[opa-nightly-tests] jelly OPA_Daily_Tests_1012Thu
hdftest
hdftest at hdfgroup.org
Fri Oct 13 00:20:41 CDT 2023
*** OPA Tests on 1012Thu ***
Tests Summary
Tests Time Summary
jelly: Ran 6(0/0/0) hosts, Grand total test time = 20m 42s
Timekeeper log
Timekeeper started at Fri Oct 13 00:00:11 CDT 2023
Timekeeper sleeping for 1200 seconds
Timekeeper woke up at Fri Oct 13 00:20:11 CDT 2023, looking for processes to terminate...
terminating process PID.jelly_jelly (29909)
Remote shell command ended. But some processes might still be
running in the remote machine. Login there to verify.
terminating process PID.koala_koala (29984)
terminating process PID.moohan_moohan (30012)
terminating process PID.platypus_platypus (29998)
Timekeeper ended at Fri Oct 13 00:20:11 CDT 2023
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:59:49 up 78 days, 3:02, 2 users, load average: 0.00, 0.01, 0.05
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 65868920 0 65868920 0% /dev
tmpfs 4194304 100280 4094024 3% /dev/shm
tmpfs 65880516 830092 65050424 2% /run
tmpfs 65880516 0 65880516 0% /sys/fs/cgroup
/dev/mapper/centos00-root 16766976 8950892 7816084 54% /
/dev/md0 3904859232 2187262880 1717596352 57% /scr
tmpfs 65880516 0 65880516 0% /mnt/daos
/dev/md10 11718682624 7823138544 3895544080 67% /mnt/wrk
/dev/mapper/centos00-opt 134152192 127161992 6990200 95% /opt
/dev/sda1 520876 288780 232096 56% /boot
10.10.10.85:/data/ftp 480719104 429696640 26603264 95% /mnt/ftp
10.10.10.86:/mnt/hdf 961432576 877176832 35418112 97% /mnt/hdf
10.10.10.86:/mnt/scr1 961432576 890255360 22339584 98% /mnt/scr1
10.10.10.85:/data/web 480719104 429696640 26603264 95% /mnt/web
tmpfs 13176104 0 13176104 0% /run/user/29138
10.10.10.86:/home 961432576 152906752 759688192 17% /home
tmpfs 13176104 0 13176104 0% /run/user/27429
tmpfs 13176104 0 13176104 0% /run/user/22417
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1012Thu
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
00:00:16 up 78 days, 3:02, 2 users, load average: 0.16, 0.05, 0.06
tmpfs 65880516 830132 65050384 2% /run
/dev/mapper/centos00-root 16766976 8950960 7816016 54% /
10.10.10.86:/mnt/scr1 961432576 890256384 22338560 98% /mnt/scr1
Wait For /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1013Fri to appear
****INCOMPLETE jelly: snaptest did not complete****
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:00:18 up 96 days, 15:38, 0 users, load average: 0.02, 0.03, 0.01
/dev/sda7 22292052 4428140 16713260 21% /
/dev/sda5 12192608 370720 11192544 4% /tmp
/dev/sda3 12192636 1168772 10394520 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 79692460 65302364 55% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
****INCOMPLETE koala: snaptest did not complete****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:00:21 up 96 days, 15:38, 0 users, load average: 0.41, 0.34, 0.17
/dev/sda6 54205540 43007028 8438372 84% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 32976 12158284 1% /tmp
/dev/sda3 12850716 5372632 6818628 45% /var
/dev/sdd 152623212 123199464 21664288 86% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
****INCOMPLETE platypus: snaptest did not complete****
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
00:00:24 up 28 days, 5:07, 1 user, load average: 0.38, 0.40, 0.39
/dev/mapper/centos_moohan-root 52196352 10417912 41778440 20% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402384 3537460 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312960 193792 62% /boot
/dev/mapper/centos_moohan-var 16371712 4157120 12214592 26% /var
/dev/mapper/centos_moohan-scr 858065536 404193188 453872348 48% /scr
/dev/mapper/centos_moohan-tmp 16371712 33416 16338296 1% /tmp
gumund:/data/ftp 480719104 429696640 26603264 95% /mnt/ftp
gumund:/data/web 480719104 429696640 26603264 95% /mnt/web
tmpfs 787972 16 787956 1% /run/user/42
jam:/home 961432576 152906752 759688192 17% /home
jam:/mnt/hdf 961432576 877176832 35418112 97% /mnt/hdf
jam:/mnt/scr1 961432576 890256384 22338560 98% /mnt/scr1
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
****INCOMPLETE moohan: snaptest did not complete****
Testing ostrich
ostrich is not reachable (Fri Oct 13 00:00:24 CDT 2023)
****SYSTEM ERROR: ostrich is not reachable (Fri Oct 13 00:00:24 CDT 2023)
****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
****SYSTEM ERROR osx1011test: runtest command failed ****
*** finished tests in jelly ***
More information about the opa-nightly-tests
