parallel netcd 1.0.1 make errors on Apple
Robert Latham robl at mcs.anl.gov
Wed Jan 10 14:51:48 CST 2007
On Wed, Jan 10, 2007 at 11:27:14AM -0700, Amjad Majid Ali wrote:
> Hi
> I am trying to compile parallel netcdf on Apple( darwin 8.8.0)
> I  am using ibm xlf  8.1 compiler.
> I am using  lam mpi
> i am attaching my config.log file
> This is error i am getting when i run make or gnumake
> Making `all' in directory /Users/amjad/parallel-netcdf-1.0.1/src
> cd lib && make
> ar cru libpnetcdf.a mpinetcdf.o header.o mpincio.o attr.o dim.o
> error.o nc.o ncx.o string.o var.o ncmpidtype.o
> ranlib libpnetcdf.a
> if [ yes = yes ] ; then cd libf && make ; fi
> /usr/local/xlf/bin/mpif77 -c -O3 strerrorf.f
> "strerrorf.f", line 4.7: 1515-019 (S) Syntax is incorrect.
> "strerrorf.f", line 5.7: 1515-019 (S) Syntax is incorrect.
> ** nfmpi_strerror   === End of Compilation 1 ===
> 1501-511  Compilation failed for file strerrorf.f.
> make[3]: *** [strerrorf.o] Error 1
> make[2]: *** [all] Error 2
> make[1]: *** [subdir_target] Error 1
> make: *** [src/lib/all] Error 2
Huh... it would appear that your /usr/local/xlf/bin/mpif77 does not
like it when .f files use C for comments.   We use C for comments all
over the place, so I'm not sure what's wrong here.   We also use the
xlf compiler (version 10) on our BlueGene and have reports of xlf
working ok on some IBM SP machines, so I'm not entirely sure what
is different about your situation and why we don't handle it.
> Any solutions??
Well, one solution would be to remove the comments from
src/libf/strerrorf.f and also src/libf/inq_libversf.f and see how far
you get.  Is there a compiler option for xlf to handle different
comment styles?
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
