> 4GiB variables
Robert Latham robl at mcs.anl.gov
Fri Apr 6 10:21:17 CDT 2007
On Wed, Apr 04, 2007 at 11:33:52AM -0700, Katie Antypas wrote:
> Hi All,
> We are seeing the 4GiB limitation on variable sizes on the Power 5
> machine Bassi at NERSC.  The last fixed-size variable in a file can be
> larger.  John Shalf's group is also seeing the same limitation, although
> he though he recalled speaking with Rob Ross about how this limitation
> was lifted in recent versions.  Is this the case?
> We are using the latest version 1.0.2pre2 and setting the flag
> NC_64BIT_OFFSET.
Could you double-check that pnetcdf is setting the CDF-2 style
correctly?
$ od -An -c -N4 foo.nc
That command should say "C D F 2"
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
