configuring on AIX
Joachim Worringen joachim at dolphinics.com
Mon Sep 4 10:30:50 CDT 2006
Jim Edwards wrote:
> Try configure with the following options
> ./configure --disable-mpi-io-test --disable-fortran
> it seems to fill in the info you need for fortran, but not conduct the
> tests that fail.
Yes, but it also does not build the fortran bindings which I need. And
may get some data types/sizes wrong because of missing MPI-IO tests.
> Also you should change xlc to xlc_r, mpcc to mpcc_r etc.   I think that
> some parts of MPI are only supported in the recurent ( _r) version of
> the compilers.
Thanks, did so.
  Joachim
Joachim Worringen, Software Architect, Dolphin Interconnect Solutions
phone ++49/(0)228/324 08 17 - http://www.dolphinics.com
