0.9.3 installation problems on GNU/Linux with lam-mpi
Drake, Richard R
rrdrake at sandia.gov
Tue Feb 3 09:18:37 CST 2004
FYI .. I did the exact same thing. I wondered/wonder if the pnetcdf
developers -- being MPICH guys -- are much concerned or if they just don't
have the resources at this time.
-rich
Sandia National Laboratories
505-844-2537
-----Original Message-----
From: Raimondo Giammanco [mailto:rongten at member.fsf.org]
Sent: Tuesday, February 03, 2004 7:44 AM
To: parallel-netcdf at mcs.anl.gov
Subject: 0.9.3 installation problems on GNU/Linux with lam-mpi
Hello,
I tried to install 0.9.3 on a GNU/Linux PC with lam-mpi-7.0.2, and I am
having the following problem:
1) autoconf
2) ./configure --prefix=SOME_PATH --with-mpi=/usr
3) make all
It returns in src/lib
mpinetcdf.c: In function `length_of_mpitype':
mpinetcdf.c:382: switch quantity not an integer
mpinetcdf.c:383: pointers are not permitted as case values
mpinetcdf.c:383: case label does not reduce to an integer constant
mpinetcdf.c:384: pointers are not permitted as case values
mpinetcdf.c:384: case label does not reduce to an integer constant
mpinetcdf.c:386: pointers are not permitted as case values
mpinetcdf.c:386: case label does not reduce to an integer constant
mpinetcdf.c:388: pointers are not permitted as case values
mpinetcdf.c:388: case label does not reduce to an integer constant
mpinetcdf.c:390: pointers are not permitted as case values
mpinetcdf.c:390: case label does not reduce to an integer constant
mpinetcdf.c:392: pointers are not permitted as case values
mpinetcdf.c:392: case label does not reduce to an integer constant
mpinetcdf.c:394: pointers are not permitted as case values
mpinetcdf.c:394: case label does not reduce to an integer constant
############### etc. etc. where there is the swith(datatype) command.
I looked a little in /usr/include mpi.h of lam, and
I tried to substitute the switches with a series of ifs.
I was able to compile, but I received a series of errors
in make testing.
Before submitting the details, I was wondering if this
is an implementation problem of lam, or there is some
other reason behind this strange behavior.
Is there anybody using lam-mpi and that can give me some pointers?
Best Regards
Raimondo Giammanco <rongten at member.fsf.org>
More information about the parallel-netcdf
