configuring on AIX
William Gropp gropp at mcs.anl.gov
Mon Sep 4 10:53:51 CDT 2006
The configure needs an upgrade.  What we do in MPICH2 for tests that
normally need to run a program is to use variables of the form
CROSS_<name of thing> to provide these values.  For example,
CROSS_SIZEOF_MPI_OFFSET .  For now, you can set
ac_cv_sizeof_MPI_Offset in your environment, and it *might* work.
Bill
On Sep 4, 2006, at 10:18 AM, Joachim Worringen wrote:
> William Gropp wrote:
>> It looks like the configure step failed to determine the size of
>> an MPI_Offset and then tried to use the null value in the Fortran
>> test (hence the "integer*" test instead of "integer*4" or
>> something).  What did it say for MPI_Offset?
> This test fails with a warning - obviously, as it can not execute
> the MPI executable. How is this generic test supposed to work in a
> specific environment?
>  Joachim
> Joachim Worringen, Software Architect, Dolphin Interconnect Solutions
> phone ++49/(0)228/324 08 17 - http://www.dolphinics.com
