Help getting started with Pnetcdf
Nikhil Laghave
nikhill at iastate.edu
Mon Oct 13 16:07:52 CDT 2008
Hello All,
I have been using Parallel HDF5 for our code to do parallel IO of huge files
but the performance we're getting is not very encouraging. So I wanted to do
the same with Pnetcdf, but I am not able find much tutorials on the web with
simple examples to write out files in parallel. The ones that are there are
the serial ones.
So I was wondering if someone on this mailing list has a simple Pnetcdf
example, that will help me in understanding how to use pnetcdf.
Also, I am trying to create a simple file using pnetcdf and am getting this
error. There seems to be some problem with the include file and I don't
understand how to get rid of this error. My code is as follows:
program simple_xy_wr
implicit none
include 'pnetcdf.inc'
include 'mpif.h'
C This is the name of the data file we will create.
character*(*) FILE_NAME
parameter (FILE_NAME='simple_xy.nc')
C We are writing 2D data, a 6 x 12 grid.
integer NDIMS,ierr
parameter (NDIMS=1)
integer NX, NY, i, myid, nprocs
parameter (NX = 16)
parameter (NY = 4)
CHARACTER(LEN=12) :: dataname
C When we create netCDF files, variables and dimensions, we get back
C an ID for each one.
integer ncid, varid,varid2, dimids(NDIMS), dimids2(NDIMS)
integer x_dimid, y_dimid
C This is the data array we will write. It will just be filled with
C a progression of integers for this example.
integer data_out(NX)
integer lengths_out(NY)
C Loop indexes, and error handling.
integer x, y, retval
call MPI_INIT(ierr)
call MPI_COMM_RANK(MPI_COMM_WORLD, myid, ierr)
call MPI_COMM_SIZE(MPI_COMM_WORLD, nprocs, ierr)
write(*,*) 'my id is :',myid,'& nprocs are:',nprocs
C Create some pretend data. If this wasn't an example program, we
C would have some real data to write, for example, model output.
do x = 1, NX
data_out(x) = (x - 1) * NX
end do
do y = 1, NY
lengths_out(y) = (y-1) * NY
enddo
nfmpi_create(MPI_COMM_WORLD,FILE_NAME,
& NF_NETCDF4,MPI_INFO_NULL,ncid)
end
When i compile this using : ftn simple.f $PNETCDF, i get this error.
PGF90-S-0021-Label field of continuation line is not blank
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1816)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1820)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1823)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1825)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1827)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1831)
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1833)
PGF90-S-0034-Syntax error at or near identifier
sizeof_mpi_offsetnfmpi_unlimited
(/usr/common/usg/pnetcdf/1.0.2/include/pnetcdf.inc: 1836)
PGF90-S-0034-Syntax error at or near end of line (simple.f: 50)
PGF90-S-0038-Symbol, nfmpi_unlimited, has not been explicitly declared
(simple.f)
0 inform, 0 warnings, 10 severes, 0 fatal for simple_xy_wr
Am i missing something simple ?
Nikhil
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20081013/5f49d481/attachment.htm>
More information about the parallel-netcdf
