parallel netCDF question
Daniel S. Katz Daniel.S.Katz at jpl.nasa.gov
Wed Dec 21 16:52:09 CST 2005
I have a parallel code/machine which uses the standard netCDF library to
write data to a single file system NFS-mounted on the compute codes.  As
I got this code, it uses a fairly simple MPI send/recv mechanism
(similar to token passing) to allow output files to be written by
multiple processors in a serialized fashion (each opens, writes, then
closes the file).  This is slow, and bad!
As I don't know the netCDF library well, my first thought is simply to
have all the processors write at once, since they are going to write to
separate parts of the file.  However, depending on how the library does
buffering, this may not work.  (I know it wouldn't work with the cfitsio
package, for example.)  Does anyone know if this will work, will not
work, or will have uncertain behavior?
Assuming that this will not always work, is parallel netCDF the next
choice, even when the file system is question is not a parallel file system?
Any other thoughts or suggestions?
Dan
    Jet Propulsion Laboratory               or d.katz at ieee.org
California Institute of Technology          or dsk at computer.org
        Mail Stop 126-104                 (818) 354-7359 (voice)
       4800 Oak Grove Drive                (818) 393-6141 (fax)
     Pasadena, CA  91109-8099       http://pat.jpl.nasa.gov/public/dsk/
