error in configure
Wei-keng Liao wkliao at ece.northwestern.edu
Tue Dec 29 12:20:40 CST 2009
Hi, Jim,
I would like to mention that ncmpi_get_var_all() is to read the
entire variable. The checking at line 2009 is to see if the user
buffer has the same number of array elements as the entire
variable. However, this is a warning, not an error. Please let
me know if you are also getting incorrect data from this call.
What puzzles me is the 2nd printf statement that the same
nelems and cnelems bypass the if statement for checking
(nelems != cnelems). Such problem may be because of mismatched
pnetcdf object files in the library). Since you had a clean
rebuild, this should not be the cause. Something else is fishy.
If you are using the SVN most recent revision 753, the two
printf statements you added should be in lines 2009 and 2013.
Did you also add other codes above the line 2009?
Wei-keng
On Dec 29, 2009, at 9:58 AM, Jim Edwards wrote:
> I rebuilt pnetcdf with all optimization off and still get the error.
> I tried to build a short testcase and it works fine, (no error -
> line 2016 is not printed).
> On Mon, Dec 28, 2009 at 6:45 PM, Wei-keng Liao <wkliao at ece.northwestern.edu
> > wrote:
> Your outputs said both nelems and cnelems are 27.
> I don't know why the printf at line 2016 even got printed.
> Can you try a clean build of pnetcdf?
> Or if you can provide a test code, I can give it a try.
> Wei-keng
> On Dec 28, 2009, at 6:59 PM, Jim Edwards wrote:
> That works - thanks.    Here is another one.  I'm gettiing an error
>  Input/Output data amount mismatch
> that I've traced to the mpinetcdf.c file at around line 2000  where
> I added a couple of print statements
>    printf("line %d nelems %d cnelems %d\n",__LINE__,nelems,cnelems);
>  if (nelems != cnelems) {
>    if (warning == NC_NOERR)
>      warning = NC_EIOMISMATCH;
>    (nelems>cnelems) ? (nelems=cnelems) : (cnelems=nelems);
> This results in the output:
>   1:line 2012 nelems 27 cnelems 27
>   1:line 2016 nelems 27 cnelems 27
> On Mon, Dec 28, 2009 at 5:38 PM, Wei-keng Liao <wkliao at ece.northwestern.edu
> > wrote:
> Hi,
> If you run autoreconf first, it will generate that file for you.
> Wei-keng
> On Dec 28, 2009, at 2:47 PM, Jim Edwards wrote:
> Hi,
> Tried checking out the svn trunk and get the following configure
> error...
> configure: error: cannot find sources (src/lib/ncconfig.in) in . or ..
> what happened to this file?
