can't build on linux system...
Ed Hartnett ed at unidata.ucar.edu
Wed Oct 22 08:39:43 CDT 2008
"kgao at eecs" <kgao at eecs.northwestern.edu> writes:
> Hi Ed Hartnett,
> 	Please remove '--disable-fortran' and try it again.
> 	When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7
> --disable-fortran" on our cluster, the same problem is appeared.
> 	When I run "./configure --with-mpi=/home/kgao/mpich2-1.0.7", it is
> OK.
> 	Regards,
> Kui.
That was it! Thanks!
Now it builds and installs just fine.
I notice there is no "check" target. Is there a set of tests I should
run?
Thanks!
Ed
Ed Hartnett  -- ed at unidata.ucar.edu
