first success story on NEC SX
Jianwei Li jianwei at cheetah.cpdc.ece.nwu.edu
Wed Jul 30 10:17:41 CDT 2003
On Wed, 30 Jul 2003, rene.redler wrote:
Rene,
	Thank you for your information! It is very helpful!
> Hello,
>   after some Makefile editing tests ran successfully on a SX.
> MPIF77=mpif90
> MPICC=mpic++
> CC=c++
> CXX=c++
> ARFLAGS=r
> Makefile.in in directory /src/lib
> #       v1hpg.c
> #       ncio.c \
> #       putget.c \
> PACKING_LIST = \
> causes the whole PACKING_LIST to be in the comment line as well
> same for
> #       onstack.h \
> LIB_OBJS = $(LIB_CSRCS:.c=.o)
> I needed to eliminate the backslashes after putget.c and onesteck.h.
> make and make install worked fine with these modifications.
	I think you did the right thing. We should eliminate the
        backslashes at the end of each commented line.
	Jianwei
