[opa-nightly-tests] jelly OPA_Daily_Tests_0214Wed
hdftest
hdftest at hdfgroup.org
Thu Feb 15 00:06:12 CST 2024
*** OPA Tests on 0214Wed ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 23s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 20m 42s
Timekeeper log
Timekeeper started at Wed Feb 14 23:45:42 CST 2024
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Thu Feb 15 00:05:42 CST 2024, looking for processes to terminate...
terminating process PID.koala_koala (2646)
Remote shell command ended. But some processes might still be
running in the remote machine. Login there to verify.
Timekeeper ended at Thu Feb 15 00:05:42 CST 2024
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:45:20 up 38 days, 15:18, 12 users, load average: 0.00, 0.01, 0.39
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 1024 4193280 1% /dev/shm
tmpfs 65880516 355936 65524580 1% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9189756 7577220 55% /
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md0 3904859232 2928197432 976661800 75% /scr
/dev/sda1 520876 288780 232096 56% /boot
/dev/md10 11718682624 8163264500 3555418124 70% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
10.10.10.86:/home 961432576 158348288 754245632 18% /home
10.10.10.86:/mnt/hdf 961432576 868335616 44259328 96% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 886051840 26543104 98% /mnt/scr1
10.10.10.85:/data/ftp 480719104 441129856 15170048 97% /mnt/ftp
10.10.10.85:/data/web 480719104 441129856 15170048 97% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/29138
tmpfs 13176104 0 13176104 0% /run/user/22417
tmpfs 13176104 0 13176104 0% /run/user/10057
tmpfs 13176104 0 13176104 0% /run/user/10013
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0214Wed
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
23:45:48 up 38 days, 15:18, 12 users, load average: 0.21, 0.06, 0.40
tmpfs 65880516 355976 65524540 1% /run
/dev/mapper/centos00-root 16766976 9189792 7577184 55% /
/dev/md0 3904859232 2928197396 976661836 75% /scr
10.10.10.86:/mnt/scr1 961432576 886052864 26541056 98% /mnt/scr1
Extract source and run autogen if .
Wed Feb 14 23:45:58 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_0214Wed_2345
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Wed Feb 14 23:47:00 CST 2024
Total time = 1m 2s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:46:53 up 28 days, 14:45, 0 users, load average: 221.23, 220.63, 220.44
/dev/sda7 22292052 4428180 16713220 21% /
/dev/sda5 12192608 418576 11144688 4% /tmp
/dev/sda3 12192636 6309320 5253972 55% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 78030452 66964372 54% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
gumund:/data/ftp 480719104 441129856 15170048 97% /mnt/ftp
gumund:/data/web 480719104 441129856 15170048 97% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Feb 14 23:47:33 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0214Wed_2347
****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:46:22 up 37 days, 5:57, 0 users, load average: 0.27, 0.45, 0.30
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 65548 12125712 1% /tmp
/dev/sda3 12850716 4473892 7717368 37% /var
/dev/sdd 152623212 121548988 23314764 84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Feb 14 23:46:32 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0214Wed_2346
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Feb 14 23:47:17 CST 2024
Total time = 0m 45s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:46:25 up 37 days, 14:59, 1 user, load average: 0.30, 0.36, 1.17
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418864 3520980 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
/dev/mapper/centos_moohan-var 16371712 3854352 12517360 24% /var
/dev/mapper/centos_moohan-scr 858065536 399357504 458708032 47% /scr
jam:/mnt/hdf 961432576 868335616 44259328 96% /mnt/hdf
jam:/home 961432576 158348288 754245632 18% /home
jam:/mnt/scr1 961432576 886052864 26541056 98% /mnt/scr1
tmpfs 787972 16 787956 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/27429
tmpfs 787972 0 787972 0% /run/user/0
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Wed Feb 14 23:46:36 CST 2024
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0214Wed_2346
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Wed Feb 14 23:47:58 CST 2024
Total time = 1m 22s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Wed Feb 14 23:46:25 CST 2024)
****SYSTEM ERROR: ostrich is not reachable (Wed Feb 14 23:46:25 CST 2024)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
