Weird error with nfmpi_def_dim
Nikhil Laghave nikhill at iastate.edu
Wed Oct 15 00:39:46 CDT 2008
Okay I got it, the 3rd parameter needs to be integer*8.
Nikhil
On Wed, Oct 15, 2008 at 12:15 AM, Nikhil Laghave <nikhill at iastate.edu>wrote:
> Hello All,
> Can anyone find some mistake in this function call ?
> retval = nfmpi_def_dim(ncid,'x',NX,x_dimid)
> This is the syntax i got from several documents but I keep getting this
> error because of this line:
> Error:
> 0:   Invalid dimension size
> The variables are declared as:
>       integer NX, NY
>       parameter (NX = 16)
>       integer ncid
>       integer x_dimid, y_dimid
> The file gets created collectively and then I get this error when I try to
> define the dimensions for the variable.
> Can someone plz point out the error so that I can get a start with pnetcdf
> ? I have also attached the file with this emai.
> Thanks in anticipation.
> Regards,
> Nikhil
Nikhil
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20081015/822daaee/attachment.htm>
