MPI info object
Wei-keng Liao
wkliao at ece.northwestern.edu
Wed Jul 4 02:30:51 CDT 2007
The MPI info object passed into ncmpi_open() and ncmpi_create() should be
duplicated using
MPI_Info_dup(info, &nciop->mpiinfo);
instead of
nciop->mpiinfo = info;
in ncmpiio_create() and ncmpiio_open() in file mpincio.c.
The same info object will be used in MPI_file_setview() later in the data
mode APIs. The above fix can prevent from freeing the info object by
applications before the data mode APIs are called.
Wei-keng
More information about the parallel-netcdf
