Houston, we have a problem
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Mon Aug 4 13:07:21 CDT 2003
John,
Thanks for actively testing this new release!
> Jianwei,
> I finally loaded up 0.8.9 and ran with it. My run of the Fortran test
> code appears to put out exactly the same results that you got, except
> that my read/write times are all zero? This also leads to a couple of
You mean both header I/O (define) time and data I/O time are zero?
Is that possible while your data is actually written out?
//I'll try another run later to see what's going on...
> INF values being output (/0). My netCDF output appears to be the same
> as yours, but it does not match the C test code output? The C output
> starts 0.001, 0.002, 0.003, ... The Fortran output starts 65.794,
> 65.795, 65.796, ... Could be a problem with my test code? I was kind
This is definitely due to difference of your C test and F test:)
I checked it, in the Get_Field tri-loop, your F index start
from 1, while your C index start from 0, being multipiled by 256
makes them so different:)
> of hoping that somehow the Fortran results were just reversed, but this
> does not appear to be the case.
It is not reversed because you have taken care of the dimension
ordering problem explictly in your F code (in Get_Field subrout).
Don't worry, I'll send out another email talking about this.
I think it's not a big problem.
Jianwei
> Regards,
> John
> Jianwei Li wrote:
> > OK. I got the full output from my test after I made those modifications
> > to the fortran binding code.
> > The result seems good?
> > standard output:
> > mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
> > 0 0 0 0 256 256 256 16 256 256 0 0 0
> > 1 1 0 0 256 256 256 16 256 256 16 0 0
> > 3 3 0 0 256 256 256 16 256 256 48 0 0
> > 4 4 0 0 256 256 256 16 256 256 64 0 0
> > 7 7 0 0 256 256 256 16 256 256 112 0 0
> > 2 2 0 0 256 256 256 16 256 256 32 0 0
> > 5 5 0 0 256 256 256 16 256 256 80 0 0
> > 6 6 0 0 256 256 256 16 256 256 96 0 0
> > 8 8 0 0 256 256 256 16 256 256 128 0 0
> > 9 9 0 0 256 256 256 16 256 256 144 0 0
> > 11 11 0 0 256 256 256 16 256 256 176 0 0
> > 14 14 0 0 256 256 256 16 256 256 224 0 0
> > 10 10 0 0 256 256 256 16 256 256 160 0 0
> > 12 12 0 0 256 256 256 16 256 256 192 0 0
> > 13 13 0 0 256 256 256 16 256 256 208 0 0
> > 15 15 0 0 256 256 256 16 256 256 240 0 0
> > write 1: 1.312E+00 1.562E+00
> > write 2: 1.000E+00 1.188E+00
> > write 3: 8.750E-01 1.438E+00
> > write 4: 8.125E-01 1.062E+00
> > write 5: 8.125E-01 1.000E+00
> > read 1: 1.250E-01 3.750E-01
> > diff, delmax, delmin = 0.000E+00 0.000E+00 0.000E+00
> > read 2: 1.250E-01 5.000E-01
> > read 3: 1.250E-01 3.750E-01
> > read 4: 2.500E-01 3.750E-01
> > read 5: 1.250E-01 5.000E-01
> > File size: 1.342E+02 MB
> > Write: 134.218 MB/s (eff., 74.051 MB/s)
> > Read : 357.914 MB/s (eff., 268.435 MB/s)
> > Total number PEs: 16
> > 8.125E-01 1.000E+00 74.051 1.250E-01 3.750E-01 268.435
> > ncdump pnf_test.nc | more
> > netcdf pnf_test {
> > dimensions:
> > level = 256 ;
> > latitude = 256 ;
> > longitude = 256 ;
> > variables:
> > float tt(level, latitude, longitude) ;
> > data:
> > tt =
> > 65.794, 65.795, 65.796, 65.797, 65.798, 65.799, 65.8, 65.801, 65.802,
> > 65.803, 65.804, 65.805, 65.806, 65.807, 65.808, 65.809, 65.81, 65.811,
> > 65.812, 65.813, 65.814, 65.815, 65.816, 65.817, 65.818, 65.819, 65.82,
> > 65.821, 65.822, 65.823, 65.824, 65.825, 65.826, 65.827, 65.828, 65.829,
> > 65.83, 65.831, 65.832, 65.833, 65.834, 65.835, 65.836, 65.837, 65.838,
> > 65.839, 65.84, 65.841, 65.842, 65.843, 65.844, 65.845, 65.846, 65.847,
> > 65.848, 65.849, 65.85, 65.851, 65.852, 65.853, 65.854, 65.855, 65.856,
> > 65.857, 65.858, 65.859, 65.86, 65.861, 65.862, 65.863, 65.864, 65.865,
> > 65.866, 65.867, 65.868, 65.869, 65.87, 65.871, 65.872, 65.873, 65.874,
> > 65.875, 65.876, 65.877, 65.878, 65.879, 65.88, 65.881, 65.882, 65.883,
> > 65.884, 65.885, 65.886, 65.887, 65.888, 65.889, 65.89, 65.891, 65.892,
> > 65.893, 65.894, 65.895, 65.896, 65.897, 65.898, 65.899, 65.9, 65.901,
> > 65.902, 65.903, 65.904, 65.905, 65.906, 65.907, 65.908, 65.909, 65.91,
> > 65.911, 65.912, 65.913, 65.914, 65.915, 65.916, 65.917, 65.918, 65.919,
> > 65.92, 65.921, 65.922, 65.923, 65.924, 65.925, 65.926, 65.927, 65.928,
> > 65.929, 65.93, 65.931, 65.932, 65.933, 65.934, 65.935, 65.936, 65.937,
> > 65.938, 65.939, 65.94, 65.941, 65.942, 65.943, 65.944, 65.945, 65.946,
> > 65.947, 65.948, 65.949, 65.95, 65.951, 65.952, 65.953, 65.954, 65.955,
> > 65.956, 65.957, 65.958, 65.959, 65.96, 65.961, 65.962, 65.963, 65.964,
> > 65.965, 65.966, 65.967, 65.968, 65.969, 65.97, 65.971, 65.972, 65.973,
> > 65.974, 65.975, 65.976, 65.977, 65.978, 65.979, 65.98, 65.981, 65.982,
> > 65.983, 65.984, 65.985, 65.986, 65.987, 65.988, 65.989, 65.99, 65.991,
> > 65.992, 65.993, 65.994, 65.995, 65.996, 65.997, 65.998, 65.999, 66,
> > 66.001, 66.002, 66.003, 66.004, 66.005, 66.006, 66.007, 66.008, 66.009,
> > 66.01, 66.011, 66.012, 66.013, 66.014, 66.015, 66.016, 66.017, 66.018,
> > 66.019, 66.02, 66.021, 66.022, 66.023, 66.024, 66.025, 66.026, 66.027,
> > 66.028, 66.029, 66.03, 66.031, 66.032, 66.033, 66.034, 66.035, 66.036,
> > 66.037, 66.038, 66.039, 66.04, 66.041, 66.042, 66.043, 66.044, 66.045,
> > 66.046, 66.047, 66.048, 66.049,
> > Jianwei
> > On Fri, 1 Aug 2003, Jianwei Li wrote:
> >>I think I know where the problem is now, after looking into the
> >>fortran binding code as a "human":)
> >>The automatic fortran binding is mistaking (*start)[], (*count)[],
> >>and (*stride)[] as *start[], *count[], *stride[].
> >>After changing the fortran binding interface code from
> >> FORTRAN_API void FORT_CALL nfmpi_put_vara_float_all_ ( int *v1, int *v2,
> >> int * v3[], int * v4[], float*v5, MPI_Fint *ierr ){
> >> *ierr = ncmpi_put_vara_float_all( *v1, *v2, (const size_t *)(*v3),
> >> (const size_t *)(*v4), v5 );
> >>to
> >> int (* v3)[], int (* v4)[], float*v5, MPI_Fint *ierr ){
> >>in file "parallel-netcdf-0.8.8/src/libf/put_vara_float_allf.c"
> >>and doing the same thing to other fortran binding functions that need to
> >>deal with start[], count[], stride[],
> >>I got the fortran test running successfully.
> >>And that's why the original ones fails only for put_vara/get_vara:)
> >>Another way may be just using **start, **count, **stride?
> >>But I don't know how to modify these automatically :(
> >>This is the netcdf data file generated, running with 8 processes:
> >>netcdf pnf_test {
> >>dimensions:
> >> level = 256 ;
> >> latitude = 256 ;
> >> longitude = 256 ;
> >>variables:
> >>data:
> >> tt =
> >>And the standard output looks like:
> >>poe pnf_test -nodes 1 -tasks_per_node 8 -rmpool 1 -euilib ip -euidevice en0
> >> 0 0 0 0 256 256 256 32 256 256 0 0 0
> >> 1 1 0 0 256 256 256 32 256 256 32 0 0
> >> 2 2 0 0 256 256 256 32 256 256 64 0 0
> >> 3 3 0 0 256 256 256 32 256 256 96 0 0
> >> 4 4 0 0 256 256 256 32 256 256 128 0 0
> >> 5 5 0 0 256 256 256 32 256 256 160 0 0
> >> 6 6 0 0 256 256 256 32 256 256 192 0 0
> >> 7 7 0 0 256 256 256 32 256 256 224 0 0
> >>write 1: 0.000E+00 7.040E+02
> >>... It's still running, and I'll post the full output later and confirm
> >>that my thought:)
> >>Jianwei
> >>On Thu, 31 Jul 2003, John Tannahill wrote:
> >>>Jianwei,
> >>>This is what I was suspecting as well.
> >>>John
> >>>Jianwei Li wrote:
> >>>>I think I was wrong after a careful look at the standard output.
> >>>>operation header I/O time data I/O time
> >>>>write 2: 1.250E-01 0.000E+00
> >>>>read 2: 6.250E-02 0.000E+00
> >>>>It seems that Nfmpi_Put_Vara_Float_All/Nfmpi_Get_Vara_Float_All
> >>>>are not running properly in this case.
> >>>>We should look in more details for problems ...
> >>>>Jianwei
> >>>>On Thu, 31 Jul 2003, Jianwei Li wrote:
> >>>>>John,
> >>>>>I had a quick run of your attached fortran code using pnetcdf0.8.8
> >>>>>on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
> >>>>>and genterate these outputs:
> >>>>>standard output:
> >>>>>write 1: 2.500E-01 6.250E-02
> >>>>>write 3: 1.250E-01 6.250E-02
> >>>>>write 4: 1.875E-01 0.000E+00
> >>>>>write 5: 1.250E-01 0.000E+00
> >>>>>read 1: 6.250E-02 0.000E+00
> >>>>>diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
> >>>>>read 3: 6.250E-02 0.000E+00
> >>>>>read 4: 6.250E-02 0.000E+00
> >>>>>read 5: 6.250E-02 0.000E+00
> >>>>> Write: INF MB/s (eff., 1073.742 MB/s)
> >>>>> Read : INF MB/s (eff., 2147.484 MB/s)
> >>>>> 1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
> >>>>>netcdf file <pnf_test.nc>:
> >>>>>netcdf pnf_test {
> >>>>>dimensions:
> >>>>> level = 256 ;
> >>>>> latitude = 256 ;
> >>>>> longitude = 256 ;
> >>>>>variables:
> >>>>>data:
> >>>>>tt =
> >>>>> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>0,
> >>>>>I think it's a successful run, right?
> >>>>>So what? Is it the Fortran Binding problem specially related to the Frost
> >>>>>platform? or something else?
> >>>>>btw, I build my pnetcdf lib as below and maybe you want to try this:
> >>>>>setenv CC xlc
> >>>>>setenv FC xlf
> >>>>>setenv F90 xlf90
> >>>>>setenv CXX xlC
> >>>>>setenv FFLAGS '-d -O2'
> >>>>>setenv MPICC mpcc_r
> >>>>>setenv MPIF77 mpxlf_r
> >>>>>#make
> >>>>>#make install
> >>>>>//what else can I do?:)
> >>>>>Jianwei
> >>>>>>Rob,
> >>>>>>I am hoping that I can catch you before you leave, so that you can
> >>>>>>pass this on to someone, but if you are already gone, can anyone
> >>>>>>else take a look at this?
> >>>>>>I have graduated up to my original bigger test case and the C version
> >>>>>>works, but the Fortran version doesn't. It's certainly possible that
> >>>>>>I have screwed up the translation from C to Fortran and I will be
> >>>>>>looking at that, but I wanted to pass this back to you folks, so that
> >>>>>>you can take a look at it to.
> >>>>>>I am using 0.8.8. Attached are two tar files that should be pretty
> >>>>>>self-explanatory, but let me know if you have questions.
> >>>>>>Regards,
> >>>>>>John
> >>>>>>John R. Tannahill
> >>>>>>Lawrence Livermore Nat. Lab.
> >>>>>>P.O. Box 808, M/S L-103
> >>>>>>Livermore, CA 94551
> >>>>>>925-423-3514
> >>>>>>Fax: 925-423-4908
> >>>John R. Tannahill
> >>>Livermore, CA 94551
> >>>925-423-3514
> >>>Fax: 925-423-4908
> John R. Tannahill
> Livermore, CA 94551
> 925-423-3514
> Fax: 925-423-4908
More information about the parallel-netcdf
