fortran, parallel-netcdf and openMPI
Mark Taylor
mataylo at sandia.gov
Tue Apr 17 13:48:53 CDT 2007
Parallel-netcdf team:
I'm trying to get the fortran parallel-netcdf interface working on an
openMPI system. Are there any known problems with this combination?
Here's what I get:
./nf_test -c
[alogin1.sandia.gov:11769] *** An error occurred in MPI_Comm_rank
[alogin1.sandia.gov:11769] *** on communicator MPI_COMM_WORLD
[alogin1.sandia.gov:11769] *** MPI_ERR_COMM: invalid communicator
[alogin1.sandia.gov:11769] *** MPI_ERRORS_ARE_FATAL (goodbye)
I did a little debugging, and came to the possible conclusion that
parallel-netcdf is assuming the Fortran communicator handle is
compatible with the C communicator handle? (see for example openf.c).
But openMPI, the fortran handle has to be converted with the
MPI_Comm_f2c() routine. See for example:
http://www.open-mpi.org/community/lists/users/2006/09/1812.php
Do you think this could be the cause of my problem? And if so, any
simple workarounds?
Mark Taylor, mataylo at sandia.gov, 505-284-1874
Exploratory Simulation Technologies
MS 0370, Sandia National Labs, Albuquerque NM 87185
More information about the parallel-netcdf
