configuring on AIX
Joachim Worringen
joachim at dolphinics.com
Mon Sep 4 05:51:04 CDT 2006
I have a problem to configure pnetcdf 1.0.1 on AIX. configure fails with:
./configure
[snip]
checking for Fortran "byte"... yes
checking for Fortran "integer*2"... yes
checking if Fortran "byte" is C "signed char"... yes
checking if Fortran "byte" is C "short"... no
checking if Fortran "byte" is C "int"... no
checking if Fortran "byte" is C "long"... no
checking if Fortran "integer*2" is C "short"... yes
checking if Fortran "integer*2" is C "int"... no
checking if Fortran "integer*2" is C "long"... no
checking if Fortran "integer" is C "int"... yes
checking if Fortran "real" is C "float"... yes
checking if Fortran "doubleprecision" is C "double"... yes
checking for Fortran-equivalent to netCDF "byte"... byte
checking for Fortran-equivalent to netCDF "short"... integer*2
checking for Fortran "integer*"... no
configure: error: F77 does not support "integer*"
The machine is:
j36:parallel-netcdf-1.0.1 [17] uname -a
AIX j36 3 5 00223C3B4C00
Compiler settings:
MPICC=mpcc
MPIF77=mpxlf
CXX=xlC
CC=xlc
FC=xlf
F77=xlf
Is this a known issue?
thanks, Joachim
Joachim Worringen, Software Architect, Dolphin Interconnect Solutions
phone ++49/(0)228/324 08 17 - http://www.dolphinics.com
More information about the parallel-netcdf
