[opa-nightly-tests] jelly OPA_Daily_Tests_1020Fri
hdftest hdftest at hdfgroup.org
Fri Oct 20 23:52:17 CDT 2023
*** OPA Tests on 1020Fri ***
   Tests Summary
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 4s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 20s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  2m 28s
   Timekeeper log
Timekeeper started at Fri Oct 20 23:50:01 CDT 2023
Timekeeper sleeping for 1200 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:49:39 up 86 days,  2:52,  2 users,  load average: 0.12, 0.45, 2.78
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304       9688    4184616   1% /dev/shm
tmpfs                        65880516     903940   64976576   2% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9066212    7700764  55% /
/dev/md0                   3904859232 2197797440 1707061792  57% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7822861700 3895820924  67% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  425384704   30915200  94% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  877264896   35329024  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  887390208   25204736  98% /mnt/scr1
10.10.10.85:/data/web       480719104  425384704   30915200  94% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  152906752  759688192  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/10022
tmpfs                        13176104          0   13176104   0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1020Fri
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 23:50:07 up 86 days,  2:52,  2 users,  load average: 0.15, 0.43, 2.71
tmpfs                        65880516     903980   64976536   2% /run
/dev/mapper/centos00-root    16766976    9066420    7700556  55% /
10.10.10.86:/mnt/scr1       961432576  887391232   25202688  98% /mnt/scr1
Extract source and run autogen if .
Fri Oct 20 23:50:17 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_1020Fri_2350
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Fri Oct 20 23:51:21 CDT 2023
Total time = 1m 4s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:50:10 up 104 days, 15:28,  0 users,  load average: 0.00, 0.01, 0.00
/dev/sda7             22292052   4428140  16713260  21% /
/dev/sda5             12192608    402028  11161236   4% /tmp
/dev/sda3             12192636   1174948  10388344  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79721312  65273512  55% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Oct 20 23:50:20 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1020Fri_2350
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Oct 20 23:50:54 CDT 2023
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:50:12 up 104 days, 15:28,  0 users,  load average: 0.55, 0.46, 0.22
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716    190992  12000268   2% /tmp
/dev/sda3             12850716   5608964   6582296  47% /var
/dev/sdd             152623212 121703604  23160148  85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Oct 20 23:50:23 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1020Fri_2350
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Oct 20 23:51:05 CDT 2023
Total time = 0m 42s
*** finished tests in platypus ***
Fri Oct 20 23:51:06 CDT 2023
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 23:50:16 up 36 days,  4:57,  1 user,  load average: 0.33, 0.99, 2.00
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    410576   3529268  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   4371996  11999716  27% /var
/dev/mapper/centos_moohan-scr  858065536 400046256 458019280  47% /scr
/dev/mapper/centos_moohan-tmp   16371712     33416  16338296   1% /tmp
gumund:/data/ftp               480719104 425384704  30915200  94% /mnt/ftp
gumund:/data/web               480719104 425384704  30915200  94% /mnt/web
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152906752 759688192  17% /home
jam:/mnt/hdf                   961432576 877264896  35329024  97% /mnt/hdf
jam:/mnt/scr1                  961432576 887391232  25202688  98% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Oct 20 23:50:26 CDT 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1020Fri_2350
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Oct 20 23:51:46 CDT 2023
Total time = 1m 20s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Fri Oct 20 23:50:15 CDT 2023)
	****SYSTEM ERROR: ostrich is not reachable (Fri Oct 20 23:50:15 CDT 2023)
	Fri Oct 20 23:52:16 CDT 2023
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
