nfmpi write interface
Wei-keng Liao wkliao at ece.northwestern.edu
Wed Oct 15 15:44:54 CDT 2008
Hi, Nikhil,
Can you tell us what pnetcdf version you are using?
Wei-keng
On Wed, 15 Oct 2008, Nikhil Laghave wrote:
> Hello All,
> I am getting stuck in a write call "nfmpi_put_vara_int_all". There's
> something wrong in the arguments that I don't seem to understand.
> Can someone have a quick look at the attached file to see what is going
> wrong ? I am creating a 1-D array of 16 integers and running it on 4 procs.
> Each processor writes 4 integers in this arrayat an offset of 4 from each
> other. The file and the variable gets created but the put call doesnt write
> anything.
> Regards,
> Nikhil
