[opa-nightly-tests] jelly OPA_Daily_Tests_1113Mon_FAILED!!!
hdftest hdftest at hdfgroup.org
Mon Nov 13 00:04:38 CST 2023
*** OPA Tests on 1113Mon ***
   Tests Summary
****FAILED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala****
PASSED jelly: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
jelly: Ran 1(1/0/0) tests, Grand total test time =  1m 4s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 19s
koala: Ran 1(0/1/0) tests, Grand total test time =  2m 48s
jelly: Ran 6(0/0/0) hosts, Grand total test time =  3m 48s
   Timekeeper log
Timekeeper started at Mon Nov 13 00:01:02 CST 2023
Timekeeper sleeping for 1200 seconds
   Tests Failures
Dumping logfile of koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/koala_1113Mon_0001
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads                 Incorrect number of elements dequeued: 3145879 Expected: 4500000
*FAILED*
        at /home/hdftest/snapshots-opa/current/test/test_queue.c:399 in test_queue_threaded()...
    Unexpected return from 1 thread
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                           PASSED
Testing multithreaded queue (empty queue) with 100 threads                Incorrect number of elements dequeued: 4810921 Expected: 4950000
*FAILED*
Testing multithreaded queue (full queue) with 100 threads              PASSED
***** 2 QUEUE TESTS FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mpich.org/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/koala/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/koala/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Mon Nov 13 00:04:08 CST 2023 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:00:40 up 109 days,  4:03,  7 users,  load average: 0.00, 0.01, 0.26
Filesystem                  1K-blocks       Used  Available Use% Mounted on
devtmpfs                     65868920          0   65868920   0% /dev
tmpfs                         4194304      22424    4171880   1% /dev/shm
tmpfs                        65880516    1133348   64747168   2% /run
tmpfs                        65880516          0   65880516   0% /sys/fs/cgroup
/dev/mapper/centos00-root    16766976    9206376    7560600  55% /
/dev/md0                   3904859232 2345320792 1559538440  61% /scr
tmpfs                        65880516          0   65880516   0% /mnt/daos
/dev/md10                 11718682624 7888059376 3830623248  68% /mnt/wrk
/dev/mapper/centos00-opt    134152192  127161992    6990200  95% /opt
/dev/sda1                      520876     288780     232096  56% /boot
10.10.10.85:/data/ftp       480719104  436740992   19558912  96% /mnt/ftp
10.10.10.86:/mnt/hdf        961432576  879818752   32776192  97% /mnt/hdf
10.10.10.86:/mnt/scr1       961432576  888081408   24512512  98% /mnt/scr1
10.10.10.85:/data/web       480719104  436740992   19558912  96% /mnt/web
tmpfs                        13176104          0   13176104   0% /run/user/29138
10.10.10.86:/home           961432576  152906752  759688192  17% /home
tmpfs                        13176104          0   13176104   0% /run/user/22417
tmpfs                        13176104          0   13176104   0% /run/user/27429
tmpfs                        13176104          0   13176104   0% /run/user/10008
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1113Mon
*** launching tests from jelly ***
TESTHOST is jelly
koala
platypus
moohan
ostrich
osx1011test
    Fork off timekeeper 20
Testing jelly
ssh -o ConnectTimeout=60 jelly -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jelly
 00:01:08 up 109 days,  4:03,  7 users,  load average: 0.08, 0.03, 0.25
tmpfs                        65880516    1133388   64747128   2% /run
/dev/mapper/centos00-root    16766976    9206416    7560560  55% /
Extract source and run autogen if .
Mon Nov 13 00:01:18 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests in jelly ***
Uname -a: Linux jelly 3.10.0-1160.80.1.el7.x86_64 #1 SMP Tue Nov 8 15:48:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jelly_1113Mon_0001
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jelly deploy jelly tests for jelly ***
Mon Nov 13 00:02:22 CST 2023
Total time = 1m 4s
*** finished tests in jelly ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:01:10 up 2 days, 13:42,  0 users,  load average: 3.04, 3.01, 2.95
/dev/sda7             22292052   4428148  16713252  21% /
/dev/sda5             12192608    371296  11191968   4% /tmp
/dev/sda3             12192636   1188092  10375200  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  79895856  65098968  56% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
gumund:/data/ftp     480719104 436740992  19558912  96% /mnt/ftp
gumund:/data/web     480719104 436740992  19558912  96% /mnt/web
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Nov 13 00:01:20 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Total time = 2m 48s
*** finished tests in koala ***
****SYSTEM ERROR koala: Abnormal exit from runtest ****
	****SYSTEM ERROR koala: runtest command failed ****
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:01:13 up 127 days, 16:39,  0 users,  load average: 0.43, 0.41, 0.27
/dev/sda6             54205540  43007028   8438372  84% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     33112  12158148   1% /tmp
/dev/sda3             12850716   5323072   6868188  44% /var
/dev/sdd             152623212 122436172  22427580  85% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Nov 13 00:01:23 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1113Mon_0001
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Nov 13 00:02:07 CST 2023
Total time = 0m 44s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 00:01:16 up 59 days,  6:08,  1 user,  load average: 2.25, 3.73, 3.47
/dev/mapper/centos_moohan-root  52196352  10417912  41778440  20% /
devtmpfs                         3923072         0   3923072   0% /dev
tmpfs                            3939844        84   3939760   1% /dev/shm
tmpfs                            3939844    426988   3512856  11% /run
tmpfs                            3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                      506752    312960    193792  62% /boot
/dev/mapper/centos_moohan-var   16371712   4064712  12307000  25% /var
/dev/mapper/centos_moohan-scr  858065536 403584092 454481444  48% /scr
/dev/mapper/centos_moohan-tmp   16371712     33400  16338312   1% /tmp
tmpfs                             787972        16    787956   1% /run/user/42
jam:/home                      961432576 152906752 759688192  17% /home
jam:/mnt/hdf                   961432576 879818752  32776192  97% /mnt/hdf
jam:/mnt/scr1                  961432576 888082432  24512512  98% /mnt/scr1
tmpfs                             787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Mon Nov 13 00:01:26 CST 2023
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1113Mon_0001
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Mon Nov 13 00:02:45 CST 2023
Total time = 1m 19s
*** finished tests in moohan ***
Testing ostrich
ostrich is not reachable (Mon Nov 13 00:01:16 CST 2023)
	****SYSTEM ERROR: ostrich is not reachable (Mon Nov 13 00:01:16 CST 2023)
	****INCOMPLETE ostrich: snaptest did not complete****
Testing osx1011test
ssh -o ConnectTimeout=60 osx1011test -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname osx1011test
grep: /proc/cpuinfo: No such file or directory
snapshots-opa: No such file or directory.
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: Command not found.
****SYSTEM ERROR osx1011test: Abnormal exit from runtest ****
	****SYSTEM ERROR osx1011test: runtest command failed ****
More information about the opa-nightly-tests mailing list
