problem with def_var
Jim Edwards
jedwards at ucar.edu
Thu May 10 12:27:35 CDT 2007
I'm getting a rather criptic message on initialization that I think means
that one of def_var, def_dim, or put_att has a confict from one mpi task to
the next:
NC definations on multiprocesses conflict.
NOTE: Definitions across all process
the problem is that it's at enddef that I get this message so I can't tell
which of the 50 or so calls prior to that is really the problem. Is there
any way to move this message closer to the point of origin?
Jim
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20070510/eae10784/attachment.htm>
More information about the parallel-netcdf
