Pnetcdf New File Format
Katie Antypas
kantypas at lbl.gov
Mon Aug 11 19:23:39 CDT 2008
Hi Rob,
I am testing out the new pnetcdf file format which is supposed to allow
variable sizes greater than 4GB (as long as they have fewer than 2^31
elements). I am running on the Franklin Cray XT4 system at NERSC with
the PGI compilers and have not successfully created a 1d variable size
larger than 4GB. (I'll try multi-dimensions soon.)
I pass "NC_CLOBBER | NC_64BIT_DATA" to ncmpi_create now. Also, I was
getting type warnings and noticed a new type int64_t in places where
type int and MPI_Offset were used before in a number of calls. What is
your recommendation to users regarding the int64_t type? Should they
replace MPI_Offset with int64_t?
In either case though, if I do or don't make any changes to the ncmpi
calls (namely ncmpi_create, ncmpi_def_var, ncmpi_put_vara_double_all)
then I can only create a variable up to 2GB variable size which is under
2^31 NC_DOUBLE elements in a 1 dimensional array. (If we were counting
bytes, rather than doubles my test would be at the 2^31 elements
limit.) I didn't think this was the way elements were counted though?
Katie
More information about the parallel-netcdf
