failure running pnetcdf tests
michael bane michael.bane at manchester.ac.uk
Tue Jan 9 15:31:03 CST 2007
-------- Forwarded Message --------
> From: michael bane <michael.bane at manchester.ac.uk>
> To: parallel-netcdf at mcs.anl.gov
> Subject: failure running pnetcdf tests
> Date: Sat, 06 Jan 2007 18:11:27 +0000
> Folks
> I've just downloaded the pnetCDF tarball and attempted to install on my
> box with mpich2 and Intel compilers. When running
>         ~/src/parallel-netcdf-1.0.1/test/nf_test$ ./nf_test
> I get numerous errors immediately, starting with
>         *** Testing nfmpi_strerror ...
>         *** Testing nfmpi_open ...
>          0: MPI_File_open error = File does not exist, error stack:
>         ADIOI_UFS_OPEN(53): File tooth-fairy.nc does not exist
>          nfmpi_open of nonexistent file should    have returned system
>         error
>         ADIOI_UFS_OPEN(53): File test.nc does not exist
>          nfmpi_open: Can not open/create file
>          nfmpi_redef of read-only file should fail
>          nfmpi_close: Not a netCDF id
>            ###            8  FAILURES TESTING nfmpi_open! ###
> I am at a lost as to what this errors mean or if I've misunderstood
> instructions so any tips welcome!
> Thanks, Michael
Thanks to Robert who advised I should be running
 nf_test -c && nf_test -v
However, for both FORTRAN and C I get many more errors than
"expected"... anybody know where I should be looking to see what I've
done wrong? Thanks, Michael
michael at manchester-campaigns:~/src/parallel-netcdf-1.0.1/test/nf_test$
mpirun -np 1 ./nf_test -c
mpirun -np 1 ./nf_test -v > nf_test.out 2>&1
OUTPUT:
 nfmpi_open of nonexistent file should    have returned system error
   ###            1  FAILURES TESTING nfmpi_open! ###
*** Testing nfmpi_close ...
*** Testing nfmpi_inq ...
*** Testing nfmpi_inq_dimid ...
*** Testing nfmpi_inq_dim ...
*** Testing nfmpi_inq_dimlen ...
*** Testing nfmpi_inq_dimname ...
*** Testing nfmpi_inq_varid ...
*** Testing nfmpi_inq_var ...
*** Testing nfmpi_inq_natts ...
*** Testing nfmpi_inq_ndims ...
*** Testing nfmpi_inq_nvars ...
*** Testing nfmpi_inq_unlimdim ...
*** Testing nfmpi_inq_vardimid ...
*** Testing nfmpi_inq_varname ...
*** Testing nfmpi_inq_varnatts ...
*** Testing nfmpi_inq_varndims ...
*** Testing nfmpi_inq_vartype ...
*** Testing nfmpi_get_var1_text ...
         179  good comparisons.
*** Testing nfmpi_get_var1_int1 ...
         269  good comparisons.
*** Testing nfmpi_get_var1_int2 ...
         682  good comparisons.
*** Testing nfmpi_get_var1_int ...
        1191  good comparisons.
*** Testing nfmpi_get_var1_real ...
        1203  good comparisons.
*** Testing nfmpi_get_var1_double ...
        1212  good comparisons.
*** Testing nfmpi_get_var_text ...
*** Testing nfmpi_get_var_int1 ...
*** Testing nfmpi_get_var_int2 ...
*** Testing nfmpi_get_var_int ...
*** Testing nfmpi_get_var_real ...
*** Testing nfmpi_get_var_double ...
*** Testing nfmpi_get_vara_text ...
*** Testing nfmpi_get_vara_int1 ...
*** Testing nfmpi_get_vara_int2 ...
*** Testing nfmpi_get_vara_int ...
*** Testing nfmpi_get_vara_real ...
*** Testing nfmpi_get_vara_double ...
*** Testing nfmpi_get_vars_text ...
         293  good comparisons.
*** Testing nfmpi_get_vars_int1 ...
         553  good comparisons.
*** Testing nfmpi_get_vars_int2 ...
        1250  good comparisons.
*** Testing nfmpi_get_vars_int ...
        2309  good comparisons.
*** Testing nfmpi_get_vars_real ...
        2095  good comparisons.
*** Testing nfmpi_get_vars_double ...
        2134  good comparisons.
*** Testing nfmpi_get_varm_text ...
*** Testing nfmpi_get_varm_int1 ...
*** Testing nfmpi_get_varm_int2 ...
*** Testing nfmpi_get_varm_int ...
*** Testing nfmpi_get_varm_real ...
*** Testing nfmpi_get_varm_double ...
*** Testing nfmpi_get_att_text ...
           7  good comparisons.
*** Testing nfmpi_get_att_int1 ...
           7  good comparisons.
*** Testing nfmpi_get_att_int2 ...
          15  good comparisons.
*** Testing nfmpi_get_att_int ...
          21  good comparisons.
*** Testing nfmpi_get_att_real ...
          29  good comparisons.
*** Testing nfmpi_get_att_double ...
          33  good comparisons.
*** Testing nfmpi_inq_att ...
*** Testing nfmpi_inq_attname ...
*** Testing nfmpi_inq_attid ...
*** Testing nfmpi_inq_attlen ...
*** Testing nfmpi_inq_atttype ...
*** Testing nfmpi_create ...
 0: MPI_File_open error = Other I/O error , error stack:
ADIOI_UFS_OPEN(83): Other I/O error File exists
 attempt to overwrite file: Can not open/create file
   ###            2  FAILURES TESTING nfmpi_create! ###
*** Testing nfmpi_redef ...
        1391  good comparisons.
          40  good comparisons.
*** Testing nfmpi_enddef ...
*** Testing nfmpi_sync ...
*** Testing nfmpi_abort ...
*** Testing nfmpi_def_dim ...
*** Testing nfmpi_rename_dim ...
*** Testing nfmpi_def_var ...
*** Testing nfmpi_put_var1_text ...
*** Testing nfmpi_put_var1_int1 ...
*** Testing nfmpi_put_var1_int2 ...
*** Testing nfmpi_put_var1_int ...
*** Testing nfmpi_put_var1_real ...
 Var value read not that expected
 varid: %d          10
 var_name: ir
 index:
             2
 expect:    2147483647.00000
 got:   -2147483648.00000
        1199  good comparisons.
   ###           32  FAILURES TESTING nfmpi_put_var1_real! ###
*** Testing nfmpi_put_var1_double ...
*** Testing nfmpi_put_var_text ...
*** Testing nfmpi_put_var_int1 ...
*** Testing nfmpi_put_var_int2 ...
*** Testing nfmpi_put_var_int ...
*** Testing nfmpi_put_var_real ...
 Numeric conversion not
representable
representable
representable
 varid: %d          10
 var_name: ir
 index:
   ###           35  FAILURES TESTING nfmpi_put_var_real! ###
*** Testing nfmpi_put_var_double ...
*** Testing nfmpi_put_vara_text ...
*** Testing nfmpi_put_vara_int1 ...
*** Testing nfmpi_put_vara_int2 ...
*** Testing nfmpi_put_vara_int ...
*** Testing nfmpi_put_vara_real ...
representable
representable
representable
 varid: %d          10
 var_name: ir
 index:
   ###           35  FAILURES TESTING nfmpi_put_vara_real! ###
*** Testing nfmpi_put_vara_double ...
*** Testing nfmpi_put_vars_text ...
*** Testing nfmpi_put_vars_int1 ...
*** Testing nfmpi_put_vars_int2 ...
*** Testing nfmpi_put_vars_int ...
*** Testing nfmpi_put_vars_real ...
representable
representable
representable
 varid: %d          10
 var_name: ir
 index:
   ###           35  FAILURES TESTING nfmpi_put_vars_real! ###
*** Testing nfmpi_put_vars_double ...
*** Testing nfmpi_put_varm_text ...
*** Testing nfmpi_put_varm_int1 ...
*** Testing nfmpi_put_varm_int2 ...
*** Testing nfmpi_put_varm_int ...
*** Testing nfmpi_put_varm_real ...
representable
representable
representable
 varid: %d          10
 var_name: ir
 index:
   ###           35  FAILURES TESTING nfmpi_put_varm_real! ###
*** Testing nfmpi_put_varm_double ...
*** Testing nfmpi_rename_var ...
*** Testing nfmpi_put_att_text ...
           7  good comparisons.
*** Testing nfmpi_put_att_int1 ...
           7  good comparisons.
*** Testing nfmpi_put_att_int2 ...
*** Testing nfmpi_put_att_int ...
*** Testing nfmpi_put_att_real ...
representable
 att. value read not that expected
 varid:            0
 att_name: Gi
 element number:            2
          27  good comparisons.
   ###           15  FAILURES TESTING nfmpi_put_att_real! ###
*** Testing nfmpi_put_att_double ...
*** Testing nfmpi_copy_att ...
*** Testing nfmpi_rename_att ...
*** Testing nfmpi_del_att ...
*** Testing nfmpi_set_fill ...
 NOTE: Parallel-netcdf expects to see 3 failures
 Total number of failures:          190
michael at manchester-campaigns:~/src/parallel-netcdf-1.0.1/test/nc_test$
mpirun -np 1 ./nc_test -c
mpirun -np 1 ./nc_test -v > nc_test.out 2>&1
OUTPUT:
*** Testing ncmpi_strerror ...
ok
*** Testing ncmpi_open ...  0: MPI_File_open error = File does not
exist, error stack:
	FAILURE at line 97 of test_read.c: ncmpi_open of nonexistent file
	### 1 FAILURES TESTING ncmpi_open! ###
*** Testing ncmpi_close ...
ok
*** Testing ncmpi_inq ...
ok
*** Testing ncmpi_inq_dimid ...
ok
*** Testing ncmpi_inq_dim ...
ok
*** Testing ncmpi_inq_dimlen ...
ok
*** Testing ncmpi_inq_dimname ...
ok
*** Testing ncmpi_inq_varid ...
ok
*** Testing ncmpi_inq_var ...
ok
*** Testing ncmpi_inq_natts ...
ok
*** Testing ncmpi_inq_ndims ...
ok
*** Testing ncmpi_inq_nvars ...
ok
*** Testing ncmpi_inq_unlimdim ...
ok
*** Testing ncmpi_inq_vardimid ...
ok
*** Testing ncmpi_inq_varname ...
ok
*** Testing ncmpi_inq_varnatts ...
ok
*** Testing ncmpi_inq_varndims ...
ok
*** Testing ncmpi_inq_vartype ...
ok
*** Testing ncmpi_get_var_text ...
ok
*** Testing ncmpi_get_var_uchar ...
 264 good comparisons.
ok
*** Testing ncmpi_get_var_schar ...
ok
*** Testing ncmpi_get_var_short ...
ok
*** Testing ncmpi_get_var_int ...
 1189 good comparisons.
ok
*** Testing ncmpi_get_var_long ...
ok
*** Testing ncmpi_get_var_float ...
 1198 good comparisons.
ok
*** Testing ncmpi_get_var_double ...
 1207 good comparisons.
ok
*** Testing ncmpi_get_var1_text ...
ok
*** Testing ncmpi_get_var1_uchar ...
ok
*** Testing ncmpi_get_var1_schar ...
ok
*** Testing ncmpi_get_var1_short ...
ok
*** Testing ncmpi_get_var1_int ...
ok
*** Testing ncmpi_get_var1_long ...
ok
*** Testing ncmpi_get_var1_float ...
ok
*** Testing ncmpi_get_var1_double ...
ok
*** Testing ncmpi_get_vara_text ...
ok
*** Testing ncmpi_get_vara_uchar ...
ok
*** Testing ncmpi_get_vara_schar ...
ok
*** Testing ncmpi_get_vara_short ...
ok
*** Testing ncmpi_get_vara_int ...
ok
*** Testing ncmpi_get_vara_long ...
ok
*** Testing ncmpi_get_vara_float ...
ok
*** Testing ncmpi_get_vara_double ...
ok
*** Testing ncmpi_get_vars_text ...
ok
*** Testing ncmpi_get_vars_uchar ...
ok
*** Testing ncmpi_get_vars_schar ...
ok
*** Testing ncmpi_get_vars_short ...
ok
*** Testing ncmpi_get_vars_int ...
ok
*** Testing ncmpi_get_vars_long ...
ok
*** Testing ncmpi_get_vars_float ...
ok
*** Testing ncmpi_get_vars_double ...
ok
*** Testing ncmpi_get_varm_text ...
ok
*** Testing ncmpi_get_varm_uchar ...
ok
*** Testing ncmpi_get_varm_schar ...
ok
*** Testing ncmpi_get_varm_short ...
ok
*** Testing ncmpi_get_varm_int ...
ok
*** Testing ncmpi_get_varm_long ...
ok
*** Testing ncmpi_get_varm_float ...
ok
*** Testing ncmpi_get_varm_double ...
ok
*** Testing ncmpi_get_att_text ...
 7 good comparisons.
ok
*** Testing ncmpi_get_att_uchar ...
 5 good comparisons.
ok
*** Testing ncmpi_get_att_schar ...
 7 good comparisons.
ok
*** Testing ncmpi_get_att_short ...
ok
*** Testing ncmpi_get_att_int ...
 19 good comparisons.
ok
*** Testing ncmpi_get_att_long ...
ok
*** Testing ncmpi_get_att_float ...
 23 good comparisons.
ok
*** Testing ncmpi_get_att_double ...
ok
*** Testing ncmpi_inq_att ...
ok
*** Testing ncmpi_inq_attname ...
ok
*** Testing ncmpi_inq_attid ...
ok
*** Testing ncmpi_inq_attlen ...
ok
*** Testing ncmpi_inq_atttype ...
ok
*** Testing ncmpi_create ...  0: MPI_File_open error = Other I/O error ,
error stack:
	FAILURE at line 57 of test_write.c: attempt to overwrite file: status =
-32
	### 1 FAILURES TESTING ncmpi_create! ###
*** Testing ncmpi_redef ...
 1386 good comparisons.
ok
*** Testing ncmpi_sync ...
ok
*** Testing ncmpi_abort ...
ok
*** Testing ncmpi_def_dim ...
ok
*** Testing ncmpi_rename_dim ...
ok
*** Testing ncmpi_def_var ...
ok
*** Testing ncmpi_put_var_text ...
ok
*** Testing ncmpi_put_var_uchar ...
ok
*** Testing ncmpi_put_var_schar ...
ok
*** Testing ncmpi_put_var_short ...
ok
*** Testing ncmpi_put_var_int ...
ok
*** Testing ncmpi_put_var_long ...
ok
*** Testing ncmpi_put_var_float ...
	FAILURE at line 2912 of test_put.c: Numeric conversion not
representable
	FAILURE at line 2961 of test_put.c: Numeric conversion not
representable
	FAILURE at line 725 of test_put.c: Var value read not that expected
varid: 9, var_name: ir, index: 1, expect: 2.14748e+09, got: -2.14748e+09
varid: 21, var_name: i2, index: 1, expect: 2.14748e+09, got: -2.14748e
+09
varid: 27, var_name: i3, index: 1, expect: 2.14748e+09, got: -2.14748e
+09
varid: 33, var_name: i4, index: 1, expect: 2.14748e+09, got: -2.14748e
+09
 1194 good comparisons.
	### 6 FAILURES TESTING ncmpi_put_var_float! ###
*** Testing ncmpi_put_var_double ...
ok
*** Testing ncmpi_put_var1_text ...
ok
*** Testing ncmpi_put_var1_uchar ...
ok
*** Testing ncmpi_put_var1_schar ...
ok
*** Testing ncmpi_put_var1_short ...
ok
*** Testing ncmpi_put_var1_int ...
ok
*** Testing ncmpi_put_var1_long ...
ok
*** Testing ncmpi_put_var1_float ...
+09
+09
+09
	### 4 FAILURES TESTING ncmpi_put_var1_float! ###
*** Testing ncmpi_put_var1_double ...
ok
*** Testing ncmpi_put_vara_text ...
ok
*** Testing ncmpi_put_vara_uchar ...
ok
*** Testing ncmpi_put_vara_schar ...
ok
*** Testing ncmpi_put_vara_short ...
ok
*** Testing ncmpi_put_vara_int ...
ok
*** Testing ncmpi_put_vara_long ...
ok
*** Testing ncmpi_put_vara_float ...
	FAILURE at line 4155 of test_put.c: Numeric conversion not
representable
representable
representable
+09
+09
+09
	### 7 FAILURES TESTING ncmpi_put_vara_float! ###
*** Testing ncmpi_put_vara_double ...
ok
*** Testing ncmpi_put_vars_text ...
ok
*** Testing ncmpi_put_vars_uchar ...
ok
*** Testing ncmpi_put_vars_schar ...
ok
*** Testing ncmpi_put_vars_short ...
ok
*** Testing ncmpi_put_vars_int ...
ok
*** Testing ncmpi_put_vars_long ...
ok
*** Testing ncmpi_put_vars_float ...
	FAILURE at line 5415 of test_put.c: Numeric conversion not
representable
representable
representable
	FAILURE at line 5418 of test_put.c: range error: status = 0
+09
+09
+09
	### 8 FAILURES TESTING ncmpi_put_vars_float! ###
*** Testing ncmpi_put_vars_double ...
ok
*** Testing ncmpi_put_varm_text ...
ok
*** Testing ncmpi_put_varm_uchar ...
ok
*** Testing ncmpi_put_varm_schar ...
ok
*** Testing ncmpi_put_varm_short ...
ok
*** Testing ncmpi_put_varm_int ...
ok
*** Testing ncmpi_put_varm_long ...
ok
*** Testing ncmpi_put_varm_float ...
	FAILURE at line 6738 of test_put.c: Numeric conversion not
representable
representable
	FAILURE at line 6741 of test_put.c: range error: status = 0
representable
+09
+09
	### 9 FAILURES TESTING ncmpi_put_varm_float! ###
*** Testing ncmpi_put_varm_double ...
ok
*** Testing ncmpi_rename_var ...
ok
*** Testing ncmpi_put_att_text ...
 7 good comparisons.
ok
*** Testing ncmpi_put_att_uchar ...
 5 good comparisons.
ok
*** Testing ncmpi_put_att_schar ...
 7 good comparisons.
ok
*** Testing ncmpi_put_att_short ...
ok
*** Testing ncmpi_put_att_int ...
ok
*** Testing ncmpi_put_att_long ...
ok
*** Testing ncmpi_put_att_float ...
	FAILURE at line 1345 of test_put.c: att. value read not that expected
varid: -1, att_name: Gi, element number: 1 expect: 2.14748e+09, got:
-2.14748e+09
varid: 3, att_name: i, element number: 1 expect: 2.14748e+09, got:
-2.14748e+09
	### 2 FAILURES TESTING ncmpi_put_att_float! ###
*** Testing ncmpi_put_att_double ...
ok
*** Testing ncmpi_copy_att ...
ok
*** Testing ncmpi_rename_att ...
ok
*** Testing ncmpi_del_att ...
ok
*** Testing ncmpi_set_fill ... unimplemented
ok
*** Testing ncmpi_delete ...
ok
NOTE: parallel-netcdf expects to see 2 failures
Total number of failures: 38
