ERROR: 0032-184 on AIX5.3
Robert Latham robl at mcs.anl.gov
Wed Nov 22 15:02:59 CST 2006
On Wed, Nov 22, 2006 at 02:42:13PM -0600, Wei-keng Liao wrote:
> In nf_test.F, there are 2 places MPI_Finalize() is called, lines 333 and
> 518. I can see ud_exit() is also called after MPI_Finalize.
> So, simply putting MPI_Abort() in ud_exit_() is not a good idea. Checking
> the status first is a better one.
> However, for exit status 0, calling MPI_Finalize() and then exit() in
> ud_exit() will result in MPI_Finalize() being called twice in nf_test.F,
> in lines 335, 336, 523, 525 and 526 .
> For exit status 1, line 336 and 526's ud_exit(1) will make MPI_Abort()
> be called after MPI_Finalize(), which is problematic.
> My suggestion is to rewrite nf_test.F for lines 333-336 and lines 522-526.
> Such that those ud_exit(0 or 1) after MPI_Finalize() are replaced by
> exit(0 or 1) directly.
I'm pretty sure I've addressed all these concerns in CVS now. ud_exit
will be the only place calling MPI_Finalize.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
