[opa-nightly-tests] jelly OPA_Daily_Tests_1028Sat
hdftest hdftest at hdfgroup.org
Sun Oct 29 00:20:46 CDT 2023
*** OPA Tests on 1028Sat ***
   Tests Summary
   Tests Time Summary
jelly: Ran 6(0/0/0) hosts, Grand total test time =  20m 43s
   Timekeeper log
Timekeeper started at Sun Oct 29 00:00:15 CDT 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Sun Oct 29 00:20:15 CDT 2023, looking for processes to terminate...
terminating process PID.jelly_jelly (40740)
Remote shell command ended.  But some processes might still be
running in the remote machine.  Login there to verify.
terminating process PID.koala_koala (40813)
terminating process PID.moohan_moohan (40842)
terminating process PID.platypus_platypus (40827)
Timekeeper ended at Sun Oct 29 00:20:15 CDT 2023
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:59:53 up 94 days,  3:02,  3 users,  load average: 0.01, 0.02, 0.05
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      12752    4181552   1% /dev/shm
tmpfs                        65880516     985740   64894776   2% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    8550592    8216384  51% /
/dev/md0                   3904859232 2182202612 1722656620  56% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7822789540 3895893084  67% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  431540992   24758912  95% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  877331456   35263488  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  889406464   23188480  98% /mnt/scr1
10.10.10.85:/data/web       480719104  431540992   24758912  95% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  152906752  759688192  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1028Sat
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 00:00:21 up 94 days,  3:02,  3 users,  load average: 0.08, 0.04, 0.05
tmpfs                        65880516     985780   64894736   2% /run
/dev/mapper/centos00-root    16766976    8551136    8215840  51% /
Wait For /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1029Sun to appear
	****INCOMPLETE jelly: snaptest did not complete****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:00:23 up 112 days, 15:38,  0 users,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4428140  16713260  21% /
/dev/sda5             12192608    370720  11192544   4% /tmp
/dev/sda3             12192636   1175572  10387720  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79760076  65234748  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
	****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:00:25 up 112 days, 15:38,  0 users,  load average: 0.37, 0.38, 0.24
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     32976  12158284   1% /tmp
/dev/sda3             12850716   5428764   6762496  45% /var
/dev/sdd             152623212 120217904  24645848  83% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
	****INCOMPLETE platypus: snaptest did not complete****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 00:00:29 up 44 days,  5:07,  1 user,  load average: 0.47, 0.45, 0.39
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    402384   3537460  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   4153836  12217876  26% /var
/dev/mapper/centos_moohan-scr  858065536 397573700 460491836  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
gumund:/data/ftp               480719104 431540992  24758912  95% /mnt/ftp
gumund:/data/web               480719104 431540992  24758912  95% /mnt/web
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152906752 759688192  17% /home
jam:/mnt/hdf                   961432576 877331456  35263488  97% /mnt/hdf
jam:/mnt/scr1                  961432576 889406464  23188480  98% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
	****INCOMPLETE moohan: snaptest did not complete****
Testing ostrich
ostrich is not reachable (Sun Oct 29 00:00:29 CDT 2023)
	****SYSTEM ERROR: ostrich is not reachable (Sun Oct 29 00:00:29 CDT 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
*** finished tests in jelly ***
More information about the opa-nightly-tests mailing list
