[opa-nightly-tests] jelly OPA_Daily_Tests_0106Sat
hdftest
hdftest at hdfgroup.org
Sun Jan 7 00:20:30 CST 2024
*** OPA Tests on 0106Sat ***
Tests Summary
Tests Time Summary
jelly: Ran 6(0/0/0) hosts, Grand total test time = 20m 43s
Timekeeper log
Timekeeper started at Sat Jan 6 23:59:59 CST 2024
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Sun Jan 7 00:19:59 CST 2024, looking for processes to terminate...
terminating process PID.jelly_jelly (35537)
Remote shell command ended. But some processes might still be
running in the remote machine. Login there to verify.
terminating process PID.koala_koala (35931)
terminating process PID.moohan_moohan (35959)
terminating process PID.platypus_platypus (35945)
Timekeeper ended at Sun Jan 7 00:19:59 CST 2024
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:59:36 up 10 days, 5:38, 2 users, load average: 0.04, 0.06, 0.05
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 0 4194304 0% /dev/shm
tmpfs 65880516 109304 65771212 1% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9492740 7274236 57% /
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md0 3904859232 2885524800 1019334432 74% /scr
/dev/md10 11718682624 8161755896 3556926728 70% /mnt/wrk
/dev/sda1 520876 288780 232096 56% /boot
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
10.10.10.85:/data/web 480719104 439235200 17064704 97% /mnt/web
10.10.10.86:/home 961432576 153607168 758987776 17% /home
10.10.10.86:/mnt/hdf 961432576 883054592 29540352 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 882958336 29636608 97% /mnt/scr1
10.10.10.85:/data/ftp 480719104 439235200 17064704 97% /mnt/ftp
tmpfs 13176104 0 13176104 0% /run/user/29138
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0106Sat
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
00:00:05 up 10 days, 5:38, 2 users, load average: 0.30, 0.12, 0.07
tmpfs 65880516 109344 65771172 1% /run
/dev/mapper/centos00-root 16766976 9493056 7273920 57% /
Wait For /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0107Sun to appear
Sun Jan 7 00:20:29 CST 2024
****INCOMPLETE jelly: snaptest did not complete****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:00:30 up 10 days, 5:24, 0 users, load average: 71.94, 71.58, 71.55
/dev/sda7 22292052 4428164 16713236 21% /
/dev/sda5 12192608 380428 11182836 4% /tmp
/dev/sda3 12192636 4904320 6658972 43% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 80069108 64925716 56% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 439235200 17064704 97% /mnt/ftp
gumund:/data/web 480719104 439235200 17064704 97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:00:20 up 182 days, 16:38, 0 users, load average: 0.41, 0.44, 0.26
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 32872 12158388 1% /tmp
/dev/sda3 12850716 4454672 7736588 37% /var
/dev/sdd 152623212 120848192 24015560 84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
****INCOMPLETE platypus: snaptest did not complete****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
00:00:23 up 114 days, 6:07, 1 user, load average: 0.31, 0.37, 0.20
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402468 3537376 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 3738720 12632992 23% /var
/dev/mapper/centos_moohan-scr 858065536 400054360 458011176 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 153607168 758987776 17% /home
jam:/mnt/hdf 961432576 883054592 29540352 97% /mnt/hdf
jam:/mnt/scr1 961432576 882958336 29636608 97% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
****INCOMPLETE moohan: snaptest did not complete****
Testing ostrich
ostrich is not reachable (Sun Jan 7 00:00:23 CST 2024)
****SYSTEM ERROR: ostrich is not reachable (Sun Jan 7 00:00:23 CST 2024)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
*** finished tests in jelly ***
More information about the opa-nightly-tests
