precision woes
Joachim Worringen
joachim at ccrl-nece.de
Fri Jan 30 04:15:53 CST 2004
Some more SX test results: running the tests 'nf_test' and 'nc_test' on SX-6
systems reported a lot of errors.
After being quite sure that our MPI-IO is alright and testing on Linux IA-32,
I assumed that there may be some 32/64 bit issues, probably in the test
programs themselves. Here we go - the proposed fixes worked for me, but maybe
won't work for others (?), although I do not see why this could be the case.
- test/nc_test/test_get.c and test_put.c: ptrdiff_t is used to pass arrays of
size_t values to pnetcdf -> on SX, ptrdiff_t is 64bit, while size_t is 32 bit
Fix: replace all ptrdiff_t by size_t
- pnetcdf.h: defines NC_UNLIMITED to '0L' - this is 64bit on SX, but is passed
as 32-bit size_t value
Fix: define to 0, not 0L
- test/nf_test/test_put.F: in the functions hash_real(), check_vars_real() and
check_atts_real(), I had to replace the 'doubleprecision' declarations by
'real' to avoid (bogus!?) error messages. I am not Fortran-expert, though,
and am still wondering why these 'doubleprecision' declarations do not cause
such problems in functions like check_vars_int().
I still have some numerical issues in the testing of real values, though:
*** Testing nfmpi_put_att_real ...
Numeric conversion not representable
att. value read not that expected
varid: 0
att_name: Gd
element number: 3
expect: -7.812501848093234D-03
got: -7.812500000000000D-03
2 good comparisons.
### 43 FAILURES TESTING nfmpi_put_att_real! ###
The related test in nc_test does not cause these problems. Any hints? I guess
it's related to the SX-f90 compiler, though.
What about these tests on other 64-bit platforms - anybody?
Joachim
Joachim Worringen - NEC C&C research lab St.Augustin
fon +49-2241-9252.20 - fax .99 - http://www.ccrl-nece.de
More information about the parallel-netcdf
