>> mpi_initialized=.true.
>>>>>> if (myrank==0) then
>>>>>>   print *, 'Myrank 0: ',myrank
>>>>>>   print *, 'MPI initialized!'
>>>>>>   print *, 'Number of processes [nprocs]: ',nprocs
>>>>>> endif
>>>>>> if (ierror>0) then
>>>>>>   call MPI_Error_string(ierror,message,100)
>>>>>>   call MPI_Error_class(ierror,errorclass)
>>>>>>   call exec_stop(message,errorclass)
>>>>>> endif
>>>>>> end subroutine initialize_mpi
>>>>>> subroutine setup_mpi()
>>>>>> !    use atham_module, only : myrank,nprocs,my_cart,mycoor
>>>>>> integer(kint)              :: idims(2),shape_array(2)
>>>>>> logical                    :: reorder
>>>>>> integer(kint)              :: i,j,istart,jstart
>>>>>> if (nprocs/=npx*npy) then
>>>>>>   print *, 'nprocs /= npx*npy - execution aborted'
>>>>>>   call mpi_abort(mpi_comm_world,ierror)
>>>>>>   stop
>>>>>> endif
>>>>>> ! create virtual topology
>>>>>> idims(1:2) = (/npx,npy/)
>>>>>> reorder = .true.
>>>>>> call
>>>>>> MPI_Cart_create(mpi_comm_world,2,idims,(/.false.,.false./),reorder,my_cart,ierror)
>>>>>> call MPI_Comm_rank(my_cart,myrank,ierror) ! ranks on new communicator
>>>>>> call MPI_Cart_coords(my_cart,myrank,2,mycoor,ierror)
>>>>>> if(myrank==0) then
>>>>>>   print *, 'Coords of process ',myrank,' :',mycoor
>>>>>> endif
>>>>>> if (ierror>0) then
>>>>>> endif
>>>>>> ! allocate and assign global grid on each process
>>>>>> allocate(array_g(ntx,nty))
>>>>>> array_g(1,:) = (/ 11.0,12.0,13.0,14.0 /)
>>>>>> array_g(2,:) = (/ 21.0,22.0,23.0,24.0 /)
>>>>>> array_g(3,:) = (/ 31.0,32.0,33.0,34.0 /)
>>>>>> array_g(4,:) = (/ 41.0,42.0,43.0,44.0 /)
>>>>>> if (myrank==0) then
>>>>>>   print *, 'whole 4*4 array on each process:'
>>>>>>   print *, array_g(1,:)
>>>>>>   print *, array_g(2,:)
>>>>>>   print *, array_g(3,:)
>>>>>>   print *, array_g(4,:)
>>>>>> endif
>>>>>> ! allocate and assign subgrid portions on various processes
>>>>>> allocate(array(nx,ny))
>>>>>> do i=1,nx
>>>>>>   do j=1,ny
>>>>>>      array(i,j) = array_g(istart+i,jstart+j)
>>>>>>   enddo
>>>>>> enddo
>>>>>> ! output results from one process
>>>>>> if (myrank==0) then
>>>>>>   print *, ''
>>>>>>   print *, 'subgrid array on process with coords ',mycoor,':'
>>>>>>   shape_array = shape(array)
>>>>>>   print *, 'shape: ',shape_array
>>>>>>   do i=1,shape_array(1)
>>>>>>      print *, array(i,:)
>>>>>>   enddo
>>>>>>   print *, ''
>>>>>> endif
>>>>>> end subroutine setup_mpi
>>>>>> subroutine nc_out_s()
>>>>>> use netcdf
>>>>>> !    use atham_module, only : makename
>>>>>> !    use atham_module, only : mycoor
>>>>>> character(len=10)    :: name
>>>>>> integer(kint)        :: x_dimID,y_dimID,x_varID,y_varID,array_varID
>>>>>> call makename('out',mycoor,name)
>>>>>> name = trim(name)//'.nc'
>>>>>> call handle_err_nc_s(nf90_create(path = './'//trim(name), cmode =
>>>>>> 0, ncid = NCID))
>>>>>> call handle_err_nc_s(nf90_def_dim(ncid = NCID, name = 'x',     len
>>>>>> = nx, dimid = x_dimID))
>>>>>> call handle_err_nc_s(nf90_def_dim(ncid = NCID, name = 'y',     len
>>>>>> = ny, dimid = y_dimID))
>>>>>> call handle_err_nc_s(nf90_def_var(ncid = NCID, name = 'x',
>>>>>> xtype = NF90_FLOAT, dimids = x_dimID, varid = x_varID))
>>>>>> call handle_err_nc_s(nf90_def_var(ncid = NCID, name = 'y',
>>>>>> xtype = NF90_FLOAT, dimids = y_dimID, varid = y_varID))
>>>>>> call handle_err_nc_s(nf90_def_var(ncid = NCID, name = 'array',
>>>>>> xtype = NF90_FLOAT, dimids = (/x_dimID,y_dimID/), varid =
>>>>>> array_varID))
>>>>>> call handle_err_nc_s(nf90_enddef(ncid = NCID))
>>>>>> call handle_err_nc_s(nf90_put_var(ncid = NCID, varid = array_varID,
>>>>>> values = array))
>>>>>> call handle_err_nc_s(nf90_close(ncid = NCID))
>>>>>> end subroutine nc_out_s
>>>>>> subroutine nc_out_p
>>>>>> !    use atham_module, only : mycoor,my_cart,myrank
>>>>>> ! precompiler problem: include file had to be hardwired into code
>>>>>> !    include 'pnetcdf.inc'
>>>>>> integer(kint)                :: NCIDP
>>>>>> integer(kint)                ::
>>>>>> x_dimIDP,y_dimIDP,x_varIDP,y_varIDP,array_varIDP
>>>>>> integer(kint)                :: dimIDPs(2)
>>>>>> integer(MPI_OFFSET_KIND)     :: dimlenx,dimleny
>>>>>> integer(MPI_OFFSET_KIND)     :: ntx_mpi,nty_mpi,nx_mpi,ny_mpi
>>>>>> ntx_mpi = ntx
>>>>>> nty_mpi = nty
>>>>>> nx_mpi  = nx
>>>>>> ny_mpi  = ny
>>>>>> name   = 'out_glb.nc'
>>>>>> call
>>>>>> handle_err_nc_p(nfmpi_create(my_cart,'./'//trim(name),0,MPI_INFO_NULL,NCIDP),0)
>>>>>> call handle_err_nc_p(nfmpi_def_dim(NCIDP,'x',ntx_mpi,x_dimIDP),1)
>>>>>> call handle_err_nc_p(nfmpi_def_dim(NCIDP,'y',nty_mpi,y_dimIDP),2)
>>>>>> call
>>>>>> handle_err_nc_p(nfmpi_def_var(NCIDP,'x',NF_FLOAT,1,x_dimIDP,x_varIDP),3)
>>>>>> call
>>>>>> handle_err_nc_p(nfmpi_def_var(NCIDP,'y',NF_FLOAT,1,y_dimIDP,y_varIDP),4)
>>>>>> call
>>>>>> handle_err_nc_p(nfmpi_def_var(NCIDP,'array',NF_FLOAT,2,(/x_dimIDP,y_dimIDP/),array_varIDP),5)
>>>>>> call handle_err_nc_p(nfmpi_enddef(NCIDP),6)
>>>>>> if (myrank==0) then
>>>>>>   print *, ''
>>>>>>   print *, 'array in nc_out_p subroutine'
>>>>>>   print *, array
>>>>>>   print *, ''
>>>>>>   print *, '(/nx,ny/)         ',(/nx,ny/)
>>>>>>   print *, '(/istart,jstart/) ',(/istart,jstart/)
>>>>>> endif
>>>>>> if (myrank==0) then
>>>>>>   print *, ''
>>>>>>   call handle_err_nc_p(nfmpi_inq_dimlen(NCIDP,x_dimIDP,dimlenx),7)
>>>>>>   call handle_err_nc_p(nfmpi_inq_dimlen(NCIDP,y_dimIDP,dimleny),8)
>>>>>>   print *, 'pnetCDF var dimensions in xy ',dimlenx,dimleny
>>>>>>   print *, 'ntx_mpi ',ntx_mpi
>>>>>>   print *, 'ntx     ',ntx
>>>>>>   print *, 'nx_mpi  ',nx_mpi
>>>>>>   print *, 'nx      ',nx
>>>>>> endif
>>>>>> call
>>>>>> end subroutine nc_out_p
>>>>>> subroutine handle_err_nc_s(status)
>>>>>> use netcdf
>>>>>> if ( status /= nf90_noerr ) then
>>>>>>   print *, ""
>>>>>>   print *, trim(nf90_strerror(status))
>>>>>>   print *, "atham_netcdf error: program execution stopped"
>>>>>>   print *, ""
>>>>>>   stop
>>>>>> end if
>>>>>> return
>>>>>> end subroutine handle_err_nc_s
>>>>>> subroutine handle_err_nc_p(status,callID)
>>>>>> integer,                    intent (in   ) :: callID
>>>>>>   if (myrank==0) then
>>>>>>      print *, ""
>>>>>> ",callID
>>>>>>      print *, ""
>>>>>> !         stop
>>>>>>   end if
>>>>>> endif
>>>>>> return
>>>>>> end subroutine handle_err_nc_p
>>>>>> subroutine exec_stop(MESSAGE,ERRORCLASS)
>>>>>> character(len=*), intent(in   ) :: MESSAGE
>>>>>> integer(kint),    intent(in   ) :: ERRORCLASS
>>>>>> print *, 'ERROR: MPI execution stopped'
>>>>>> print *, 'error class: ', ERRORCLASS
>>>>>> print *, 'message: ', trim(MESSAGE)
>>>>>> stop
>>>>>> end subroutine exec_stop
>>>>>> subroutine makename(prefix,icoor,name)
>>>>>> ! create character name=prefix_(icoor(1)+1)_(icoor(2)+1)           !
>>>>>> character(len=*), intent(in)             :: prefix
>>>>>> integer(kint), dimension(2), intent(in)  :: icoor
>>>>>> character(len=*), intent(out)            :: name
>>>>>> ! local variables                                                  !
>>>>>> character(len=25)                        :: numx,numy
>>>>>> integer(kint)                            :: lenx,leny,lenf
>>>>>> write(numx,'(i5)') icoor(1)+1
>>>>>> numx=adjustl(numx)
>>>>>> lenx=len_trim(numx)
>>>>>> write(numy,'(i5)') icoor(2)+1
>>>>>> numy=adjustl(numy)
>>>>>> leny=len_trim(numy)
>>>>>> name=adjustl(prefix)
>>>>>> lenf=len_trim(name)
>>>>>> name=name(1:lenf)//'_'//numx(1:lenx)//'_'//numy(1:leny)
>>>>>> end subroutine makename
>>>>>> end program mpi_setup_netCDFout
>>>>>> # MAKEFILE used for development module testing
>>>>>> # Alex Hoffmann
>>>>>> # set netCDF path
>>>>>> NETCDF = /usr/local/netcdf-3.6.2-ifort
>>>>>> PNETCDF= /usr/local/parallel-netcdf-1.0.1
>>>>>> # set compiler
>>>>>> F90    = mpif90  # mpif90 refers to a shell script that includes
>>>>>> links
>>>>>> to the libraries
>>>>>> # set compiler flags
>>>>>> OFLAGS = -g
>>>>>> # set include flags
>>>>>> IFLAGS = -I$(NETCDF)/include/ -I$(PNETCDF)/include/
>>>>>> # set pre-processing flags
>>>>>> #PFLAGS = -fpp
>>>>>> # concatenate flags
>>>>>> FLAGS  = $(OFLAGS) $(IFLAGS) $(PFLAGS)
>>>>>> # set library flags
>>>>>> LFLAGS = -L$(NETCDF)/lib -lnetcdf -L$(PNETCDF)/lib -lpnetcdf
>>>>>> RM = rm -f
>>>>>> #MAIN =
>>>>>> MAIN = mpi_setup_netCDFout
>>>>>> OBJECTS =
>>>>>> all: $(MAIN)
>>>>>> $(MAIN): $(MAIN).F90 $(OBJECTS)
>>>>>> $(F90) $(FLAGS) -o $@ $^ $(LFLAGS)
>>>>>> clean:
>>>>>> $(RM) *.o *.mod
