Now nc_test PASSES
Jianwei Li
jianwei at pop.ece.nwu.edu
Wed Apr 2 14:32:23 CST 2003
Good news.
Now nc_test can pass successfully except 2 FAILUREs that depend on how
to report errors.
In addition to those problems I reported last time (2 weeks ago?), I
figured out a couple of more problems summarized as follows:
1. In read/write of the header part, there are some bugs in dealing
with attribute values, like padding for 4-byte-alignment. Now I've
fixed them.
2. In nc_test code, I think rob had disabled some test code in earlier
stage of debugging. After enabling those necessary for generating
correct&expected "scratch.nc", the errors are gone.
I have committed my modifications into cvs, and files that are affected
this time are:
parallel-netcdf/src/lib/header.c
parallel-netcdf/src/lib/nc.h
parallel-netcdf/test/nc_test/nc_test.c
parallel-netcdf/test/nc_test/test_get.m4
parallel-netcdf/test/nc_test/test_put.m4
parallel-netcdf/test/nc_test/test_write.c
Now, what are left in nc_test are tests of "put/get schar/uchar/long",
which have not been included in current library implementation, I'll
add those functions when I have time. For now, everything looks good?
Jianwei
More information about the parallel-netcdf
