[opa-nightly-tests] jelly OPA_Daily_Tests_0906Wed
hdftest hdftest at hdfgroup.org
Wed Sep 6 21:58:47 CDT 2023
*** OPA Tests on 0906Wed ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 4s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  2m 28s
   Timekeeper log
Timekeeper started at Wed Sep  6 21:56:31 CDT 2023
Timekeeper sleeping for 1200 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:56:09 up 42 days, 58 min,  1 user,  load average: 0.10, 0.15, 2.01
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      78348    4115956   2% /dev/shm
tmpfs                        65880516     445184   65435332   1% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9407760    7359216  57% /
/dev/md0                   3904859232 2163148256 1741710976  56% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7816856920 3901825704  67% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  447238528    9061376  99% /mnt/ftp
10.10.10.86:/home           961432576  152442880  760151040  17% /home
10.10.10.86:/mnt/hdf        961432576  877241344   35352576  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  887102464   25491456  98% /mnt/scr1
10.10.10.85:/data/web       480719104  447238528    9061376  99% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/29138
tmpfs                        13176104          0   13176104   0% /run/user/10013
tmpfs                        13176104          0   13176104   0% /run/user/10008
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0906Wed
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 21:56:37 up 42 days, 59 min,  1 user,  load average: 0.14, 0.15, 1.96
tmpfs                        65880516     445224   65435292   1% /run
/dev/mapper/centos00-root    16766976    9407776    7359200  57% /
10.10.10.86:/mnt/hdf        961432576  876744704   35849216  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  887104512   25490432  98% /mnt/scr1
Extract source and run autogen if .
Wed Sep  6 21:56:47 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_0906Wed_2156
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Wed Sep  6 21:57:51 CDT 2023
Total time = 1m 4s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:56:39 up 60 days, 13:34,  0 users,  load average: 0.00, 0.11, 0.33
/dev/sda7             22292052   4428132  16713268  21% /
/dev/sda5             12192608    398772  11164492   4% /tmp
/dev/sda3             12192636   1199504  10363788  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79615352  65379472  55% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Sep  6 21:56:49 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0906Wed_2156
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Wed Sep  6 21:57:22 CDT 2023
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:56:42 up 60 days, 13:34,  0 users,  load average: 0.24, 0.32, 0.63
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     71676  12119584   1% /tmp
/dev/sda3             12850716   6128072   6063188  51% /var
/dev/sdd             152623212 121887420  22976332  85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Sep  6 21:56:52 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0906Wed_2156
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Sep  6 21:57:36 CDT 2023
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 21:56:45 up 60 days, 18:24,  1 user,  load average: 1.41, 3.46, 3.62
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    402468   3537376  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-tmp   16371712     33416  16338296   1% /tmp
/dev/mapper/centos_moohan-var   16371712   4623308  11748404  29% /var
/dev/mapper/centos_moohan-scr  858065536 401438188 456627348  47% /scr
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152442880 760151040  17% /home
jam:/mnt/hdf                   961432576 876744704  35849216  97% /mnt/hdf
jam:/mnt/scr1                  961432576 887104512  25490432  98% /mnt/scr1
gumund:/data/web               480719104 447238528   9061376  99% /mnt/web
gumund:/data/ftp               480719104 447238528   9061376  99% /mnt/ftp
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Wed Sep  6 21:56:55 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_0906Wed_2156
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Wed Sep  6 21:58:17 CDT 2023
Total time = 1m 22s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Wed Sep  6 21:56:44 CDT 2023)
	****SYSTEM ERROR: ostrich is not reachable (Wed Sep  6 21:56:44 CDT 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
