[opa-nightly-tests] jelly OPA_Daily_Tests_0127Sat
hdftest hdftest at hdfgroup.org
Sat Jan 27 23:59:43 CST 2024
*** OPA Tests on 0127Sat ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 45s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 6s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 23s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  20m 42s
   Timekeeper log
Timekeeper started at Sat Jan 27 23:39:13 CST 2024
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Sat Jan 27 23:59:13 CST 2024, looking for processes to terminate...
terminating process PID.koala_koala (54791)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
Timekeeper ended at Sat Jan 27 23:59:13 CST 2024
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:38:51 up 20 days, 15:12,  6 users,  load average: 0.00, 0.02, 0.06
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304       1024    4193280   1% /dev/shm
tmpfs                        65880516     191492   65689024   1% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9251904    7515072  56% /
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md0                   3904859232 2918667868  986191364  75% /scr
/dev/sda1                      520876     288780     232096  56% /boot
/dev/md10                 11718682624 8162011532 3556671092  70% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
10.10.10.86:/home           961432576  153626624  758968320  17% /home
10.10.10.86:/mnt/hdf        961432576  877171712   35422208  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  881869824   30724096  97% /mnt/scr1
10.10.10.85:/data/ftp       480719104  439542400   16757504  97% /mnt/ftp
10.10.10.85:/data/web       480719104  439542400   16757504  97% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/29138
tmpfs                        13176104          0   13176104   0% /run/user/22417
tmpfs                        13176104          0   13176104   0% /run/user/10022
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0127Sat
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 23:39:18 up 20 days, 15:12,  6 users,  load average: 0.07, 0.04, 0.07
tmpfs                        65880516     191532   65688984   1% /run
/dev/mapper/centos00-root    16766976    9251928    7515048  56% /
10.10.10.86:/mnt/scr1       961432576  881870848   30724096  97% /mnt/scr1
Extract source and run autogen if .
Sat Jan 27 23:39:29 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_0127Sat_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Sat Jan 27 23:40:34 CST 2024
Total time = 1m 5s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:39:35 up 10 days, 14:38,  0 users,  load average: 80.99, 80.72, 80.62
/dev/sda7             22292052   4428176  16713224  21% /
/dev/sda5             12192608    406460  11156804   4% /tmp
/dev/sda3             12192636   3108308   8454984  27% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  80085232  64909592  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 439542400  16757504  97% /mnt/ftp
gumund:/data/web     480719104 439542400  16757504  97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Jan 27 23:39:57 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0127Sat_2339
	****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:39:30 up 19 days,  5:50,  0 users,  load average: 0.37, 0.42, 0.26
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     57400  12133860   1% /tmp
/dev/sda3             12850716   4421556   7769704  37% /var
/dev/sdd             152623212 120650884  24212868  84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Jan 27 23:39:40 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0127Sat_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Jan 27 23:40:24 CST 2024
Total time = 0m 44s
*** finished tests in platypus ***
Sat Jan 27 23:40:25 CST 2024
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 23:39:33 up 19 days, 14:52,  1 user,  load average: 0.36, 0.41, 0.34
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    287760   3652084   8% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
/dev/mapper/centos_moohan-var   16371712   3935532  12436180  25% /var
/dev/mapper/centos_moohan-scr  858065536 397540412 460525124  47% /scr
jam:/mnt/hdf                   961432576 877171712  35422208  97% /mnt/hdf
jam:/home                      961432576 153626624 758968320  17% /home
jam:/mnt/scr1                  961432576 881870848  30724096  97% /mnt/scr1
tmpfs                             787972        16    787956   1% /run/user/42
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sat Jan 27 23:39:43 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0127Sat_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sat Jan 27 23:41:06 CST 2024
Total time = 1m 23s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Sat Jan 27 23:39:33 CST 2024)
	****SYSTEM ERROR: ostrich is not reachable (Sat Jan 27 23:39:33 CST 2024)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
