Houston, we have a problem
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Fri Aug 1 11:28:41 CDT 2003
I think I know where the problem is now, after looking into the
fortran binding code as a "human":)
The automatic fortran binding is mistaking (*start)[], (*count)[],
and (*stride)[] as *start[], *count[], *stride[].
After changing the fortran binding interface code from
FORTRAN_API void FORT_CALL nfmpi_put_vara_float_all_ ( int *v1, int *v2,
int * v3[], int * v4[], float*v5, MPI_Fint *ierr ){
*ierr = ncmpi_put_vara_float_all( *v1, *v2, (const size_t *)(*v3),
(const size_t *)(*v4), v5 );
to
int (* v3)[], int (* v4)[], float*v5, MPI_Fint *ierr ){
in file "parallel-netcdf-0.8.8/src/libf/put_vara_float_allf.c"
and doing the same thing to other fortran binding functions that need to
deal with start[], count[], stride[],
I got the fortran test running successfully.
And that's why the original ones fails only for put_vara/get_vara:)
Another way may be just using **start, **count, **stride?
But I don't know how to modify these automatically :(
This is the netcdf data file generated, running with 8 processes:
ncdump pnf_test.nc | more
netcdf pnf_test {
dimensions:
level = 256 ;
latitude = 256 ;
longitude = 256 ;
variables:
float tt(level, latitude, longitude) ;
data:
tt =
65.794, 65.795, 65.796, 65.797, 65.798, 65.799, 65.8, 65.801, 65.802,
65.803, 65.804, 65.805, 65.806, 65.807, 65.808, 65.809, 65.81, 65.811,
65.812, 65.813, 65.814, 65.815, 65.816, 65.817, 65.818, 65.819, 65.82,
65.821, 65.822, 65.823, 65.824, 65.825, 65.826, 65.827, 65.828, 65.829,
65.83, 65.831, 65.832, 65.833, 65.834, 65.835, 65.836, 65.837, 65.838,
65.839, 65.84, 65.841, 65.842, 65.843, 65.844, 65.845, 65.846, 65.847,
65.848, 65.849, 65.85, 65.851, 65.852, 65.853, 65.854, 65.855, 65.856,
65.857, 65.858, 65.859, 65.86, 65.861, 65.862, 65.863, 65.864, 65.865,
65.866, 65.867, 65.868, 65.869, 65.87, 65.871, 65.872, 65.873, 65.874,
And the standard output looks like:
poe pnf_test -nodes 1 -tasks_per_node 8 -rmpool 1 -euilib ip -euidevice en0
mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
0 0 0 0 256 256 256 32 256 256 0 0 0
1 1 0 0 256 256 256 32 256 256 32 0 0
2 2 0 0 256 256 256 32 256 256 64 0 0
3 3 0 0 256 256 256 32 256 256 96 0 0
4 4 0 0 256 256 256 32 256 256 128 0 0
5 5 0 0 256 256 256 32 256 256 160 0 0
6 6 0 0 256 256 256 32 256 256 192 0 0
7 7 0 0 256 256 256 32 256 256 224 0 0
write 1: 0.000E+00 7.040E+02
... It's still running, and I'll post the full output later and confirm
that my thought:)
Jianwei
On Thu, 31 Jul 2003, John Tannahill wrote:
> Jianwei,
> This is what I was suspecting as well.
> John
> Jianwei Li wrote:
> > I think I was wrong after a careful look at the standard output.
> > operation header I/O time data I/O time
> > write 2: 1.250E-01 0.000E+00
> > read 2: 6.250E-02 0.000E+00
> > It seems that Nfmpi_Put_Vara_Float_All/Nfmpi_Get_Vara_Float_All
> > are not running properly in this case.
> > We should look in more details for problems ...
> > Jianwei
> > On Thu, 31 Jul 2003, Jianwei Li wrote:
> >>John,
> >>I had a quick run of your attached fortran code using pnetcdf0.8.8
> >>on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
> >>and genterate these outputs:
> >>standard output:
> >> 0 0 0 0 256 256 256 16 256 256 0 0 0
> >> 1 1 0 0 256 256 256 16 256 256 16 0 0
> >> 13 13 0 0 256 256 256 16 256 256 208 0 0
> >> 2 2 0 0 256 256 256 16 256 256 32 0 0
> >> 8 8 0 0 256 256 256 16 256 256 128 0 0
> >> 5 5 0 0 256 256 256 16 256 256 80 0 0
> >> 9 9 0 0 256 256 256 16 256 256 144 0 0
> >> 6 6 0 0 256 256 256 16 256 256 96 0 0
> >> 10 10 0 0 256 256 256 16 256 256 160 0 0
> >> 4 4 0 0 256 256 256 16 256 256 64 0 0
> >> 11 11 0 0 256 256 256 16 256 256 176 0 0
> >> 12 12 0 0 256 256 256 16 256 256 192 0 0
> >> 14 14 0 0 256 256 256 16 256 256 224 0 0
> >> 15 15 0 0 256 256 256 16 256 256 240 0 0
> >> 3 3 0 0 256 256 256 16 256 256 48 0 0
> >> 7 7 0 0 256 256 256 16 256 256 112 0 0
> >>write 1: 2.500E-01 6.250E-02
> >>write 3: 1.250E-01 6.250E-02
> >>write 4: 1.875E-01 0.000E+00
> >>write 5: 1.250E-01 0.000E+00
> >> read 1: 6.250E-02 0.000E+00
> >>diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
> >> read 3: 6.250E-02 0.000E+00
> >> read 4: 6.250E-02 0.000E+00
> >> read 5: 6.250E-02 0.000E+00
> >>File size: 1.342E+02 MB
> >> Write: INF MB/s (eff., 1073.742 MB/s)
> >> Read : INF MB/s (eff., 2147.484 MB/s)
> >>Total number PEs: 16
> >> 1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
> >>netcdf file <pnf_test.nc>:
> >>netcdf pnf_test {
> >>dimensions:
> >> level = 256 ;
> >> latitude = 256 ;
> >> longitude = 256 ;
> >>variables:
> >>data:
> >> tt =
> >> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>0,
> >>I think it's a successful run, right?
> >>So what? Is it the Fortran Binding problem specially related to the Frost
> >>platform? or something else?
> >>btw, I build my pnetcdf lib as below and maybe you want to try this:
> >>setenv CC xlc
> >>setenv FC xlf
> >>setenv F90 xlf90
> >>setenv CXX xlC
> >>setenv FFLAGS '-d -O2'
> >>setenv MPICC mpcc_r
> >>setenv MPIF77 mpxlf_r
> >>#make
> >>#make install
> >>//what else can I do?:)
> >>Jianwei
> >>>Rob,
> >>>I am hoping that I can catch you before you leave, so that you can
> >>>pass this on to someone, but if you are already gone, can anyone
> >>>else take a look at this?
> >>>I have graduated up to my original bigger test case and the C version
> >>>works, but the Fortran version doesn't. It's certainly possible that
> >>>I have screwed up the translation from C to Fortran and I will be
> >>>looking at that, but I wanted to pass this back to you folks, so that
> >>>you can take a look at it to.
> >>>I am using 0.8.8. Attached are two tar files that should be pretty
> >>>self-explanatory, but let me know if you have questions.
> >>>Regards,
> >>>John
> >>>John R. Tannahill
> >>>Lawrence Livermore Nat. Lab.
> >>>P.O. Box 808, M/S L-103
> >>>Livermore, CA 94551
> >>>925-423-3514
> >>>Fax: 925-423-4908
> John R. Tannahill
> Livermore, CA 94551
> 925-423-3514
> Fax: 925-423-4908
More information about the parallel-netcdf
