parallel netcdf - first experiences
rene.redler
redler at ccrl-nece.de
Mon Jul 28 09:44:54 CDT 2003
Hello,
I recently (today) subscribed to parallel-netCDF mailing list, so I
apologies in advance for taking your time if I rise any topic that has
already been discussed.
I started with the latest version 0.8.6 and tried to install the library on
a NEC SX6. Doing this on a SX6 itself would have resulted in some changes
of the Makefile.in due to different behavior of make (-C is not supported
there and install, and some other odd things.) I then started working with
the cross compiler which was not possible with release 0.8.4 which I
tested last week due to the fact that the previous release needed to run
executables during the configure (or make) phase.
I needed to define the following environment variables
setenv MPIF77 sxmpif90
setenv MPICC sxmpic++
setenv AR sxar
setenv RANLIB :
Running configure and make worked fine.
When trying to create the test cases I recognized that mpinetcdf.c tries
to call MPI_Type_create_vector which I guess is not part of the MPI2
standard. Are there any plans to to add this function to the MPI2 in
future? I also could not find this function in the mpich-1.2.5 release.
Comments are welcome.
As a first check whether everything worked I used e.g.
ncvalid parallel-netcdf-0.8.6/test/data/test_double.nc
which resulted in no output. From a brief look into validate.c I got the
impression that this could be a good sign.
Nevertheless trying to test_read the netCDF files failed, and the ncmpi
routines returned and invalid id or dimension. Did anyone encounter a
similar behavior on any other architecture?
Another question related to parallel netCDF for climate system modeling:
Is any subscriber of this mailing list working for or in close contact
with the ESMF (Earth System Modeling Framework) or the European PRISM
project (Program for Integrated Earth System Modeling)? If so, I would be
happy to get into contact to discus the impact of the parallel netCDF on
ongoing or planned activities.
Thank you very much for your attention,
Rene Redler
_______________________________________________________________
C&C Research Laboratories
NEC Europe Ltd. Tel: +49 (0)2241 925240
Rathausallee 10 Fax: +49 (0)2241 925299
53757 Sankt Augustin URL: www.ccrl-nece.de/~redler
More information about the parallel-netcdf
