pnetcdf 0.8.8 release
Robert Latham robl at mcs.anl.gov
Fri Aug 1 11:32:30 CDT 2003
On Wed, Jul 30, 2003 at 05:31:11PM -0500, Rob Ross wrote:
> Hello,
> I've put up version 0.8.8.  Major changes include a big cleanup in the
> test directory and fixes to the makefiles to address issues on the NEC and
> AIX platforms.  Hopefully make; make install; make tests will just work
> now.  A configure script is included, so you don't need to run autoconf.
> I did not get to Tyce's fixes for the Fortran test yet.  This might end up
> waiting until RobL and Jianwei work on this.  Probably matters less now
> that John has some things working, but I still want to get it fixed.
> I haven't tried an out-of-tree build lately, so I don't know if this is
> working.  I will check that out soon and make sure it's still ok.
an out-of-tree build works fine for me on a system where $INSTALL is
/usr/bin/install.  Just needed to give the chmod line in configure.in
the full path to install-sh.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Labs, IL USA                B29D F333 664A 4280 315B
