problem in pnetcdf.h
Rob Ross
rross at mcs.anl.gov
Sat Feb 7 02:25:28 CST 2004
Hi James,
Yes; I have fixed this in CVS and have attached a patch. Please let us
know if this does or does not cover things for you, or if you have other
issues.
Rob
On Fri, 6 Feb 2004, Foucar, James G wrote:
> Hello, I think there may be a bug in the pnetcdf.h file. I was getting link
> errors due to name mangling in a project using c++. Shouldn't the extern C
> cover the entire file instead of ending on line 201?
> -James Foucar
Index: src/lib/pnetcdf.h
RCS file: /home/gropp/cvsMaster_z/parallel-netcdf/src/lib/pnetcdf.h,v
retrieving revision 1.6
diff -r1.6 pnetcdf.h
200,203d199
< #if defined(__cplusplus)
< #endif
923a920,924
> #endif
More information about the parallel-netcdf
