Compilation error on Alpha (Tru64)
William Gropp gropp at mcs.anl.gov
Wed Aug 20 07:44:35 CDT 2003
At 01:46 PM 8/20/2003 +0930, Milton Woods wrote:
>Greetings,
>On a Compaq Alphaserver using the Tru64 compilers, the configure script
>aborts with the following message:
>checking whether size_t and int size match... no
>configure: error: This is a critical error; please report this size
>mismatch to the developers!
>It appears that size_t is 64 bit while int is 32 bit. There is no obvious
>way to change this. Any suggestions?
We have a fix for this that we're testing for the next release.  The issue
only affects the Fortran bindings in any case, and we have also added a
switch to turn off tests in the configure that only apply to the Fortran
version.
Bill
