newbie errors
Rob Ross rross at mcs.anl.gov
Tue Apr 6 09:44:07 CDT 2004
What machine and MPI are you using here?  You should be including an MPI
header too; that might be the cause (or you might have just neglected to
include that).
Rob
On Tue, 6 Apr 2004 jabencke at ncsu.edu wrote:
> I'm not sure what's causing the errors I'm having, listed below.  I'm
> trying to baby step here and just create the file to start things off.
> Below the errors is the code that causes the problem.  It's repeated 8
> times because it's an 8 processor test job.  Any help would be fantastic.
>  Can not open/create file
> -1073749200: MPI_File_open error = Intercommunicator is not allowed
> -1073746896: MPI_File_open error = Intercommunicator is not allowed
> -1073751120: MPI_File_open error = Intercommunicator is not allowed
> -1073747536: MPI_File_open error = Intercommunicator is not allowed
> -1073749456: MPI_File_open error = Intercommunicator is not allowed
> -1073746512: MPI_File_open error = Intercommunicator is not allowed
> -1073750224: MPI_File_open error = Intercommunicator is not allowed
> -1073747248: MPI_File_open error = Intercommunicator is not allowed
> Code here:
>       subroutine prin(prefix)
> ! Outputs ascii array if ndim = 1, else if ndim > 1 then
> ! write out hdf5 data file containing all variables (plus time).
>       include 'pnetcdf.inc'
>       include 'global.h'
>       include 'sweep.h'
>       include 'zone.h'
>       ! integer(HID_T) :: hdf_file !file id for hdf file
>       integer :: hdf_error !error var for hdf5 file
>       character(LEN=1) :: char
>       character(LEN=1) :: coord
>       character(LEN=4) :: tmp1, tmp2
>       character(LEN=5) :: prefix
>       character(LEN=15) :: filename
> !     Added (Fortran 90 style) for hdf5 stuff
>       ! INTEGER(HID_T) :: dsp_id  ! Dataspace ID
>       ! INTEGER(HID_T) :: dset_id !Dataset ID
>       INTEGER, DIMENSION(3) :: dims
>       INTEGER, DIMENSION(3) :: dimids
>       INTEGER :: status, ncid
>       INTEGER :: xDimID, yDimID, zDimID
>       INTEGER :: yMaxDimID, tsDimID
>       INTEGER :: density_varID, pressure_varID
>       INTEGER :: XVelocity_varID, YVelocity_varID, ZVelocity_varID
>       INTEGER :: XScale_varID, YScale_varID, ZScale_varID, time_varID
> ! Create filename from integer nfile (in global.h) and prefix such that
> filename
> ! looks like prefx.1000 where 1000 is the value of nfile
>       write(tmp1,910) nfile
>       write(tmp2,910) mype
>  910  format(i4)
>       do i = 1, 4
>          if ((tmp1(i:i)) .eq. ' ') tmp1(i:i) = '0'
>          if ((tmp2(i:i)) .eq. ' ') tmp2(i:i) = '0'
>       enddo
>       filename = prefix(1:5) // '_' // tmp1(1:4) // '.' // tmp2(1:4)
>       nfile = nfile + 1
>       if (ndim .eq. 1) then
> ! Keep 1D output simple, just write out in ascii...
>         open(unit=3,file=filename,form='formatted')
>         do i = 1, imax
>           write(3, 1003) zxa(i), zro(i,1,1),zpr(i,1,1), zux(i,1,1)
>         enddo
>         close(3)
>       else
> !     Initialize Dimensions
>       dims(1) = imax
>       dims(2) = js
>       if(ndim.eq.3) dims(3) = kmax
>       status = nfmpi_create(MPI_COMM_WORLD, filename,
>      &                      MPI_INFO_NULL, nf90_Clobber, ncid)
>       if (status /= nf90_NoErr ) print *, nfmpi_strerror(status)
>       ! always a necessary statment to flush output
>       status = nfmpi_close(ncid)
>       endif
>       write(8,6000) filename, time, ncycle
>  6000 format('Wrote ',a10,' to disk at time =',1pe12.5,' (ncycle =',
>      &        i6,')')
>  1003 format(' ',4e13.5)
>       return
>       end
