[opa-nightly-tests] jelly OPA_Daily_Tests_1022Sun
hdftest
hdftest at hdfgroup.org
Mon Oct 23 00:02:31 CDT 2023
*** OPA Tests on 1022Sun ***
Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 27s
Timekeeper log
Timekeeper started at Sun Oct 22 00:00:22 CDT 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Sun Oct 22 00:20:22 CDT 2023, looking for processes to terminate...
Timekeeper ended at Sun Oct 22 00:20:22 CDT 2023
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:00:00 up 88 days, 3:02, 2 users, load average: 0.01, 0.02, 0.26
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 12416 4181888 1% /dev/shm
tmpfs 65880516 920284 64960232 2% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 9112228 7654748 55% /
/dev/md0 3904859232 2207677204 1697182028 57% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7822861908 3895820716 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 425134848 31165056 94% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 877288448 35306496 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 891402240 21191680 98% /mnt/scr1
10.10.10.85:/data/web 480719104 425134848 31165056 94% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 152906752 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/22417
tmpfs 13176104 0 13176104 0% /run/user/10013
tmpfs 13176104 0 13176104 0% /run/user/10022
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1023Mon
Mon Oct 23 00:00:22 CDT 2023
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
00:00:27 up 88 days, 3:02, 2 users, load average: 0.15, 0.05, 0.26
tmpfs 65880516 920324 64960192 2% /run
/dev/mapper/centos00-root 16766976 9112276 7654700 55% /
Extract source and run autogen if .
Mon Oct 23 00:00:38 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jelly_1023Mon_0000
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Mon Oct 23 00:01:39 CDT 2023
Total time = 1m 1s
*** finished tests in jelly ***
jelly: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:00:30 up 106 days, 15:38, 0 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4428140 16713260 21% /
/dev/sda5 12192608 370720 11192544 4% /tmp
/dev/sda3 12192636 1166544 10396748 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79736864 65257960 55% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Oct 23 00:00:40 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1023Mon_0000
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Oct 23 00:01:15 CDT 2023
Total time = 0m 35s
*** finished tests in koala ***
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 35s
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:00:33 up 106 days, 15:38, 0 users, load average: 0.35, 0.33, 0.21
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 32972 12158288 1% /tmp
/dev/sda3 12850716 5385312 6805948 45% /var
/dev/sdd 152623212 122430456 22433296 85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Oct 23 00:00:43 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1023Mon_0000
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Oct 23 00:01:29 CDT 2023
Total time = 0m 46s
*** finished tests in platypus ***
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 46s
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
00:00:38 up 38 days, 5:07, 1 user, load average: 2.04, 3.26, 3.24
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 410604 3529240 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4119528 12252184 26% /var
/dev/mapper/centos_moohan-scr 858065536 403586856 454478680 48% /scr
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
gumund:/data/ftp 480719104 425134848 31165056 94% /mnt/ftp
gumund:/data/web 480719104 425134848 31165056 94% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152906752 759688192 17% /home
jam:/mnt/hdf 961432576 877288448 35306496 97% /mnt/hdf
jam:/mnt/scr1 961432576 891403264 21191680 98% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Mon Oct 23 00:00:48 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1023Mon_0000
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Mon Oct 23 00:02:00 CDT 2023
Total time = 1m 12s
*** finished tests in moohan ***
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 12s
Testing ostrich
ostrich is not reachable (Mon Oct 23 00:00:38 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Mon Oct 23 00:00:38 CDT 2023)
Mon Oct 23 00:02:30 CDT 2023
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
jelly: Ran 6(0/0/0) hosts, Grand total test time = 2m 20s
More information about the opa-nightly-tests
