pnetcdf question
Rob Ross
rross at mcs.anl.gov
Fri Mar 19 11:07:21 CST 2004
James,
Bill's note here is right on the mark, and this is actually very similar
to the issue that Roger Ting brought up just a little while ago. You're
much better off doing a little communication to get the offsets right and
then performing a collective I/O operation.
Rob
On Thu, 18 Mar 2004, William Gropp wrote:
> At 01:59 PM 3/18/2004, Foucar, James G wrote:
> >Hi Rob, thanks for the reply. i was thinking along the same lines. the
> >reason i am hestitant to do the:
> >array 1: 1a 1b 1c 2a 3a 3b 3c 3d 4a 4b 4c
> >array 2: 3 1 4 3
> >implementation is because it will require communication between the
> >processors to figure out what offset they should be writing to. so, right
> >now i am leaning towards separate variables per process. this will require
> >me to enter "independent data mode", correct? will this cause me to take a
> >performance hit?
> If all you need to do is to compute the offset, the MPI_Scan routine will
> do this fairly efficiently (if you have a good implementation). If you
> have an MPI-2 implementation, MPI_Exscan is a closer match to what you
> need. The communication cost should be small relative to the I/O cost.
> Bill
More information about the parallel-netcdf
