I mean independent open
William Gropp
gropp at mcs.anl.gov
Fri Feb 6 09:22:38 CST 2004
At 11:35 PM 2/5/2004, Roger Ting wrote:
>Sorry mistake. I mean independent open.
The collective open and collective read/write provide the basis for much of
the performance advantage that pnetcdf has over non-collective
approaches. For individual processes accessing files, there is
MPI_COMM_SELF, as Rob mentions. If you want an arbitrary collection of
processes to access the file, without any a priori coordination (which
collective open gives you), you open Pandora's box of difficult
synchronization and consistency issues. In such cases, it might make more
sense to use a two stage process, where each process writes a separate file
(thus eliminating any consistency issues) together with metadata about what
it wrote, followed by a step that uses collective I/O calls to assemble a
single netCDF file with maximum efficiency.
Bill
>On Fri, 2004-02-06 at 16:32, Roger Ting wrote:
> > Hi
> > It seems to be a pity that parallel netcdf doesn't support collective
> > open. It is useful in complex situation when you cannot anticipate which
> > processor and when will a netcdf file is opened.
> > Any way around this problem beside using a semaphore or condition
> > variable?
> > Roger
More information about the parallel-netcdf
