[opa-nightly-tests] jelly OPA_Daily_Tests_0917Sun
hdftest
hdftest at hdfgroup.org
Sun Sep 17 21:57:45 CDT 2023
*** OPA Tests on 0917Sun ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 8s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 26s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 33s
Timekeeper log
Timekeeper started at Sun Sep 17 21:55:22 CDT 2023
Timekeeper sleeping for 1200 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:55:00 up 53 days, 57 min, 8 users, load average: 3.39, 4.48, 3.55
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 87304 4107000 3% /dev/shm
tmpfs 65880516 551868 65328648 1% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9029016 7737960 54% /
/dev/md0 3904859232 2169023024 1735836208 56% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7816992196 3901690428 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 420092288 36207616 93% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 878369792 34224128 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 888753152 23841792 98% /mnt/scr1
10.10.10.85:/data/web 480719104 420092288 36207616 93% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
tmpfs 13176104 4 13176100 1% /run/user/10019
tmpfs 13176104 0 13176104 0% /run/user/22417
10.10.10.86:/home 961432576 152905728 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/10008
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0917Sun
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
21:55:28 up 53 days, 57 min, 8 users, load average: 3.09, 4.31, 3.52
tmpfs 65880516 551908 65328608 1% /run
/dev/mapper/centos00-root 16766976 9029096 7737880 54% /
/dev/md0 3904859232 2170076004 1734783228 56% /scr
10.10.10.86:/mnt/hdf 961432576 878387200 34207744 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 888753152 23840768 98% /mnt/scr1
Extract source and run autogen if .
Sun Sep 17 21:55:38 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_0917Sun_2155
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Sun Sep 17 21:56:46 CDT 2023
Total time = 1m 8s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:55:30 up 71 days, 13:33, 0 users, load average: 0.00, 0.23, 0.42
/dev/sda7 22292052 4428136 16713264 21% /
/dev/sda5 12192608 401752 11161512 4% /tmp
/dev/sda3 12192636 1198672 10364620 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79733816 65261008 55% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 878388224 34206720 97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Sep 17 21:55:40 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0917Sun_2155
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Sep 17 21:56:12 CDT 2023
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:55:33 up 71 days, 13:33, 0 users, load average: 1.42, 3.33, 3.63
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 74528 12116732 1% /tmp
/dev/sda3 12850716 6282524 5908736 52% /var
/dev/sdd 152623212 122232072 22631680 85% /scr
10.10.10.86:/mnt/hdf 961432576 878390272 34204672 97% /mnt/hdf
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Sep 17 21:55:43 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0917Sun_2155
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Sep 17 21:56:28 CDT 2023
Total time = 0m 45s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
21:55:36 up 3 days, 3:02, 1 user, load average: 2.57, 2.65, 3.65
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 58348 3881496 2% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4779896 11591816 30% /var
/dev/mapper/centos_moohan-scr 858065536 402434384 455631152 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33448 16338264 1% /tmp
gumund:/data/ftp 480719104 420092288 36207616 93% /mnt/ftp
gumund:/data/web 480719104 420092288 36207616 93% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152905728 759688192 17% /home
jam:/mnt/hdf 961432576 878391296 34203648 97% /mnt/hdf
jam:/mnt/scr1 961432576 888753152 23840768 98% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sun Sep 17 21:55:46 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_0917Sun_2155
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sun Sep 17 21:57:12 CDT 2023
Total time = 1m 26s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Sun Sep 17 21:55:35 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Sun Sep 17 21:55:35 CDT 2023)
Sun Sep 17 21:57:43 CDT 2023
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
