[opa-nightly-tests] jelly OPA_Daily_Tests_1024Tue
hdftest
hdftest at hdfgroup.org
Wed Oct 25 00:01:33 CDT 2023
*** OPA Tests on 1024Tue ***
Tests Summary
SKIPPED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
SKIPPED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
SKIPPED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Tests Time Summary
koala: Ran 1(0/0/1) tests, Grand total test time = 0m 0s
platypus: Ran 1(0/0/1) tests, Grand total test time = 0m 0s
moohan: Ran 1(0/0/1) tests, Grand total test time = 0m 1s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 2s
Timekeeper log
Timekeeper started at Tue Oct 24 23:59:43 CDT 2023
Timekeeper sleeping for 1200 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:59:20 up 90 days, 3:01, 3 users, load average: 0.03, 0.04, 0.08
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 12752 4181552 1% /dev/shm
tmpfs 65880516 936668 64943848 2% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9171300 7595676 55% /
/dev/md0 3904859232 2206481160 1698378072 57% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7822959556 3895723068 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 425956096 30343808 94% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 877304832 35290112 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 888475648 24119296 98% /mnt/scr1
10.10.10.85:/data/web 480719104 425956096 30343808 94% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 152906752 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/10022
tmpfs 13176104 0 13176104 0% /run/user/22417
tmpfs 13176104 0 13176104 0% /run/user/10013
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1024Tue
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
23:59:49 up 90 days, 3:02, 3 users, load average: 0.30, 0.10, 0.10
tmpfs 65880516 936708 64943808 2% /run
/dev/mapper/centos00-root 16766976 9171264 7595712 55% /
/dev/md10 11718682624 7822959804 3895722820 67% /mnt/wrk
10.10.10.86:/mnt/scr1 961432576 888475648 24118272 98% /mnt/scr1
Extract source and run autogen if .
Tue Oct 24 23:59:59 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1024Tue_2359
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Wed Oct 25 00:01:02 CDT 2023
Total time = 1m 3s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:59:52 up 108 days, 15:37, 0 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4428140 16713260 21% /
/dev/sda5 12192608 402036 11161228 4% /tmp
/dev/sda3 12192636 1173064 10390228 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79741836 65252988 55% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
No more time to run tests: skipping remaining tests:
*** finished tests in koala ***
Wed Oct 25 00:00:02 CDT 2023
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:59:55 up 108 days, 15:37, 0 users, load average: 0.32, 0.30, 0.17
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 72996 12118264 1% /tmp
/dev/sda3 12850716 5416744 6774516 45% /var
/dev/sdd 152623212 120944648 23919104 84% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
*** finished tests in platypus ***
Wed Oct 25 00:00:05 CDT 2023
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:59:57 up 40 days, 5:06, 1 user, load average: 0.42, 0.48, 0.38
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402384 3537460 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4229212 12142500 26% /var
/dev/mapper/centos_moohan-scr 858065536 402101864 455963672 47% /scr
/dev/mapper/centos_moohan-tmp 16371712 33400 16338312 1% /tmp
gumund:/data/ftp 480719104 425956096 30343808 94% /mnt/ftp
gumund:/data/web 480719104 425956096 30343808 94% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152906752 759688192 17% /home
jam:/mnt/hdf 961432576 877304832 35290112 97% /mnt/hdf
jam:/mnt/scr1 961432576 888475648 24118272 98% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
*** finished tests in moohan ***
Wed Oct 25 00:00:08 CDT 2023
Testing ostrich
ostrich is not reachable (Tue Oct 24 23:59:57 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Tue Oct 24 23:59:57 CDT 2023)
Wed Oct 25 00:01:32 CDT 2023
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests
