> 4GiB variables
Katie Antypas kantypas at lbl.gov
Mon Apr 16 11:18:11 CDT 2007
Hi Rob,
I'll talk to John Shalf and see if this is a priority or if we can work
around it.
Katie
Robert Latham wrote:
> On Wed, Apr 04, 2007 at 11:33:52AM -0700, Katie Antypas wrote:
>> Hi All,
>> We are seeing the 4GiB limitation on variable sizes on the Power 5
>> machine Bassi at NERSC.  The last fixed-size variable in a file can be
>> larger.  John Shalf's group is also seeing the same limitation, although
>> he though he recalled speaking with Rob Ross about how this limitation
>> was lifted in recent versions.  Is this the case?
> Hi Katie
> This appears to be a limitation of both serial NetCDF and
> Parallel-NetCDF, even with the CDF-2 format:
> http://www.unidata.ucar.edu/software/netcdf/docs/netcdf/NetCDF-64-bit-Offset-Format-Limitations.html
>     No fixed-size variable can require more than 2^32 - 4 bytes (i.e.
>     4GiB - 4 bytes, or 4,294,967,292 bytes) of storage for its data,
>     unless it is the last fixed-size variable and there are no record
>     variables.  When there are no record variables, the last
>     fixed-size variable can be any size supported by the file system,
>     e.g. terabytes.
> http://www.unidata.ucar.edu/software/netcdf/docs/faq.html#Large%20File%20Support10
>     Have all netCDF size limits been eliminated?
>     No, there are still some limits on sizes of netCDF objects, even
>     with the new 64-bit offset format. Each fixed-size variable and
>     the data for one record's worth of a record variable are limited
>     in size to a little less that 4 GiB, which is twice the size limit
>     in versions earlier than netCDF 3.6.
>     The maximum number of records remains 232-1.
> Is there a straightforward way for you to work with variables less
> than 4GB?  If not, we can talk with the serial netcdf guys about ways
> to work around this limit.   Just let us know.
> ==rob
