[opa-nightly-tests] jelly OPA_Daily_Tests_0925Mon
hdftest hdftest at hdfgroup.org
Mon Sep 25 21:56:42 CDT 2023
*** OPA Tests on 0925Mon ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 4s
moohan: Ran 1(1/0/0) tests, Grand total test time =  2m 23s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  3m 31s
   Timekeeper log
Timekeeper started at Mon Sep 25 21:53:23 CDT 2023
Timekeeper sleeping for 1200 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:53:01 up 61 days, 55 min,  8 users,  load average: 0.89, 0.84, 1.42
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      93728    4100576   3% /dev/shm
tmpfs                        65880516     650172   65230344   1% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    8919532    7847444  54% /
/dev/md0                   3904859232 2165222588 1739636644  56% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7817161692 3901520932  67% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  419617920   36681984  92% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  880351232   32243712  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  884942848   27651072  97% /mnt/scr1
10.10.10.85:/data/web       480719104  419617920   36681984  92% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  152905728  759688192  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/22417
tmpfs                        13176104          0   13176104   0% /run/user/10008
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/0
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0925Mon
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 21:53:28 up 61 days, 55 min,  8 users,  load average: 0.99, 0.87, 1.41
tmpfs                        65880516     650156   65230360   1% /run
/dev/mapper/centos00-root    16766976    8919356    7847620  54% /
/dev/md0                   3904859232 2165219604 1739639628  56% /scr
10.10.10.85:/data/ftp       480719104  419626112   36673792  92% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  880354304   32239616  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  884944896   27650048  97% /mnt/scr1
10.10.10.85:/data/web       480719104  419626112   36673792  92% /mnt/web
Extract source and run autogen if .
Mon Sep 25 21:53:39 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_0925Mon_2153
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Mon Sep 25 21:54:42 CDT 2023
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:53:30 up 79 days, 13:31,  0 users,  load average: 0.00, 0.20, 0.41
/dev/sda7             22292052   4428136  16713264  21% /
/dev/sda5             12192608    398724  11164540   4% /tmp
/dev/sda3             12192636   1199744  10363548  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79750552  65244272  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Sep 25 21:53:40 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0925Mon_2153
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Sep 25 21:54:14 CDT 2023
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:53:33 up 79 days, 13:31,  0 users,  load average: 0.25, 0.45, 0.66
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     73904  12117356   1% /tmp
/dev/sda3             12850716   6054564   6136696  50% /var
/dev/sdd             152623212 120977328  23886424  84% /scr
10.10.10.86:/mnt/hdf 961432576 880241664  32353280  97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Sep 25 21:53:43 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0925Mon_2153
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Sep 25 21:54:27 CDT 2023
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 21:53:39 up 11 days,  3:00,  1 user,  load average: 3.64, 3.19, 3.16
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    189420   3750424   5% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   4804964  11566748  30% /var
/dev/mapper/centos_moohan-scr  858065536 397821268 460244268  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
gumund:/data/ftp               480719104 419626112  36673792  92% /mnt/ftp
gumund:/data/web               480719104 419626112  36673792  92% /mnt/web
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152905728 759688192  17% /home
jam:/mnt/hdf                   961432576 880182272  32411648  97% /mnt/hdf
jam:/mnt/scr1                  961432576 884944896  27650048  97% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Mon Sep 25 21:53:52 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0925Mon_2153
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Mon Sep 25 21:56:12 CDT 2023
Total time = 2m 21s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Mon Sep 25 21:53:39 CDT 2023)
	****SYSTEM ERROR: ostrich is not reachable (Mon Sep 25 21:53:39 CDT 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
